Old 04-04-2013, 08:38 PM   #1
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Road & Track by Öhlins For the FR-S/BRZ!
That's right, we have these beautiful Ohlins Road And Track Coilovers here in stock and ready to ship! I was really looking forward to getting these in, and to be honest, the pictures do not do them justice, they are simply gorgeous!
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
Ohlins Road & Track Coilovers Subaru BRZ 2013 / Scion FR-S 2013 - RallySport Direct
Mfgr. Warranty: 2 Years
Adjustable: Yes
Camber Adjustable : Front Only
Caster Adjustable: No
Damping Adjust Type: 34 Way
Damper Type: Inverted Mono Tube
Height Adjustable: Yes
Independent Height Adjustable: Yes
Spring Rate Front: 343lb/in
Spring Rate Rear: 343lb/in
Spring Rate Front Metric: 6Kg/mm
Spring Rate Rear Metric: 6Kg/mm
General Features
  • DFV (Dual Flow Valve)
  • Rebuildable
  • Corrosion salt spray tested (ISO 9227)
  • 2 year Limited Warranty
Front
  • McPherson Strut
  • Top mounts with camber adjustments
  • Coil Springs (60 N/mm)
  • Height adjustable
  • Spring preload adjuster
  • Single bleed adjuster ◦ Dustcovers
Rear
  • Conventional Shock Absorber
  • Top mounts
  • Height adjustable
  • Length adjuster
  • Dustcovers
Thanks,
Rick
RallySport Direct is offline
The Following User Says Thank You to RallySport Direct For This Useful Post:
Wolfking (04-09-2013)
Old 04-05-2013, 01:14 AM   #2
3 pedals n a stick
Drives: white out frs
pm price shiped to 94561
3 pedals n a stick is offline
Old 04-05-2013, 01:26 AM   #3
whataboutbob
AutoX-10/10ths every run
Simply beautiful. These are definitely on the top of my wish list for suspension upgrades!
Build thread:Here
whataboutbob is offline
Old 04-05-2013, 01:28 AM   #4
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
They look good shame they will cost me an arm and a leg.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline
The Following User Says Thank You to DriftEightSix For This Useful Post:
JackSmiley (04-09-2013)
Old 04-05-2013, 07:16 PM   #5
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
How would this compare to the kw v3s? and Wondering why the ohlins dont offer life time warranty while the kw's do?
vignesh is offline
Old 04-05-2013, 07:23 PM   #6
RallySport Direct
PM Sent
Yeah these things are simply amazing, and hard to believe but they look even better in person.
HAHA yeah they are a bit pricey for sure, but you do get what you pay for
Thanks,
Rick
whataboutbob (04-05-2013)
Old 04-05-2013, 07:35 PM   #7
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Pm price shipped to 94583.
Thanks
sent from a Galaxy SIII...
Overland'n'5thGEN is offline
Old 04-06-2013, 08:40 AM   #8
eckoflyte
Drives: Toyota 86 GTS
they installed the bust boots the wrong way for the coilover photoshoot. lol
eckoflyte is offline
Old 04-08-2013, 01:41 PM   #9
RallySport Direct
Thanks
Sent you a PM!
LOL looks like we mixed them up front to rear on that. Nice catch
Thanks,
Rick
Old 04-08-2013, 02:33 PM   #10
RallySport Direct
They are pretty close, both being super high quality and a top-tier suspension. The main differences is that the KW's will have independent compression and rebound adjustments, where the Ohlins will have a single adjustment. Also the Ohlins will come with the top hats where the normal KW V3 will not, and also the KW's are a twin tube, where the Ohlins are a mono-tube. So there are some big difference between the 2, but I don't think you could go wrong with either one. The Onlins may make a better, install, do some minor adjusting and be done, where the KW's will take more to dial in, but you can dial it in to exactly what you want out of the suspension.
It's a tough choice either way you look at it
Thanks,
Rick
Old 04-08-2013, 02:38 PM   #11
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
wow those are nice.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline
Old 04-08-2013, 07:25 PM   #12
vignesh
Engineer
vignesh's Avatar
I am also wondering, if the KW v3 come with a dust boot?
vignesh is offline
Old 04-09-2013, 07:15 AM   #13
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
debating between ohlins, kw v3, or eibach r2...tough choices.
JackSmiley is offline
Old 04-09-2013, 02:58 PM   #14
RallySport Direct
Originally Posted by f0rge View Post
wow those are nice.
Indeed! When these came in I spent way too much time just looking at them, they truly are a work of art!
It will have a dust boot integrated into the bump stop. But it does not extend as far as the boots on the Ohlins.
Yeah that is a tough choice for sure! I don't think you can go wrong with any of those, just depends on the price point you want for a set of coilovers. All 3 are great for the price though
Originally Posted by Subarudood View Post
uh not if you can afford the ohlins its not.
Thanks,
Rick
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 12:36 PM
Track and road comparo: FR-S/BRZ/GC/MX-5/GTI Sport-Tech FR-S / BRZ vs.... 0 03-01-2013 02:37 AM
Road and track vid DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-29-2011 10:00 PM
Road & Track: Scion FR-S Preview FutureFT86 Scion FR-S / Toyota 86 GT86 General Forum 3 08-29-2011 10:54 PM
Road & Track says 2013 Champion Scion FR-S / Toyota 86 GT86 General Forum 6 09-08-2010 12:33 PM
