Old 03-22-2013, 03:16 PM   #71
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
those look like the grazo tails. But you could tint or spray them to look like that.
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 03-22-2013, 10:13 PM   #72
mact
Drives: 13 GTI
Anyone with a silver car do this mod? Pics?
mact is offline   Reply With Quote
Old 03-23-2013, 12:16 PM   #73
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Originally Posted by Cody View Post
Not sure if you have seen it on white frs yet but this may help =]
also i highly recommend using a hot knife or soldering iron under the vanity gaurd, and dremel the rest. And be careful where the gasket goes. I bent the rim where it sits a tad and it let water in...had to take them back apart clean and reseal, plus make a better gasket.
Looks real good on whiteout!
Are there pictures for the inbetween steps? It is kind of hard to visualize what I need to do with just writing.
Chinadian is offline   Reply With Quote
Old 03-24-2013, 12:39 AM   #74
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
If anyone else can post pics of them chopping up the lights i will do this.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-27-2013, 03:35 PM   #75
justintime69
justintime69's Avatar
Drives: 2013 Scion FR-S Argento
I would love to do this to my fr-s, what happen to all the pictures, they are all "x" out. Love to see them so I can see what to do.
justintime69 is offline   Reply With Quote
Old 03-28-2013, 03:19 AM   #76
Ponwh
Drives: 4 wheels
Half of the pictures arent working, please reupload
Ponwh is offline   Reply With Quote
Old 03-29-2013, 05:37 PM   #77
GenesisAZ
Drives: 2013 Hyundai Genesis Coupe 2.0T
The facebook pictures aren't showing, could someone side load them for those of us who want to see them? (I am helping Yruyur with his tail lights)
GenesisAZ is offline   Reply With Quote
Old 03-29-2013, 07:21 PM   #78
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
Sw20kosh if I sent you my taillights could you do this for me? I'd be willing to pay a good price for these! I'm not very good at this kind of stuff and really like this rather than tinting them. I also have a raven black fr-s
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Old 03-30-2013, 09:30 AM   #79
jwjknorr
Drives: FRS 2013
im just waiting on the pics being fixed before i do this. I have bought all materials and dremel to accomplish
jwjknorr is offline   Reply With Quote
Old 03-30-2013, 10:34 AM   #80
mxsled
mxsled's Avatar
Drives: Audi A3 2012
If youre doing this mod,Be sure to replace the gasket
I messed up my stock taillights because of that!
mxsled is offline   Reply With Quote
Old 03-30-2013, 01:45 PM   #81
Cody
Cody's Avatar
Drives: White Fr-S
There is a guide in the diy section of the thread. On my phone or id link it for you.
One guide is for soldering iron and one guide is for dremel. I highly recommend that you only solder under the vanity gaurd. The dremel is wayy faster.
Also i found that with the silicon sealant it was hard to seal it properly. So i used 3m window weld. Glopped it On and then used a piece of metal to smooth it out, let it dry and repeated.
This isn't and overly difficult mod as long as you patient and careful. To do both tail an the heads it probably took me around 40hrs, but thats including drying times and reassembly.
And if you mess the lenses up at all, get and of the silicon or window weld on, meguiars plastx works wonders!
Goodluck!!!!
Cody is offline   Reply With Quote
The Following User Says Thank You to Cody For This Useful Post:
Chinadian (06-02-2013)
Old 03-30-2013, 01:47 PM   #82
Cody
Cody's Avatar
Drives: White Fr-S
The stock gaskets should be replaced regardless. They are crap....
I am considering using weather stripping around the vanity
bc i made gasket and siliconed them down. No water in the rain when sitting still, but if im driving i get a little
Toyota dropped the ball with the design of this area imo.
Old 03-30-2013, 02:03 PM   #83
mxsled
mxsled's Avatar
I do the same for my news aftermarket tails lights....don't want to have condensation in them...
Old 04-01-2013, 12:45 PM   #84
Cody
Cody's Avatar
Drives: White Fr-S
Yah. Im considering weather stripping around the lid of the trunk or around the vanity gaurds to make it water tight. I made the new gaskets but when driving at speeds above 45 in the rain i stillget a little moisture in my driver side light.
Smoking or Redding BRZ/FR-S Tail Lights DarrenDriven DIY (Do-It-Yourself) Guides 596 02-20-2021 10:11 PM
Black Housing Tail Lights (FR-S) sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 20 04-13-2016 11:38 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
opening tail lights? JollyJON Cosmetic Modification (Interior/Exterior/Lighting) 34 07-23-2012 04:35 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
