Old 03-25-2013, 12:30 AM   #1
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Display current gear without clutch engaged?
I love being able to see what gear I'm in, but is there any workaround so it displays what gear it is as soon as that gear is engaged, whether or not the clutch is in? I have muscle memory habit of pulling it out of gear, wiggling in N and re-engaging, especially at stop lights. But it'd be nice just to look and see "1" as I'm waiting to take off. It can show R without clutch engagement, so it's gotta be possible.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 03-25-2013, 01:28 AM   #2
reeves
I'd like to see this too.. seems strange why they didn't set it up that way from the factory.. it's helpful to see what gear you're in, regardless of clutch engagement.
Old 03-25-2013, 01:48 AM   #3
virobloc
virobloc's Avatar
Drives: Toyota GT86, MT, Kyuzo Red
I would like to also! But I don't think it's possible.
I don't know for sure but, since it just displays the gear you're on when the clutch is engaged, I guess that it has to do with the ECU. I mean, I think that there are no sensors on the gearbox which detect the position of the stick. It calculates the gear based on the speed and the engine revolutions. The rear is different, because it must have a sensor to switch on the rear light.
So, I'm afraid that there's no easy workaround for that... :/
virobloc
virobloc is offline   Reply With Quote
The Following 4 Users Say Thank You to virobloc For This Useful Post:
3_NA_HAF (03-25-2013), Guff (03-25-2013), reeves (03-25-2013), SloS13 (03-25-2013)
Old 03-25-2013, 01:54 AM   #4
cfusionpm
It has to have at least one physical sensor because it tells you when you're in reverse, even if you have the clutch pressed all the way in.
Old 03-25-2013, 02:01 AM   #5
virobloc
virobloc's Avatar
Yes, the one used to turn on the tail light. And they take advantage of this necessary sensor to display the R. But the other gears mustn't have any sensor.
virobloc
The Following User Says Thank You to virobloc For This Useful Post:
Guff (03-25-2013)
Old 03-25-2013, 02:05 AM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
took the words right out of my finger tips.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following 3 Users Say Thank You to WolfsFang For This Useful Post:
Alang (03-25-2013), Guff (03-25-2013), virobloc (03-25-2013)
Old 03-25-2013, 02:09 AM   #7
cfusionpm
That's a real shame if that's true. Has anyone actually taken it apart and knows there's no physical sensor for the other gears? Calculating it like that just sounds absurd and silly; an unnecessarily complex method compared to a simple sensor telling you what gear is selected. I know other cars can display gears in manual, the 370Z for example:
[ame="http://www.youtube.com/watch?v=Rf3-EFtM6oU"]Nissan Nismo 370Z Gear indicator - YouTube[/ame]
The Following User Says Thank You to cfusionpm For This Useful Post:
LeeMaster (03-25-2013)
Old 03-25-2013, 03:00 AM   #8
virobloc
virobloc's Avatar
It might seem more complex, but it's easier and cheaper, because instead of building 6 sensors, they just write a small program for the ECU.
It's a bit like cheating
virobloc
Old 03-25-2013, 03:03 AM   #9
WolfsFang
Scrape Master
WolfsFang's Avatar
The reason the 370z has that feature is due to the auto blip it has when you shift to a lower gear, so it needs to know what gear you will be in before you left the clutch.
The Following User Says Thank You to WolfsFang For This Useful Post:
Old 03-25-2013, 03:10 AM   #10
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by WolfsFang View Post
The reason the 370z has that feature is due to the auto blimp it has when you shift to a lower gear, so it needs to know what gear you will be in.
But dont the Visconti tune have the auto blip feature as well for our cars? So that means somewhere in our ECU, there's gotta be a secret passage for quick gear indicator somewhere.
LeeMaster is offline   Reply With Quote
Old 03-25-2013, 03:11 AM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
Originally Posted by LeeMaster View Post
But dont the Visconti tune have the auto blip feature as well? So that means somewhere in our ECU, there's gotta be a secret passage for quick gear indicator somewhere. Or do we have to use a seperate gear gauge..
No idea but maybe @Visconti or @Rich@ViscontiTuning can lend a hand here.
Old 03-25-2013, 03:15 AM   #12
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
Mine does not show what gear I'm in... Anyone know how to turn that feature on?
TEWwild is offline   Reply With Quote
Old 03-25-2013, 03:18 AM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
perfect time to spread my video
[ame="http://www.youtube.com/watch?v=qrns2QxDTCQ"]FRS/BRZ MT Gear indicator - YouTube[/ame]
The Following 4 Users Say Thank You to WolfsFang For This Useful Post:
boead (03-25-2013), robo_robb (03-25-2013), Squishy86 (03-25-2013), TEWwild (03-25-2013)
Old 03-25-2013, 03:21 AM   #14
ft_sjo
Drives: GT86
It's not possible. The ECU uses engine speed and wheel speed to determine what gear is engaged. It can't do that with the engine disconnected from the drive train.
The Following 4 Users Say Thank You to ft_sjo For This Useful Post:
CaptainSlow (03-26-2013), Sportsguy83 (03-25-2013), virobloc (03-25-2013), WolfsFang (03-25-2013)
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 09:42 PM
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 09:03 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 02:35 AM
