Old 04-06-2013, 03:27 AM   #1
diss7
Drives: AE86, 2x GT86, TE27
Corner weights - Toyota 86
Finally got round to weighing my car at my mates workshop.
My car is a NZDM Toyota 86 2013 manual. (RHD)
With me in the car, about 10kg of stuff in the boot, and about 15L of gas in the tank, it weighed 1316kg.
The corner weights were..
FL 349
FR 371
RL 293
RR 303
I reweighed the car without me, and with all the stuff I had in the boot taken out. Obviously it still had 15L of gas. Car now weighed in at 1194kg. Seeing as the car is advertised as being 1180kg with minimal gas, 1194kg makes sense with 15L gas.
The corners weighed in at...
FL 341
FR 331
RL 271
RR 251
This gives a front to rear weight ratio of F56:R44, without me. With me it's F55:R45
To confirm, my car is 100% how it was off the showroom floor. Nothing added or removed. My car didn't come with a spare. It came with a repair kit. This was in the car, with the toolkit & jack. The stuff I pulled out of the boot was unrelated stuff I had in there. My car has the 16inch rims.
diss7 is offline   Reply With Quote
Old 04-06-2013, 04:37 AM   #2
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Good to know. Thanks! I think it worth adding that your are from New Zealand and therefore the car is RHD => numbers for LHD should be slightly different, not exactly mirrored though.
Efferalgan is offline   Reply With Quote
Old 04-06-2013, 05:37 AM   #3
diss7
For sure, mentioned both above
Old 04-06-2013, 06:22 AM   #4
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
FL 349
FR 371
RL 293
RR 303
FL 341
FR 331
RL 271
RR 251
@diss7 - left a note on your Facebook about joining the NZ 86/BRZ owners club. We are at www.86brz.co.nz. It's just a closed Facebook group.
nzer is offline   Reply With Quote
Old 04-06-2013, 07:28 AM   #5
alexmotrix
rookie drifter
Drives: 1987 ae86, 1985 celica gts
could you grab a picture of your tire repair kit at it's place, in the trunk? it's not even an option here and I would really like to get one
alexmotrix is offline   Reply With Quote
Old 04-07-2013, 12:23 AM   #6
hal0n
Drives: 2013 WR Blue BRZ
I weighed my US market BRZ (premium). This is with a full tank of gas and nothing else extraneous (tools, mats, spare).
hal0n is offline   Reply With Quote
Old 04-07-2013, 01:08 AM   #7
Allch Chcar
Drives: N/A
That's almost 100lbs less than the official weight of 2,762 lbs!
http://www.subaru.com/vehicles/brz/vehicle-specs.html
Considering that a NC MX-5 GT with hardtop comes in at 2593lbs, I'll never call the Twins heavy again.
That front:rear weight sounds a bit nose heavy. Is your garage level? Don't get me wrong, It's probably correct. But I'll never agree with why they put so much weight in the front. At least it's low in the chassis.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 04-07-2013, 02:37 AM   #8
Blue86
Drives: Sonic Blue 86GT Manual
Would you prefer Porsche supply a transaxle or have a mid mount setup and no rear seats?
Blue86 is offline   Reply With Quote
Old 04-07-2013, 09:26 AM   #9
Ingen
Drives: Ultramarine FR-S 6MT
Battery in the trunk would have worked for me
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 04-07-2013, 10:56 AM   #10
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
I would love to see an FR-S weighed with half a tank of gas, muffler delete, lightweight battery, and the items in the trunk removed.
SkitterSkotter is offline   Reply With Quote
Old 04-07-2013, 10:58 AM   #11
Blue86
Unless its a ship battery in the boot it still won't end up 50:50
Old 04-07-2013, 12:03 PM   #12
jstans84
Drives: Scion FR-S
Translated so that my fellow Americans and I can understand it.
With me in the car, about 22lbs of stuff in the boot, and about 3.96gal of gas in the tank, it weighed 2901lbs.
FL 769lbs
FR 818lbs
RL 645lbs
RR 668lbs
I reweighed the car without me, and with all the stuff I had in the boot taken out. Obviously it still had 3.96gal of gas. Car now weighed in at 2632lbs. Seeing as the car is advertised as being 2601lbs with minimal gas, 2632lbs makes sense with 3.96gal gas.
FL 752lbs
FR 729lbs
RL 597lbs
RR 553lbs
jstans84 is offline   Reply With Quote
Old 04-07-2013, 12:11 PM   #13
hal0n
The garage is very level. It's dead level within the uncertainty of my measuring equipment.
I think with some mild weight reduction, it would be possible to break 2600 lb without many compromises. Lithium battery, muffler delete (or light catback), light weight wheels and tires, etc could get you there. Getting under 2500 lb would take some compromises or real money.
The ideal weight distribution is not static 50:50. There is a dynamic weight shift during acceleration. Ultimately, you would want to have close to 50:50 during some level of acceleration. This means that you use some level of throttle without losing steering as you exist the corners. Also, there is some benefit to braking with the forward bias.
Bring it over and I'll weigh it.
Old 04-07-2013, 05:11 PM   #14
diss7
Total weights line up when converted and allowing for the difference in fuel.
One notable point is the side to side weight difference between RHD and LHD. The LHD is much more balanced without driver as shown above, but this would then be thrown out when the driver is in the car, as the car at rest shows a slightly more weight on the drivers side already.
The RHD car is also heavier on the left side at rest, and the difference is much more than the LHD car. (Which surprises me) But, because the driver is on the right on the RHD car, when the driver enters, it then goes to balance the car out.
Problem for me being 110kg, is that my weight over does this, and then makes my RHD heavier on the right side when I am in it. Without sitting down and doing the exact maths, it would appear to me that a driver half my weight (assuming that weight is applyed proportionatly to each corner as my weight was) would balance the (RHD) car side to side perfectly. This would also make sense as a typical JDM customer would be around the 60kg weight.
You could then argue that a typical 60kg driver would not be as tall as I am, so the seat would be further forward, which would then add more of their weight to the front than the rear, when compared with myself.
Interesting results I think.
Cooks corner Meet slidethis Southern California 62 03-08-2013 05:30 AM
Corner Balancing Gen Southern California 5 11-13-2012 06:42 PM
Wheel weights BAE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-09-2012 09:16 AM
I'm hoping my BRZ is around the corner Evil86 BRZ First-Gen (2012+) — General Topics 4 05-24-2012 07:58 PM
does anyone know why GT86 weights so much? wu_dot_com Scion FR-S / Toyota 86 GT86 General Forum 85 03-19-2012 04:24 PM
