Old 04-04-2013, 03:26 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Looks like a great, simple product. I'd love to see some larger pics though.
Any ideas for something similar for the rear? I'm sure lower the rear that much isn't helping the camber curves much either...?
Old 04-04-2013, 04:20 PM   #16
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Robi,
I didnt see any sway bar / end link mods in your points assessment. Are you running stock bars and endlinks? I just got done putting the clubsports on and the sway bar is contacting the control arm on the front pass. side cause the end link is too long
GTM_Challenge is offline   Reply With Quote
Old 04-04-2013, 04:39 PM   #17
robispec
Drives: Black frs project
Im right in the middle of that....
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
CSG Mike (04-04-2013)
Old 04-04-2013, 05:14 PM   #18
celica73
For time attack, why not run the A series Hoosiers and get even more stick.
Old 04-04-2013, 05:19 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The A6s are more points than the R6s.
GTM_Challenge (04-04-2013)
Old 04-04-2013, 05:22 PM   #20
GTM_Challenge
Drives: On track
With NASA TT, you are limited to a certain number of points before being moved up into the next class. The base tire size for the TTD class is a 245. Running a 205 nets you 10 points back. The A6 compound is a 13 point tire.
Thus, a 205 A6 would be 13 points (compound) - 10 points (down sized tire) = 3 points.
An R6 compound tire is a +10 point compound. +10 (compound) - 10 (down sized tire) = 0 points.
It's all a strategy. While I'm sure Robi would like to run an A6, but he'd have to find an additional 3 points to do so.
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Old 04-04-2013, 05:40 PM   #21
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Just run TTU and don't worry about it.
neurokinetik is offline   Reply With Quote
Old 04-04-2013, 06:13 PM   #22
robispec
Been there done that second place at nationals twice...
Also no 205 A6 .....
Old 04-04-2013, 06:23 PM   #23
GTM_Challenge
Drives: On track
Could always run a 205/45ZR16
For those who aren't familiar with NASA TT points, you can see a classing sheet here - http://www.nasaproracing.com/rules/t...sification.pdf
Old 04-04-2013, 06:54 PM   #24
robispec
Ok.
215 stock wheel tire 41.5 lbs
245 RS3+9" wheel is 39.5 lbs
225 NTO1 +8" wheel 38.5 lbs
205 R6+8" wheel.......33.5 lbs
Dang thats THIRTY TWO LBS UNSPRUNG ROTATING WEIGHT LIGHERT THAN STOCK
Old 04-04-2013, 08:03 PM   #25
coyote
coyote's Avatar
Drives: Slowly
Originally Posted by robispec View Post
Ok.
205/45R16 R6 on 16x7 wheel ... 29.6lb
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
robispec (04-04-2013)
Old 04-04-2013, 08:05 PM   #26
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Robi, what exactly do you have going on in that control arm?
SubieNate is offline   Reply With Quote
Old 04-04-2013, 08:22 PM   #27
robispec
We machine a custom monoball shell and press it into the stock lower control arm. This gets your roll center corrected for drops past the 15mm recomended. The bump steer corrects the steering for the same condition.
Old 04-04-2013, 08:23 PM   #28
robispec
I LIKE IT!
Nasa High Speed Autocross @ VMP 4/21/2013 Sponsored by Ptuning Events@Ptuning Southeast 5 04-22-2013 11:17 AM
AZ Track days via NASA gmookher Southwest 0 09-04-2012 04:20 PM
Took her to the NASA Auto-X at VMP today! (video inside) xjohnx Tracking / Autocross / HPDE / Drifting 4 08-27-2012 09:54 AM
NASA-x at MIR with video about350 Tracking / Autocross / HPDE / Drifting 2 08-11-2012 10:42 AM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 09:13 AM
