Old 03-15-2013, 04:26 AM   #29
eckoflyte
Drives: Toyota 86 GTS
Pm'd
eckoflyte is offline   Reply With Quote
Old 03-15-2013, 06:32 AM   #30
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Originally Posted by eckoflyte View Post
Pm'd
Email Sent
Email, PM replied.
We should have some updates for the front control arms, and upper rears this weekend.
Jeff@Racer X Fab is offline   Reply With Quote
Old 03-15-2013, 10:40 AM   #31
OrbitalEllipses
Drives: Attitude
Email Sent
I would have suggested these, but I wasn't sure on the availability.
Old 03-17-2013, 11:53 AM   #32
Jeff@Racer X Fab
Front control arms
Well we finished the front adjustable control arms this weekend. We made a few finally changes for the front arms which are:
-offset bushings for the primary arm
-bend to provide more steering angle clearance
-spacer set for up to 2" of RCA movement
We are sending the arms out for powder coating now, they are full 4130 chromoly, and the tapered rods are getting zinc plated. The full arm with hardware weighs about 5 ounces more than the OEM arm.
We are currently working on the rear upper arms and I am pretty excited about them.
Old 03-17-2013, 01:04 PM   #33
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Those look really nice. Good work guys.
Interested in adjustable rear UCA's as well.
kask2_6.0 is offline   Reply With Quote
Old 03-17-2013, 06:43 PM   #34
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Awesome work!!! I've seen your handy work on the mr2 forums can't wait to see what else you have on the way
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-17-2013, 09:32 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Control arms look great! Can't wait to see the UCAs! Pre-order special or group buy?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-17-2013, 10:06 PM   #36
Jeff@Racer X Fab
Thanks guys!!
We will be running a group buy for all of the suspension components in the next week or two.
Old 03-18-2013, 03:43 AM   #37
eckoflyte
An important question to ask is, the way you've designed the offset bushing on the front arm to line it up with the outer ball joint, will this increase or decrease caster? Just looking at the pics alone, it looks like it decreases caster because the ball joint will move the knuckle further toward the rear of the car. Of course I could just be dyslexic.
Old 03-18-2013, 06:11 AM   #38
Jeff@Racer X Fab
The offset bushing is used to reduce the rod end misalignment. The arms hold OEM position until the rod ends are adjusted.
Old 03-21-2013, 11:57 AM   #39
Jeff@Racer X Fab
Adjustable toe links, part installation and weights
We finished the toe links a couple weeks ago with the adjustable rear control arms, adjustable trailing arms, and rear end links. We made a small change to the tapered rod, and did not want to post them up till we had the updated design completed.
12L14 cold rolled steel hex stock with 5/8 LH/RH rod ends, tapered studs provide a perfect fit to the hub and we use hex stock again to eliminate extra fastners. We will ship out the tapered studs to be zinc plated. These Will provide strength and durability for all customers looking to have great handling from racing to street. We will provide custom tapered rods for those guys that want the capability of bump steer adjustment. Be aware that it will impinge on the e-brake cable. Currently there is roughly a 1/2" of height adjustment this would not be enough to properly provide the range required.
We should have the rear upper arms completed this weekend and will update again then.
If you have any questions feel free to PM or email: info@racerxfabrication.com
Old 03-21-2013, 11:59 AM   #40
Jeff@Racer X Fab
Pics with trailing arm installed, weight of trailing arm.
Old 03-21-2013, 03:38 PM   #41
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
If all our competitors had this kind of quality, I'd be more than happy to compete. Keeps everyone on their toes and prevents us from getting complacent. Great to see another solid option for customers.
Hancha Group is offline   Reply With Quote
Old 03-21-2013, 04:27 PM   #42
wparsons
wparsons's Avatar
Are the toe-links adjustable on the car without removing an end? It looks like it might be based on the link itself being a hex, but without seeing a left and right thread I can't see for sure.
flickr
lower control arms, racer x fabrication, rear toe links, trailing arms, upper control arms
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
Intakes, Exhausts, Service, Fabrication! All go fast parts! We ship international! No Limit Motorsport Engine, Exhaust, Bolt-Ons 3 10-02-2012 04:21 PM
Gauging interest: No Name Garage NEW86 Parts & Fabrication DookDookDGM Scion FR-S / Toyota 86 GT86 General Forum 4 08-07-2012 10:09 AM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 03:35 AM
