Old 03-29-2013, 03:27 PM   #15
FR-S Matt
I am not experiencing this and I am in Texas with the Perrin CAI, but my filter is outside of the hood. I know it gets super hot here which is why I chose this intake.
The Following User Says Thank You to FR-S Matt For This Useful Post:
BuBlake (03-29-2013)
Old 03-29-2013, 03:28 PM   #16
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Originally Posted by Chewie4299 View Post
Can Torque show IAT and Oil Temp? I see outside air temp and coolant temp in your pic.
Both of those, yes. That's not my pic, just one I found off google. I have mine setup a little different. I have a page for "eco" which has an instant MPG graph, avg mpg, fuel % remaining, amount of fuel used (since turning on the app), outside air temp, and distance to empty (often incorrect). Then the other page is like "performance" with tachometer, throttle position, air fuel ratio, air intake temp, voltage, and exhaust temp. You can arrange the dials, graphs and displays pretty much any way you like and you have multiple pages to display them on.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 03-29-2013, 03:29 PM   #17
cfusionpm
Originally Posted by BuBlake View Post
So this will show intake temperature? I do not see it in the picture, just an ambient.
I'll double check it right now and take a screen shot of the phone. That one in the pic is just one I pulled off Google.
The Following User Says Thank You to cfusionpm For This Useful Post:
Old 03-29-2013, 03:34 PM   #18
reeves
I have all of those showing on mine's.
The custom "Fuel Remaining" PID works great too.. VERY accurate (from 0.5 to 12.5 gallons)! I love being able to run my tank almost dry, without worrying I'll run out of fuel.. so I can fill up with E85
The Following User Says Thank You to reeves For This Useful Post:
Old 03-29-2013, 03:44 PM   #19
cfusionpm
How do you get engine oil temp? It doesn't show up on mine. Could be an FR-S/BRZ thing? As far as I know, it can display anything the ECU spits out through the OBDII and engine oil temp is inactive. Just made a quick new page and drove around the block to snap this:
Old 03-29-2013, 03:46 PM   #20
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
ERMAGERD! Awesome! I must have... Would be Batman.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 03-29-2013, 04:00 PM   #21
reeves
Not sure if 'inactive' is the right word.. the OBDII connector/reader just didn't know "how" to look for it apparently.
But, as usual, our fellow FT-86ers figured it out! http://www.ft86club.com/forums/showt...300#post588300
You'll have to add a CUSTOM PID to see it though.. PLEASE read post #3 in that link to figure out how to do that.
Thanks to @andreyiv for the Oil temperature PID... and to @developer for the [more] accurate 'Fuel Remaining' PID.
cfusionpm (03-29-2013)
Old 03-31-2013, 10:11 AM   #22
Kodename47
Kodename47's Avatar
Drives: UK GT86
I figure that mine must run at least 10 degrees hotter than ambient after sitting at idle.
You do realize it will likely be double that, if not more. I assume you mean deg. C? I've posted plenty of graphs for IATs and I intend to test on a mates Injen to prove how bad the heat soak is.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-31-2013, 10:49 PM   #23
BuBlake
BuBlake's Avatar
I meant in Fahrenheit, but I really have no idea. I have ordered the Bluetooth adaptor and found a few apps similar to torque for my iphone, so should be able to know for sure pretty soon!
Old 04-01-2013, 05:45 AM   #24
Kodename47
Kodename47's Avatar
Drives: UK GT86
The BT devices only work on Jail broken iOS phones or you'll need a WiFi one (you may already know this so tell me to shut it).
There are some graphs on here when I tested the OEM box without the snorkel. Ambient was 8, best IAT was high 20s and at idle hit 44. That's all celcius. As soon as the snorkel was replaced I've yet to see those temps again. Massive contrast in the way the car felt, started bogging at low RPM and just was generally horrible to drive. Back to stock-ish and all is well again.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2013, 10:08 AM   #25
BuBlake
BuBlake's Avatar
Ah crap, didn't know it had to be jailbroken for BT devices! Are you sure? I use several audio BT devices with my iphone... Connects to the stock headunit of course. I will probably just jailbreak it then... Or maybe I'll try to find a cheap Android device that will be dedicated to the torque app.
Interesting that snorkel removal had such a negative effect for the stock box. I didn't really notice a difference with the Injen.
Old 04-01-2013, 08:49 PM   #26
Turdinator
Señor Member
Turdinator's Avatar
Living in Melbourne we have just gone from summer with temps of 30 - 40c (85 - 105f) to Autumn (Fall) temps of 12 - 20c (55 - 70f) and I am running a stock airbox and snorkel with a perrin drop in and silicon tube. I can definitely feel an improvement in power and responce on the colder days. I don't have data logs or dynos to back this up tho.
1974 TA22 Celica
2013 86 GT
Old 04-01-2013, 08:59 PM   #27
zoomzoomers
zoomzoomers's Avatar
Better yet, instead of a ~$160, wired accessory, you can get a $20 wireless bluetooth OBDII adapter and the Torque app for any Android phone (I think iPhone has some kind of app too). Same thing (and more, actually) for 1/8 the cost.
https://play.google.com/store/apps/d...l.torque&hl=en
How easy, or difficult, is it to install that OBDII sensor in the vehicle? If it isn't too difficult, I might buy that torque app and that adaptor. Is there a DIY?
Old 04-01-2013, 09:16 PM   #28
cfusionpm
1. Locate OBDII sensor plug in your car (in the footwell, under the steering wheel, directly back from the gas pedal).
2. Insert OBDII sensor into plug.
3. Pair sensor to phone or device (usually password 0000 or 1234).
4. Use Torque app.
That's all there is to it.
zoomzoomers (04-01-2013)
Who says we need more horsepower? LeeMaster Scion FR-S / Toyota 86 GT86 General Forum 36 01-11-2013 12:05 PM
Bolt on 6 horsepower for about $50. MillersOilsUS Engine, Exhaust, Bolt-Ons 29 01-10-2013 09:53 PM
6 horsepower, 4 lb-ft from an oil change MillersOilsUS Mechanical Maintenance and Tools 1 01-03-2013 12:21 PM
ft86.com has some serious horsepower! MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 2 03-22-2012 08:45 PM
