Old 04-05-2013, 10:04 AM   #701
Paragon
Guest
Posts: n/a
Is there an installation guide for the sprint kit?
Old 04-05-2013, 11:16 AM   #702
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
http://www.essexparts.com/media/down...stemManual.pdf
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 04-05-2013, 11:32 AM   #703
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Sprint System Install Guide
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
Old 04-06-2013, 11:26 AM   #704
fishek
Drives: H8R FR-S
Spring Kit pad rattle?
Yesterday, I installed the Sprint kit (with Ferodo DSUNO pads) and all went ok. When I test drove the car I noticed that there is noise coming from the front wheels on bumps and imperfections on the road. The noise is similar to the noise you get when the strut mounts or some other suspension component are a bit loose. I took the wheels off, checked all nuts, bolts and connections and everything seemed rock solid. Then when I rotated the rotors back and forth I noticed that the pads where moving up and down and hitting the caliper and making a knocking noise. The backplate of the pad is smaller than the vertical space in the caliper. I believe this is what is causing the noise.
To be on the safe side I wanted to check with Jeff and other owners here. I know the Sprint kit is a competition kit and doesn't have some anti-rattle instrumentation, but this sounded a bit too much. Is this rattle normal? Can the rattle be a bit more with the DSUNO pads? If it is normal, is there anything I can do to mitigate it? Roads are terrible where I live and it gets quite annoying with this sound on every little bump.
If you want to make a small fortune in motorsports, start with a large one
fishek is offline   Reply With Quote
The Following User Says Thank You to fishek For This Useful Post:
jonnyozero3 (05-04-2013)
Old 04-06-2013, 11:51 AM   #705
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I haven't used ferodo pads yet with the sorint kit but some movement is normal. The pads have to be slightly smaller for heat expansion.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-06-2013, 01:00 PM   #706
fishek
Drives: H8R FR-S
Dave, does your car have the same noise I'm talking about? I have had people sit in the car with me, even experienced racers they were like, what is wrong with the front suspension? It is really very hard to miss.
Old 04-06-2013, 01:42 PM   #707
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Mine does in reverse and the occasional bump. Some pads (like CL pads) are worse as they are smaller than others due to their expansion rates. Mine is noticeable but its quieter by a large margin than the whiteline com-c top hats are
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-06-2013, 02:27 PM   #708
Hanakuso
Mine make that noise. I've just gotten used to it.
Hanakuso is offline   Reply With Quote
Old 04-06-2013, 03:21 PM   #709
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Did you ever try out those shims?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-06-2013, 03:29 PM   #710
Hanakuso
Yeah but haven't tested caliper temps yet. They did get colorful tho
Old 04-06-2013, 08:11 PM   #711
fishek
Drives: H8R FR-S
May I ask which brake shims are those? Are you using them for better heat management or noise reduction?
Old 04-07-2013, 12:54 AM   #712
Hanakuso
Got them from hardbrakes.com They are titanium and yeah they are for heat management. Suppose to keep the calipers cooler
Old 04-07-2013, 02:39 AM   #713
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Just another data point on fitment using the Sprint template; Enkei Fujin 17x7.5 with +40 offset has adequate clearance (gap in template was taken into account):
The Enkei Fujins will replace the stock wheels as the daily drivers.
I have some old 17x7 +42mm (if I remember correctly) offset Enkei Racing RS-5's I need to try the template with sometime (they are currently on my brothers Impreza 2.5 RS).
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
JRitt (04-19-2013)
Old 04-17-2013, 03:54 PM   #714
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Fitting my endurance kit tomorrow
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 11:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 03:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
