Old 03-29-2013, 10:37 AM   #1
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Garbage inside my hood???!!!
I opened my hood yesterday to check up on my oil. And I find a TON of garbage, newspapers, mcdee cups and what not, but it was A LOT. I filled up 3 shopping bags that you get from target. I couldnt get a picture cuz right went I saw it I went into panic mode. Can someone open the hood while the car is locked?
Car did not go on fire, thank god. But it did burn a bit of the fire resistant foam on the hood.
I live in an apartment and the car is parked on the ground level so anyone has access to it.
I've attached picture on how it looked like.
Most of the garbage came from this pine tree. The one with needle like branches.
UPDATE APR 3
Im looking for the rubber cover on top of the alternator. I went to the dealership today and they can't find it(looked for 15min). Does anyone know the part#?
Also, the animal decided to eat some of the hood insulation off. Should I replace the insulation, it cost $50.
ArKiTeCkT is offline   Reply With Quote
Old 03-29-2013, 10:41 AM   #2
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Animals do this. Usually rodents but I suppose a cat could have as well.
Did this happen while you had it stored over the winter? Chances are something Hibernated there.
Starscream15 is offline   Reply With Quote
The Following User Says Thank You to Starscream15 For This Useful Post:
ftc~brz (03-29-2013)
Old 03-29-2013, 10:44 AM   #3
ArKiTeCkT
ArKiTeCkT's Avatar
funny thing is I use it everyday and last time I checked my hood was 2 weeks ago. BTW Its around 0-10 degrees celcius
Old 03-29-2013, 10:48 AM   #4
andrew20195
I'm betting a rodent of some sort made a nest in your nice warm engine bay, especially considering the cold temperatures. I suggest putting rat poison around your car if feasible, before they chew up something important.
andrew20195 is offline   Reply With Quote
Old 03-29-2013, 10:56 AM   #5
ArKiTeCkT
ArKiTeCkT's Avatar
Will rat poison kill squirrels? I normally see a lot of them in my building as well as cats.
Old 03-29-2013, 11:16 AM   #6
Saab2Frs
Drives: 2013 Hot Lava Scion FRS
This looks photoshopped to me.
Saab2Frs is offline   Reply With Quote
The Following 5 Users Say Thank You to Saab2Frs For This Useful Post:
2pt5RS (04-03-2013), flippy (04-03-2013), Ganthrithor (03-29-2013), LeeMaster (03-29-2013), Linniea (03-29-2013)
Old 03-29-2013, 11:28 AM   #7
Foobar
SLO NO MO
Foobar's Avatar
LOL it's definitely shopped, but I think the OP was just illustrating what it looked like before he cleared it all off.
Old 03-29-2013, 11:30 AM   #8
SloS13
Drives: 2013 FR-S whiteout
As a squirrel owner, I implore you not to use poison.
SloS13 is offline   Reply With Quote
The Following User Says Thank You to SloS13 For This Useful Post:
Craig (03-30-2013)
Old 03-29-2013, 12:09 PM   #9
boead
boead's Avatar
9mm?
boead is offline   Reply With Quote
Old 03-29-2013, 12:09 PM   #10
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Total photoshop. Edges of the debris are way too straight. WTF was OP thinking?
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 03-29-2013, 12:10 PM   #11
FRiSson
Drives: FR-S MT
Extremely symmetrical nest building. I think you need to call the Smithsonian.
FRiSson is offline   Reply With Quote
The Following 2 Users Say Thank You to FRiSson For This Useful Post:
husker741 (03-29-2013), Sportsguy83 (03-31-2013)
Old 03-29-2013, 12:13 PM   #12
DieselxIndustry
Drives: 2013 Firestorm FR-S
Poison fast because I had animals doing that to mine and they chewed right into my main engine harness causing a 3700$ repair
DieselxIndustry is offline   Reply With Quote
Old 03-29-2013, 12:14 PM   #13
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
check for rodent intrusion
Jesse is offline   Reply With Quote
Old 03-29-2013, 03:40 PM   #14
FR-S Matt
Copied a picture of this and left it in a square? That's not even photoshop, that's Windows Paint.
The Following User Says Thank You to FR-S Matt For This Useful Post:
TRD air filter inside! Silverdub Engine, Exhaust, Transmission 43 05-15-2015 05:19 PM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 03:47 AM
Water inside the car? YourFearlessLeader Issues | Warranty | Recalls / TSB 10 12-16-2012 05:55 PM
Hamster inside? ParangWala Off-Topic Lounge [WARNING: NO POLITICS] 9 09-03-2012 01:55 PM
I just died inside. DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 62 07-02-2012 09:51 PM
