Old 04-03-2013, 03:03 PM   #211
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Originally Posted by OICU812 View Post
So realizing it is "subjective" it seems that if a poll were made would I be correct in assuming MOST are in fact eliminating the sound generator to the cabin? Has anyone done any interior DB testing to know how much less noise etc this changed inside the cabin when eliminating the noise generator? To me it makes sense to have as little noise as possible artificially introduced to cabin, but hey I don't own the car "yet". Learning alot here...
I do like as others have stated from a "looks" perspective how a CAI like Injen, and Greddy etc clean it up, the Injen version "looks good" but sounds to be that is about it? lol.... I also now know that doing a tube and good quality filter does same if not more. What I do not know is if I were to get the Zeta or AVO tube if I should be going with or without the stock/noise generator option cause I honestly do not know how much actually noise introduction there is from this part....?
Since I have the Injen on my car still, I'll chime in.
Honestly, it does looks pretty damn good and certainly gets compliments at shows. Also, it sounds fantastic. It is MUCH louder than the factory air box with the generator and has a much deeper tone that is common with aluminum intakes.
Now for the reality check on the Injen and most of the other short ram intakes... Most of them, (Injen included) only are able to make more power by reducing the speed of the airflow into the engine giving the ECU a false reading. The ECU in turn leans out the mixture just slightly but enough to give a little more "pep". Nothing more, nothing less. Also, the Injen takes air from the engine compartment which can get pretty warm so it is not a CAI. Not a big deal when moving down the road but you will be sucking hot air when stopped.
All in all, I do "like" my Injen but down the road, I will be changing it out for the Perrin CAI or FA20 CAI.
Scott
naikaidriver is offline   Reply With Quote
Old 04-03-2013, 03:47 PM   #212
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Heres a quick overlay of how my intake performed..stock w/hksfilter vs coldair vs coldair tuned..not that great with photoshop so bare with me but as u can see cold air faired alot better than just a drop in filter but it seems like stock pulled a little better up top for somereason..this is with AMR coldair
brichard0625 is offline   Reply With Quote
Old 04-04-2013, 12:47 AM   #213
JeremyClarkson
JeremyClarkson's Avatar
Drives: Raven FRS 2013
Originally Posted by jwjknorr View Post
I have a aem, it is enclosed and draws air from the outside. My butt dyno says i got some gains up top , and i love the sound. Defiantly would recommend.
did you tune it?
JeremyClarkson is offline   Reply With Quote
Old 04-04-2013, 08:16 AM   #214
FR-S Matt
Even with the major difference in the low end, it looks better across the band than the other options. I would take that with a slight top end hit. True cold air designs are really nice.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
