Old 03-30-2013, 12:45 AM   #85
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Need update and more pictures.
I've got photos and videos. It's been two really intense days. I haven't rest much. Have had some issues with some parts (not turbo kit). Flashed it and started it up for a good ten minutes. Took video but the sound through my phone is awful, like I cannot believe how awful it sounds.
Videos, pics and all will be coming probably by Monday. I still need to install fuel pump. Clutch will have to wait a bit.
I'm spent. Back at it tomorrow AM!
Sent from my HTC One X using Tapatalk 2
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
akuhei (03-30-2013), Draco_PR23 (03-30-2013), lbroskee (03-30-2013)
Old 03-30-2013, 12:36 PM   #86
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
curious to see the intake setup for this. seen some use the OEM box while others remove washer bottle (that seems lik it'd get annoying)
lbroskee is offline   Reply With Quote
Old 03-31-2013, 09:57 AM   #87
Sportsguy83
Drives: Limited BRZ
The stock washer bottle works. I installed the Perrin intake.
Old 03-31-2013, 10:01 AM   #88
Sportsguy83
Drives: Limited BRZ
Ok, I'm not dead!! Install is complete. It took three days, because I wanted to do some supporting mods. That plan came out with mixed results. I could not use the radiator I had ordered, and the last modification I did was install a bigger fuel pump. After the fuel pump install, the car does not want to start. I can hear the pump prime, but the car just cranks and does not go.
I tried switching the cables around but still does not start. I will be looking into this later in the week.
The install is not hard but time consuming. The big parts are very easy, finishing it up and taking care of all the little details is a bit more involved. It sounded AMAZING when I fired it up. I could not do much more then Rev it up a couple of times and had it running for about 10 minutes.
I will add pictures in the next few posts.
Old 03-31-2013, 10:04 AM   #89
lbroskee
lbroskee's Avatar
thats odd that the fuel pump isnt letting it start if wired correctly. did u upgrade your injectors too?
Old 03-31-2013, 10:11 AM   #90
Sportsguy83
Drives: Limited BRZ
Yeah, but I fired it up with injectors, new flash and all. The car was already running like it should and we decided to do the pump and after the pump, it hasn't started again. I hear it priming when in the ON position, but the car won't start.
Old 03-31-2013, 10:19 AM   #91
lbroskee
lbroskee's Avatar
that is really weird if everything else should support it and its connected correctly. at that point it has me thinking it could just b defective or theres a kink or something stupid
Old 03-31-2013, 10:32 AM   #92
Sportsguy83
Drives: Limited BRZ
This is one one of the gauges, I got the cluster pod with two gauges, Will take a pic later of it installed, it looks so freaking awesome!:
This is the header wrapped, with Turbo Blanket:
Nameless exhaust tips after full "header" back 3" exhaust is installed!
Sorry for the blurry pic, I think I need to get checked....
Perrin Intake:
Engine Bay taking shape:
Oil pump and O2 sensor for the AFR gauge:
New downpipe:
New Midpipe (see the bumper photo bombing and laughing about it!!):
Small High Flow Cat:
Flashing:
Favorite company ever... Hands down, I wanna marry them:
The Following 5 Users Say Thank You to Sportsguy83 For This Useful Post:
Chewie4299 (04-20-2013), Draco_PR23 (03-31-2013), NickFRS (04-26-2013), nix (04-28-2013), ScionFamily (03-31-2013)
Old 03-31-2013, 10:35 AM   #93
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Ok, I'm not dead!! .................................
...................After the fuel pump install, the car does not want to start. I can hear the pump prime, but the car just cranks and does not go.
Good youre not dead. I dont agree with all your posts at times but never wanted to see ya die...What radiator did you order?
Awe, shucks, wish you kept it without supporting mods and did it slowly
does putting the old one in make the car run?
Have you tested for actual pressure under the hood?
Not unusual to crank it a bunch after a FP on most cars, but Im sure you know that
got enough gas?? Havent done one yet on this car, so good to see what there is to learn from your endeavors.
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Sportsguy83 (03-31-2013)
Old 03-31-2013, 10:45 AM   #94
Sportsguy83
Drives: Limited BRZ
I thought about it twice, and kept the stock radiator, but the process in between changing it/ keeping stock took a lottt of time off our hands.
I have not tested pressure, one odd thing is that either after first install ir after swapping the cables, I never got pressure in the line when removing the pump assembly. Reinstalling the OEM one would be a lst resort as you need to cut and solder cables and I would need to do that backwards. Also, before installing the new pump the car was running, so I'm completely sure it has to do with either the pump or how its installed. I hear it priming, but no start.
I have 3/4 tank and when you actually open the tank it seems like its full! I cranked it quite a few times, I am going to remove it and redo the install. I honestly did not like the offerings available but said what the heck... the ar is torn apart might as well do it, but after trying it I still don't like the offerings. I wish it was more "drop in" then it is. The new pump does not sit flush in the canister like the OEM pump.
Old 03-31-2013, 10:50 AM   #95
lbroskee
lbroskee's Avatar
looks great, def the cleanest kit out there. just hope it makes more then the 230 whp they have on their dyno b/c i'd love a clean setup like this and still b able to make my ~290 whp goal.
btw, no engine cover? did it fully break now?
Old 03-31-2013, 10:52 AM   #96
Sportsguy83
Drives: Limited BRZ
Fist start video:
[ame="http://www.youtube.com/watch?v=oNXE5A4aT1I"]First Startup after BRZ AVO Kit install. - YouTube[/ame]
The Following 9 Users Say Thank You to Sportsguy83 For This Useful Post:
AVOturboworld (03-31-2013), boarder1995 (05-03-2013), Draco_PR23 (03-31-2013), fender9530 (04-05-2013), Gopherboy6956 (08-21-2013), raul (03-31-2013), Sonolin (05-15-2013), TRD_07 (04-08-2013), vubaru (03-31-2013)
Old 03-31-2013, 10:53 AM   #97
Sportsguy83
Drives: Limited BRZ
hahaha I bought a blue JDM one, just haven't fitted it yet until everything's done. I have stage 2+, not stage 1
Old 03-31-2013, 10:59 AM   #98
Huehuecoyotl
Trust me I am VERY eager and curious to do the same FP and injector upgrades.Not the 1st time hearing this, I need this to be be a better fit kit for me to go tracking it at triple digits speeds, or I need to better understand the fix, iirc it was shortening a line or nipple or something?
I dont see items that are as good as stock or fit as good, so I think this needs to be addressed. You spend your hard earned money.
I'm a lab rat and went into it knowing so. Your install should be wham bam thank you ma'am if you ask me. Apply slow gentle pressure to your vendor/pump maker,this aint your fault.
The vendor may not be aware of your issue, but if this is a known install issue, it needs to be addresses before others encounter this issue.
Whose radiator? You have the Visconti pump?
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
