Old 03-17-2013, 05:03 PM   #169
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Originally Posted by Foobar View Post
Weird. I emailed him right after he posted on here about the power lead on the 29th of January, then again on the 12th of Feb, and now once more today. Maybe I'm in his Spam filter...
Same thing for me, emailed him right after he posted here about the new power wire option and then a couple of times since and then a PM and no replies...
Just tried emailing him again, I can understand he's probably been busy hopefully this time is the charm.
kludger is offline   Reply With Quote
Old 03-21-2013, 07:37 PM   #170
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Great thread
I have two questions
1. If I buy SVXdc's harness, does that plug directly into the radio or the plug from the car? Is the plug from SVXdc, a true plug and play so I don't have to cut any factory harness?
2. I am using the Rydeen Duo so I can simply wire the power for the camera into the harness?
Thanks for your help guys
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 03-21-2013, 08:30 PM   #171
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Originally Posted by Doborder View Post
Great thread
1. If I buy SVXdc's harness, does that plug directly into the radio or the plug from the car? Is the plug from SVXdc, a true plug and play so I don't have to cut any factory harness? Yes, no cutting, either places the pins in the existing harness or get the one that plugs between the existing plug and the stereo.
2. I am using the Rydeen Duo so I can simply wire the power for the camera into the harness? Yes, see my post:
http://www.ft86club.com/forums/showp...&postcount=157
See red...
michaelahess is offline   Reply With Quote
Old 03-21-2013, 10:27 PM   #172
Doborder
Godzilla Konvert
Doborder's Avatar
Thanks guys,
I just e-mailed SVXdc. Hopefully I will get my harness soon!
CO>CA Cartel
Old 03-23-2013, 11:34 AM   #173
Doborder
Godzilla Konvert
Doborder's Avatar
Good info about Al-Ed.com...
Ordered my camera
Now waiting for SVXdc's reply so I can get the
Wiring to the HU
CO>CA Cartel
Old 03-23-2013, 12:37 PM   #174
michaelahess
So curious more than anything else...
You guys all are going to take your cars apart. You will need to ground a bare wire. Why is everyone so hell bent on getting an unnecessary adapter?
Not to dis SVXdc or anything, it's great he offers this, but if you are already determined to dig into the car this much, what's a little extra effort in pushing some wire through some holes? I didnt' do any cutting or altering of the original harness, radio, etc, so going back to stock is easy, that's the number one reason for this kind of harness, but if you don't need to do any of that?
Seems like a waste of money. If it was for a device that was truly plug/play, like a different rear view mirror or something, I'd "get" it. But I don't get it!
The Following User Says Thank You to michaelahess For This Useful Post:
LenA (02-13-2016)
Old 03-23-2013, 03:22 PM   #175
Foobar
SLO NO MO
Foobar's Avatar
So you don't have to hack into the stock wiring. The harness provides a plug n play RCA composit input and power. Ground wire comes from the aftermarket camera and can be grounded anywhere without cutting existing wires.
I prefer to leave stock wiring alone wherever possible.
Oh wait, you didn't cut any wires? What'd you do, just strip the camera wires and connect to the HU through the harness blanks?
Sent from my Nexus 7 using Tapatalk 2
Old 03-23-2013, 03:37 PM   #176
michaelahess
Yes, look at my link above. No need to cut anything.
Old 03-23-2013, 03:53 PM   #177
Foobar
SLO NO MO
Foobar's Avatar
Interesting... but isn't the head unit connection male? So you're shoving the bare wire through the harness and making a connection of wire to male pin? That stays in place with no problems?
Old 03-23-2013, 03:53 PM   #178
Doborder
Godzilla Konvert
Doborder's Avatar
Thanks for the info
I'm still no clear on which pin to stick it in?
Also when I strip the wire for the camera
Which one goes where?
CO>CA Cartel
Old 03-23-2013, 06:39 PM   #179
michaelahess
Thanks for the info
Look at the second to last photo in my post. You'll see the camera pins on the left most holes, orient your connector like mine, and stick them in, the power is the red wire right next to the gray one.
As for how to do it, strip them back about twice the length you actually need, then fold it over exactly in half so the tip of wire comes back to the jacket of the wire.
Then roll the end which is now a loop over about a 1/16 of an inch. Use a butter knife or something to get a nice solid bend in it. This will give you a "fat" tip that you cram into the connector, make sure the jacket goes a bit in as well.
You should see the wire just hit, or even just barely peak out the end of the connector. The male pin from the radio will "pierce" this and make a very solid connection. Use a simple hot glue gun to hold them in place as the pictures show. That's it.
I literally used a dollar store hot glue gun, the glue comes off easily enough if you need it to, but sticks very well and won't damage anything or work loose.
If the wire is very thin you may need to fold it over thrice.
I've done connections like this many times for around 20 years, never had one give out on me.
One last thing. If the wire pushes back when you put the plug into the radio, you made it too fat. Fold it over less, or on the last fold, cut a few strands off. Even if you don't fold it over, it will most likely make a plenty good connection, just want to be sure of it.
Old 03-23-2013, 09:00 PM   #180
Doborder
Godzilla Konvert
Doborder's Avatar
Thanks for the description. I think I get you. Does it matter which of the two wire goes where from the camera. I assume there is a + and - from the camera RCA.
I just took another look at the pic, look like pink on top (next to red and gray) and bare wire on the bottom
CO>CA Cartel
Old 03-25-2013, 01:02 AM   #181
michaelahess
Yeah, ground is bottom, + is on top. I used an adapter that I had laying around to make it an rca connect so I didn't need to break the camera rca cable. Any RCA style cable will work, every DVD/VCR/Console comes with them so they aren't hard to come by.
Old 04-21-2013, 01:42 AM   #182
B L U E S L A T E
Drives: BMW E84
Just mounted the Rydeen Duo to the trunk and am waiting for David to reply to my email regarding the 16-pin connector. Hope I get the wire by next Friday so I can install the harness next weekend.
BTW, how was everyone able to aim the camera to face straight back? I tried several attempts to get the lens to face straight backwards, but just not to confident about it. I might have to fiddle it again once everything is installed...
B L U E S L A T E is offline   Reply With Quote
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
