#43 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#44 |
Drives: Toyota 86 GTS
The toe link is adjustable on the car. You undo the two end nuts and turn the turnbuckle in the middle which should lengthen or shorten the arm, then tighten the two end nuts after adjustment is done.
| The Following User Says Thank You to eckoflyte For This Useful Post: | Jeff@Racer X Fab (03-22-2013) |
#45 |
Nice work, dudes! Can't wait to see the group buy go up.
| The Following 2 Users Say Thank You to Driven For This Useful Post: | Huehuecoyotl (04-04-2013), Jeff@Racer X Fab (03-22-2013) |
#46 | |
Drives: Subaru BRZ, Toyota MR2 Turbo
Ask and you shall receive. We are updating the lower rear control arms to offer that. Hopefully should have some pics of it soon. |
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | wparsons (03-22-2013) |
#47 |
just placed an order with race x fab. hands down best customer service i've seen yet. do your research, these guys make a quality product vs many off the shelf parts out there. they'll answer every question you have and can make custom bits/tweaks to your liking.
the after sale support alone is worth it i looked into other LCA and considered GT Spec/Whiteline/Stance/Cusco/SPC/Agency Power/Race Fab (the NZ company, not race x fab)/Hancha in the end I chose this as I felt it had an overall advantage as a package vs the above products. -ease of adjustment (no subframe getting in the way) -its strength using 4130 chromoly body and teflon lined steel rod ends (comes with dust boots for the street wary too). this factor is extremely important to me as i've experienced control arms (albeit stock) bend from spinning out and running sideways into a ripple strip. -no poly flex since using rod ends (can also be easily sourced and replaced if needed) -3.7 lb vs 2.2lb stock. good weight compromise considering materials used -very good pricing and after sale support Last edited by eckoflyte; 03-25-2013 at 07:25 AM. |
| The Following User Says Thank You to eckoflyte For This Useful Post: | Jeff@Racer X Fab (03-26-2013) |
#48 |
Drives: red frs
I need to find some money....
#49 |
Rear upper control arms!!
We have the rear upper control arms tacked together, and will be fitting them in the next few days. Very happy with the results, as usually for all of our suspension parts full 4130 chromoly. Adjustability at the hub, and bracing added to increase the structural integrity. This part allowed us a nice weight savings of 4 lbs per arm!! This is of course due to the OEM part being made from cast.
We will be offering all of our suspension parts with a urethane bushing option for those that are interested. Pics: ![]() ![]() ![]() ![]()
#50 |
Those UCA's look sweet, I'd much rather have adjustable uppers than lowers. These won't be adjustable on the car by chance, will they?
#51 |
Drives: FR-S Whiteout
What gauge material and tubing diameter are you using on the arms? Love the gusseting!
#52 | |
We use 4130 chromoly 11ga (1/8th wall) tubing and sheet stock. All of our control arms use the same. We chose this material, and thickness from our past experience in racing with the MR2. Our suspension parts are designed to be durable and last for several racing seasons or harsh street use. |
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | solidONE (03-27-2013) |
#53 |
1" tubes? Or thicker?
#54 |
| The Following 2 Users Say Thank You to Jeff@Racer X Fab For This Useful Post: | Huehuecoyotl (04-17-2013), solidONE (03-27-2013) |
#55 |
Site Moderator
Drives: Stuff
Awesome! I just spent $1,500 on track fees, $1,500 on wheels and tires, $400ish on various brake bits, need some ducts now.. ugh.. the rear UCAs will be ordered when car cash flow is available!
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#56 |
Rear upper control arms installed.
We had some time to test fit the upper rear control arms over the weekend. Here are a few pics of how we made the conection to the OEM hub. We will be adding weld nuts to the rear upper control arms to retain the harness plate that is used by the OEM upper control arm.
We also had a chance to install our updated rear lower control arm that is fully adjustable on the vehicle. No clearance issues with adjusting the arm, extremely easy to access the adjustment point and not hidden in the cross member. We are now gearing up to have stock of all suspension parts that we make, and will be offering an initial discounted rate for all pieces. ![]() ![]() ![]() ![]()
| Tags |
| lower control arms, racer x fabrication, rear toe links, trailing arms, upper control arms |
| Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
| Intakes, Exhausts, Service, Fabrication! All go fast parts! We ship international! | No Limit Motorsport | Engine, Exhaust, Bolt-Ons | 3 | 10-02-2012 04:21 PM |
| Gauging interest: No Name Garage NEW86 Parts & Fabrication | DookDookDGM | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 08-07-2012 10:09 AM |
| Freed Engineering custom metal fabrication and parts development | bFreed | Announcements, Contests, Giveaways | 23 | 03-24-2012 03:35 AM |
