Old 03-23-2013, 10:19 PM   #71
AllDayJonRay
Drives: 2013 Ultramarine FR-S
Oh wow, so you're breaking traction with real life tires.
Are you on any kind of ecutek tune currently? What other mods do you currently have?
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
Old 03-24-2013, 11:10 AM   #72
Area51
Area51's Avatar
Drives: 13 FR-S
Stock tune, thats what I told NX I would test. Wanted to see how much room in stock tune there was for the use of nitrous. Every platform is different so as of right now the 50shot I would consider a bolt-on and go part on stock tune. Only parts I have are a muffler delete, perrin intake/filter, crank pulley and this nitrous kit.
Area51 is offline   Reply With Quote
Old 03-24-2013, 11:40 AM   #73
AllDayJonRay
Thanks. Any idea when you will be visiting the dyno? Will you be testing both 50 & 75 shots?
Old 03-24-2013, 03:08 PM   #74
Area51
Area51's Avatar
Drives: 13 FR-S
Hopefully by end of this week, I will try both time permits me for I get three pulls. Stock,50 an 75. Only thing is to change the fuel jet with this kit you need to pull fuel pump fuse and let car idle so pressure drops. Most kits the nozzel with jets are after the solenoid.
Old 03-24-2013, 03:59 PM   #75
AllDayJonRay
I'll be pretty pumped if we see safe AFR's with this kit and no tune.
And I would imagine [hopefully], that some of our trusty ecutek tuners can optimize for the best power output within safe limits.
Excited to see your dyno results. I'm warming to the idea of a nitrous setup, the instant (& massive) torque increase is hard to argue against. Car should run about on par with, say, a no frills AVO base turbo setup, at <1/2 the cost. Not to mention, it's an easier setup to 100% reverse.
Old 03-25-2013, 03:35 AM   #76
NJA
Drives: Supercharged Saturn ION
Originally Posted by NinjaAutosports View Post
Nice setup, the only thing I would do differently is run a window switch
Were would you put it then?
Oh I read it wrong. You ment like a 4000-7000 rpm switch or whatever pills desired. Thought you ment you woulda ran my wot switch diff. I will upgrade more. I tried to show new users the min needed to run effectively. NX proton kit will work just as good and leave extra cash for upgrades for people that want something that can be moved to another car.This kit was given to me to test so I have alot left over in budget to add to it. Compared to my other kits I have had this bottle valve is just beautiful, prob sound weird but if u have or had the typical valve its like something race teams would have vs the kitchen sink hot water shut off.
I like the bottle, the plate setup is pretty legit too
Yeah, I would get a digital one not one that takes pills though. MSD makes a solid digital window switch
http://www.msdignition.com/Products/...ow_Switch.aspx
Or, since you have an NX kit it looks like they offer a similar alternative
http://www.nitrousexpress.com/18959-...-required.html
Originally Posted by scraejtp View Post
??? A window switch limits the RPM range that the nitrous activates.
It allows you to set a "window" in which you want the nitrous to spray. For example you can set the switch to enable your nitrous when you are WOT from 3500-7300 RPM. It's more of a safety feature IMO because it stops you from spraying too early but also cuts off just before redline so you don't spray into the rev limiter.
I can't imagine a push button setup being very consistent either in the lower gears when you have to deal with steering and shifting while also holding down the button.
NJA is offline   Reply With Quote
Old 03-25-2013, 04:02 AM   #77
Area51
Area51's Avatar
Drives: 13 FR-S
Yea I never ran a push button setup either in the past, this electronic wot switch seems to be ideal, has l.e.d that pretty much tells you whats going on.
Old 03-28-2013, 07:17 PM   #78
mrk1
Drives: Sterling BRZ Ltd
This looks interesting. Very curious to see AFR numbers.
I'd like to see a comparison between using the plate kit vs a universal kit like a proton.
Would a progressive controller be over kill with a 50 shot?
I commute farther then I'd like to admit so a kit like this that doesn't effect daily usage is a great option compared to FI.
mrk1 is offline   Reply With Quote
Old 03-30-2013, 01:34 PM   #79
Argento_FR-S
Drives: Scion FR-S
Checked out their website and the price on this kit was incredibly appealing. Any news on how high one can safely go before needing a tune?
Argento_FR-S is offline   Reply With Quote
Old 03-30-2013, 01:51 PM   #80
fenton
When do we get to see this kit in action?
Sent from my Nexus 10 using Tapatalk HD
fenton is offline   Reply With Quote
Old 03-30-2013, 09:30 PM   #81
Area51
Area51's Avatar
Drives: 13 FR-S
I will make a video, I apologize for I ordered a wideband and a custom gauge pod so I want that installed to show people the afr's. I currently have #.039 nitroust jet in with a .021 fuel wich is good for 65-68 shot via a little nitrous math. Car hasn't had any issues. I have a feeling it will take a 75 but with nitrous trq is much more than hp. I picked jets that would get me 220/220 till I get on dyno and see exactly wats going on. Main goal is to progress a 100shot with a tune just work schedual/needing babysitter/dyno 2hrs away all working against me.
The Following User Says Thank You to Area51 For This Useful Post:
Argento_FR-S (03-31-2013)
Old 03-31-2013, 10:08 AM   #82
Argento_FR-S
Drives: Scion FR-S
So just out of curiosity, since I've never dealt with a nitrous car before... is a purge kit necessary or just for getting a quicker response from the gas? Also does anyone know if NX's remote opener also closes the bottle? Much appreciate having my eyes opened to this wonderful form of FI!
Old 03-31-2013, 12:05 PM   #83
Area51
Area51's Avatar
Drives: 13 FR-S
Purge helps remove any air from line, needed not a must. Yes the bottle opener will close as well.
Old 03-31-2013, 02:17 PM   #84
jamesm
how much does a setup like this with the window switch, heater, bottle opener, etc run for? i'm guessing around $2k (no real idea, never had nitrous). if that's the case, it wouldn't take many fill-ups of that bottle to put the total cost of ownership into turbo kit territory. seems like an odd long-term value proposition, though i love the 'cool' factor.
VA Cops on 495 express lanes SneakyPete Mid-Atlantic 35 03-02-2013 09:19 PM
Jack Burton's Porkchop Express JACK 8URT0N BRZ First-Gen (2012+) — General Topics 14 07-23-2012 10:49 AM
Auto Express article Andy EUROPE 4 11-02-2011 07:54 PM
