Old 03-23-2013, 11:25 PM   #253
so26
Drives: Raven FR-S 6MT
Anyone know if there's away to get Torque Pro to display the Advance Multiplier?
so26 is offline   Reply With Quote
Old 03-24-2013, 01:03 AM   #254
Yruyur
Yruyur's Avatar
I thought it was just one of the custom pid settings
Old 03-24-2013, 08:22 AM   #255
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
Drives: 2013 BRZ Limited - Crystal Black
I was messing around with Torque yesterday morning.
0-60
I was able to get 6.7s with a little too much wheel spin out of the hole. Not bad.
Motor Trend got 6.4s.
Virtual Dyno
Also, the graphing feature- I was trying to graph whp vs RPM and it only lets you graph one axis using the Line chart instead of the scatter chart.
Otherwise the whp widgets seem pretty acurrate. I've been getting around 150whp at ~7K.
Does anyone have a better way to run the virtual dyno?
AM I THE MEANEST?
AM I THE PRETTIEST?
AM I THE BADDEST LOW DOWN MOFO AROUND TOWN?
SHO-NUFF!
ShoNUFF is offline   Reply With Quote
Old 03-27-2013, 02:18 PM   #256
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
0-60
Virtual Dyno
I gained the same results. I currently have an exhaust and a drop in filter. I was expecting a bit more whp. Are the whp calculated by the torque app just an estimate?
vignesh is offline   Reply With Quote
Old 03-27-2013, 02:23 PM   #257
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
I believe so. I also just installed my catback and drop in filter. The car definitely pulls harder now. Havent had a chance yet to play with toque again since.
I wish there was a better way to plot the HP and RPM on the graph besides using the scatter chart.
AM I THE MEANEST?
AM I THE PRETTIEST?
SHO-NUFF!
Old 04-01-2013, 07:56 PM   #258
zoomzoomers
zoomzoomers's Avatar
Awesome thread!
Old 04-05-2013, 11:36 AM   #259
Yruyur
Yruyur's Avatar
Ok time to find another pid. I'm pretty sure its sent via the ecu but not sure. I'm not sure if its going to be possible either to log it because the time that it is used....
Door locks... I figured if we identify the pid then ecutek should be able to add it to their tune. Doors could auto lock when you hit a certain speed.
Talked to visconti a looong time ago but said it would not be possible. But if we had the pid I think it may change things.
Any ideas or suggestions on how to capture?
Log, toggle door lock, followed by another log to compare??
Old 04-05-2013, 01:04 PM   #260
so26
I like the idea but wished the doors would unlock when the inside door handle is pulled.
The Following User Says Thank You to so26 For This Useful Post:
Yruyur (04-05-2013)
Old 04-05-2013, 01:18 PM   #261
jamesm
Could this be done with an ebay miniVCI clone and toyota software? i'll have one in a few days so i can answer if no one knows, but i know it can adjust pretty much everything else (alarm noise, drl's, etc).
Old 04-05-2013, 01:32 PM   #262
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Anyone else buying an android device just for the Torque App? haha
I ordered a used Android II A955 for $45 off of eBay with a BAFX BT OBDII reader for $30(shipped). Total was $75 vs buying a sub $250 flux system with my Unichip just for some sweet ecu readouts.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 04-05-2013, 02:05 PM   #263
Yruyur
Yruyur's Avatar
As far as I know the techstream does not give you the option to enable this feature.
Old 04-09-2013, 02:11 PM   #264
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
This is incredible. Does the car come oem with a legitimate AFR reader? I have an AEM wide band in my civic, and if I never have to order one for my BRZ that would be fantastic.
TouchMyHonda is offline   Reply With Quote
Old 04-09-2013, 02:21 PM   #265
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
I think nothing beats an independent gauge with realm time readings.
soros151 is offline   Reply With Quote
Old 04-09-2013, 02:34 PM   #266
zoomzoomers
First, let me apologize as I haven't had the opportunity to read this entire thread, but I'm a noob with this and in need of some help/pointers.
I just downloaded torque pro and purchased this reader
[ame="http://www.amazon.com/gp/product/B005NLQAHS/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive[/ame]
the reader seems to work fine, but I have some questions.
1. can I leave the reader plugged in at all times? It won't drain my car battery?
2. also when it's plugged in it seems to protrude into the foot well. Is that ok?
3. I've read that you can program PID's? How do you do that exactly? I saw the warning stating that if I do it incorrectly I can mess up my car.
Again, some help/guidance would be much apprecaited.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
