Old 03-31-2013, 11:03 AM   #99
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Huehuecoyotl View Post
Whose radiator?
I almost pulled trigger on Robispec's radiator
Old 03-31-2013, 11:09 AM   #100
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
so you're running the $6,000 kit? if so i can't wait to see your numbers to help me justify the cost
lbroskee is offline   Reply With Quote
Old 03-31-2013, 11:12 AM   #101
Sportsguy83
Drives: Limited BRZ
well, the difference between stage 1 and 2 is 7 psi actuator, exhaust, tune MAP sensor.
I have all components mentioned above for stage 2 but added supporting modes to go 7+ psi.
Video added to post 96 and first page.
Old 03-31-2013, 11:15 AM   #102
lbroskee
lbroskee's Avatar
kinda sux if you already have a front and overpipe since it includes those, but not a BOV, tuning components other then jus the tune file
Old 03-31-2013, 11:23 AM   #103
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
The vaseline jar cracks me up btw...
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Sportsguy83 (03-31-2013)
Old 03-31-2013, 11:27 AM   #104
Sportsguy83
Drives: Limited BRZ
I already had OP/DP, you can get stage 2 components minus exhaust
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lbroskee (03-31-2013)
Old 03-31-2013, 01:49 PM   #105
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Fist start video:
And here's the video!!
love the sound!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Old 03-31-2013, 02:18 PM   #106
Huehuecoyotl
you had battery disconnected when FP was going in, you check ALL your fuses? checked links under black box in hood?
Old 03-31-2013, 02:23 PM   #107
Sportsguy83
Drives: Limited BRZ
Yes, battery disconnected. I hear the pump priming when I set ignition to ON. Haven't checked fuses, but again can clearly hear the pump priming.
(Thanks for the tips, really appreciated and all good points to check)
Old 03-31-2013, 03:32 PM   #108
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
When can we expect some more video, dyno etc. I'm curious how the stage 2 numbers will come out with that interesting intake setup and the full exhaust.
The BOV and turbo seem a bit more audible with the unrestricted airbox too sounds great!
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 03-31-2013, 03:59 PM   #109
Sportsguy83
Drives: Limited BRZ
I hope soon, but can't promise a date. I'm still working a stupidly crazy amount of hours.
Old 03-31-2013, 04:09 PM   #110
buditjoenawan
Drives: Very very slowly
David,
7psi wastegate spring is a good thing! You have 93 octane gas in Florida right? Maybe even 94 in some places? I would LOVE to see the turbocharger operating in its highest efficiency island, but that would require a LOT of ancillary support components. I know you've said that you're going beyond 7psi, but pray-tell, would you come close to the efficiency pressure ratio of the turbocharger?
If anyone is curious, the highest efficiency island on this turbo should be around 13psi or thereabouts. :-)
- budi
buditjoenawan is offline   Reply With Quote
Old 03-31-2013, 04:15 PM   #111
Sportsguy83
Drives: Limited BRZ
Originally Posted by buditjoenawan View Post
David,
- budi
My goal is not quite that high, but will definitely be 8+ . I get 93 octane here in FL, honestly don't know exactly how good it is but it seems pretty good.
Old 03-31-2013, 04:23 PM   #112
buditjoenawan
Hmm, 8+ is rather vague. Would you venture beyond stock clutch/injectors/pump?
I'm rather curious as to the chassis' ability to handle the increased power. In my FD, 260whp on street tires (265s) on the street was a handful when not going straight. And I think the FD and the FRS/BRZ are pretty similar in weight.
-budi
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
