Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 08-15-2012, 11:11 AM   #57
john_jre
Drives: Toyota 86 Tornado Grey
waas it difficult to undo the doors?
john_jre is offline   Reply With Quote
Old 08-15-2012, 05:58 PM   #58
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
@WTF How are the tweeters wired up stock? Are they splits off the 6.5's, or do they run to the head unit directly?
Gir is offline   Reply With Quote
Old 08-15-2012, 06:24 PM   #59
gosaints420
gosaints420's Avatar
Drives: x-runner
I remember reading awhile back that those extra holes in the dash are there to make it easy to install a role cage.
gosaints420 is offline   Reply With Quote
Old 03-13-2013, 10:03 AM   #60
vault
86TUP
Drives: 86 GT
digging up an old thread here, but i recently installed an aftermarket headunit using a harness supplied by a car audio specialist.
once installed, the front tweeters dont work and it sound like the sound has shifted to the door and only very slightly to the rear (seems only acoustics are coming out of the rear).
Whats going on
vault is offline   Reply With Quote
Old 03-13-2013, 10:22 AM   #61
BRZRR
Drives: Black BRZ
Is it a harness or an adapter?
A 2 way split speaker system will use a crossover at some point.
Did you just connect to a left and right channel or multiple left and right channels?
BRZRR is offline   Reply With Quote
Old 03-13-2013, 10:36 AM   #62
vault
86TUP
Drives: 86 GT
my bad... its an adapter... not harness.
standard 6 speakers but with a Sony 2din head unit
Old 03-13-2013, 10:41 AM   #63
vault
86TUP
Drives: 86 GT
could it be that the fronts and rears are the other way around on the adapter?
What colour are the factory fronts wires?
the adapter was pretty much plug and play....
Old 03-14-2013, 01:27 AM   #64
vault
86TUP
Drives: 86 GT
checked wiring.. all seems correct. any suggestions?
Old 03-14-2013, 11:28 PM   #65
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
im a noob when it comes to ICE, but was thinking of fitting one of those slim active subs under the seat....something like this: http://www.ryda.com.au/Fusion-CP-AS1...p/cpas1080.htm
Im not expecting massive improvements, but just a little more bass perhaps...so worth it or waste of money?
Will also be changing the front speakers to a decent one...would any aftermarket 6.5" speaker be direct fit on the door? and since most aftermarket speakers are already 2-way, would you recommend ditching the front tweeters or leave them on?
Fizz is offline   Reply With Quote
Old 03-28-2013, 06:15 PM   #66
scottrichardson
Drives: Toyota 86 GTS White
It would certainly increase bass response, seeing as the stock system is poor. I would go as far as saying the stereo is the only real low point on the GTS for me. I'm waiting a bit, but will definitely be replacing all the front speakers and head unit. Along with adding a sub or two.
I'm just not sure what head unit to buy as it needs to be double DIN - and I'm hesitant to have someone install it all because last time I had that done in my old car they left marks all through the car
At this stage I'd like to go Pioneer - their high end splits look the goods.
Toyota 86 GTS Pegusus White
scottrichardson is offline   Reply With Quote
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
Accidentally blew the dash speakers bladesamurai Electronics | Audio | NAV | Infotainment 15 06-20-2012 09:25 AM
Installed new in-dash, lost sound from door speakers Nitro Electronics | Audio | NAV | Infotainment 2 06-04-2012 08:53 PM
Speakers Audi Scion FR-S / Toyota 86 GT86 General Forum 1 01-21-2012 05:09 PM
