Old 03-25-2013, 03:21 AM   #15
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Originally Posted by virobloc View Post
It might seem more complex, but it's easier and cheaper, because instead of building 6 sensors, they just write a small program for the ECU.
It's a bit like cheating
It'd be a simple math code, but changing anything in the gearing, wheels, tires, etc would throw the usability of that function out the window. I don't think Toyota would make such a choice, considering the clear intentions of a vast aftermarket for the car. If that's what it is, then yeah, it's a cheating band-aid solution. :P
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 03-25-2013, 03:24 AM   #16
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
The ECU uses engine RPM and either a tranny sensor or the same sensor that is used to calculate the speed your moving (dont think it is a wheel sensor).
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-25-2013, 03:59 AM   #17
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
why dont we get an indicator to tell
1. how far the clutch is depressed
2. how much more clutch is left
3. if there is any wear and tear to the pressure plate
4. leakage of the flux capacitor
5. how many more miles before engine breaks
6. how many more miles before we see an s2000
I dont need to see on an indicator what gear I am on if am driving a manual. its easy to tell just by the feel of that ball at the end of the stick///
njccmd2002 is offline   Reply With Quote
The Following 3 Users Say Thank You to njccmd2002 For This Useful Post:
muffinman (03-25-2013), PNW FRS (03-25-2013), robo_robb (03-25-2013)
Old 03-25-2013, 04:03 AM   #18
WolfsFang
Scrape Master
WolfsFang's Avatar
Or you could just leave the feature off and ignore this thread, instead you decided to post this very useless post.
The Following 2 Users Say Thank You to WolfsFang For This Useful Post:
njccmd2002 (03-25-2013), virobloc (03-25-2013)
Old 03-25-2013, 05:38 AM   #19
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
I know someone that did the final drive upgrade and it threw off the whole thing so it seems that it is going solely based off of the sensor in the transmission. So there isnt a simple code you can add.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 03-25-2013, 06:18 AM   #20
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Yeah, think its just based off engine speed vs vehicle speed.
When the clutch switch shows engaged.
The reason for the whole thing, I believe...
...Is for Derp's to see the upshift arrow,
Throw in the next gear = improve MPG.
Basically a upshift indicator for Fuel consumption.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 03-25-2013, 08:23 AM   #21
boead
boead's Avatar
Originally Posted by WolfsFang View Post
perfect time to spread my video
What's the (arrow up?) light blinking to the right indicating?
boead is offline   Reply With Quote
Old 03-25-2013, 09:56 AM   #22
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
How do you see your gear? I've played with all the buttons. Or so I thought.
Carbon420 is offline   Reply With Quote
Old 03-25-2013, 10:43 AM   #23
cfusionpm
Exactly what I feared. That's a shame. I've been driving a stick for about 11 years and the only time I've ever actually wanted/needed to know what gear I was in was when I rolled to a stop and forgot I was in 5th. Otherwise, gear display while moving seems kind of pointless. Disappointed Toyota would do it that way.
Old 03-25-2013, 11:05 AM   #24
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I love being able to see what gear I'm in, but is there any workaround so it displays what gear it is as soon as that gear is engaged, whether or not the clutch is in? I have muscle memory habit of pulling it out of gear, wiggling in N and re-engaging, especially at stop lights. But it'd be nice just to look and see "1" as I'm waiting to take off. It can show R without clutch engagement, so it's gotta be possible.
It depends on how the system makes the distinction. If it's per gear, then maybe, but if it's making the distinction between a forward/backward gear, it will display Reverse as the only backwards gear, but has to wait for additional input to tell you which forward gear you're in.
raul is offline   Reply With Quote
Old 03-25-2013, 11:21 AM   #25
ft_sjo
Drives: GT86
Believe it or not, there is a switch to detect when you're in reverse. The reversing lights don't come on by magic.
The Following User Says Thank You to ft_sjo For This Useful Post:
CaptainSlow (03-26-2013)
Old 03-25-2013, 12:02 PM   #26
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Originally Posted by TEWwild View Post
Mine does not show what gear I'm in... Anyone know how to turn that feature on?
Mine was also not on, but I found out how to from the owners manual. I see you've got a high spec, so it'll be different to my std which doesn't have keyless entry.
Some say - if you're desperate - read the book - LOL!!
Good luck.
Fish Eagle is offline   Reply With Quote
Old 03-25-2013, 12:47 PM   #27
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by ft_sjo View Post
It's not possible. The ECU uses engine speed and wheel speed to determine what gear is engaged. It can't do that with the engine disconnected from the drive train.
And then it brings us back to the question, how can the R indicator be shown on idle when the engine speed and wheel speed is at zero.
LeeMaster is offline   Reply With Quote
Old 03-25-2013, 12:53 PM   #28
ft_sjo
Drives: GT86
Read post #25.
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 09:42 PM
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 09:03 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 02:35 AM
