Old 03-31-2013, 11:50 AM   #43
Frs300
Frs300's Avatar
Drives: Pile of junk
when it happened i could hear the bov loud and clear.
Tansey that could be..cause only the top of the motor appears to be messed up.might be a different story after its opened up. all of the damnage is under the intake
Frs300 is offline   Reply With Quote
Old 03-31-2013, 11:54 AM   #44
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
so that sounds like a stuck wastegate...melted line, wrong spring, whatever caused it to not actuate to the position it needed to being at the right place and right time
neither here nor there really, if it wasnt setup right I dont know whose call it was to let you drive it...
keep your head up, its just parts
its a risk we're all taking, sorry this happened!
The right hing to do is a complete tear down even if it appears like damage is limited to one area, all parts need to be checked out that this point you dont know what else is scored etc.
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
cb7tuner (04-13-2013)
Old 03-31-2013, 11:55 AM   #45
Frs300
Frs300's Avatar
if i was worried about the car getting messed up i would have kept it stock
The Following User Says Thank You to Frs300 For This Useful Post:
Spd229 (04-16-2013)
Old 03-31-2013, 11:57 AM   #46
mad_sb
Drives: 2013 Asphalt FR-S
i went into this knowing it would void the warranty. didnt matter if toyota installed it or some other shop...they should still stand by the work they did and offer some sort of fix. it shouldnt have blown up at 7psi if installed correctly.
done using maf
So, you said the oil an coolant are still in the block.. are you sure the motor let go? If it had a bad boost leak it would run but not make power and if they boost leak eventually became a coupler blowing off under pressure you would hear a loud pop followed by the motor dying..... I could not tell from the pics if the block was perforated or if there was just coolant everywhere, like from a line bursting or something of the sort..
Never mind, i see the hole now...
Old 03-31-2013, 12:02 PM   #47
Frs300
Frs300's Avatar
if you look at first pic under the hose clam you can see the hole. second pic by the alternator bolt oth side of it and under it. third pic with the ic pipe you can see the hole again by the pully to the left of it by the bolt. blew off the dust cap for the trans and another hole under the catch can.
EDIT: so is that the block around that area then?
Old 03-31-2013, 01:47 PM   #48
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
was just normal driving took off in first spun the tires regained traction shifted to second got to about 6k rpms or so and the motor shut off with a loud bang.
I wouldn't describe this as normal driving. Especially without a wide band or a boost gauge installed. You are just asking for trouble without them.
MattF is offline   Reply With Quote
Old 03-31-2013, 01:50 PM   #49
Frs300
Frs300's Avatar
i was taking the car home to install a aem failsafe/wideband but didnt make it that far obviously
Old 03-31-2013, 01:53 PM   #50
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I think its safe to say that a boost gauge and wide band are necessary when having a 3rd party install a turbo kit on the car.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 03-31-2013, 01:59 PM   #51
Frs300
Frs300's Avatar
i would have to agree 100%
Old 03-31-2013, 02:05 PM   #52
xwd
I would say it's necessary no matter who installs the kit. You never know when parts might fail, like the wastegate vacuum line melting like others have mentioned...
Old 03-31-2013, 02:07 PM   #53
sw20kosh
Drives: 2013 Black FR-S
BOV can't cause a boost spike. It's only job is to let out pressure during throttle lift.
The wastegate can cause a boost spike. It's sole purpose is to open when it senses the correct pressure in the charge side. If it doesn't sense that pressure for what ever reason or if it has the wrong spring....bad things happen.
Bad fuel pump install could have caused lean state.
A dyno tune/boost gauge (at the minimum) should be done before boosting. This allows you to asses the system's functionality in a controlled/safe environment. Every install I have done on my own car never came out 100% due to the complexity and the shear number of parts that goes into these kits. All mistakes were caught before or on the dyno.
Hope toyota can do something for you. Good luck
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
Brzzee (03-31-2013), mad_sb (03-31-2013), SloS13 (03-31-2013)
Old 03-31-2013, 02:08 PM   #54
xwd
It's hard to see the hole. Where is it in relation to the flywheel inspection hole? The one which is plugged with the rubber plug. Either way that's not where the heads are located, they are on either side of the block, that's the block.
Old 03-31-2013, 02:12 PM   #55
sw20kosh
Hard to tell from pics.
Yep, the heads are located on the right and left side of the engine.
Old 03-31-2013, 02:13 PM   #56
Frs300
Frs300's Avatar
its all under the intake area. and out to the sides of it a little bit....i will have better pics tomorrow and will know for sure without a doubt.
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 10:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 09:24 PM
