Old 12-23-2012, 09:18 PM   #15
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Sigh-on-Rice View Post
Did you do both of the fixes? One is in the trunk and another one is from the rear seat removing the rear deck panel.
Yes, did both. Put some lube in between the panels but did not bend the sheet metal back.
Old 12-25-2012, 09:39 PM   #16
OrbitalEllipses
Drives: Attitude
Just had odd clunking or popping from what sounded like the rear left almost as if the rear wheel kept hitting something as it was turning. Stopped after half a mile, car was cold and sat for maybe 16 hours. No idea what it was and a spot check of the rear wheels produced nothing.
Old 03-22-2013, 01:58 AM   #17
suaveflooder
Originally Posted by #87 View Post
I get driver side clunk over certain bumps. It is definitely not the lsd. Ive just been living with it, don't notice any adverse effects from it. Would be interested if someone found the cause though.
Gonna bump an older thread. My car does this. A clunk, almost sounds like a loose center strut bolt, but the bolt is tight.
I've been trying to listen to this as closely as possible. It almost sounds like the rear tire, maybe where the driver is located in the car is why it is more noticeable on the driver's side
Anyone find out what this is? Any luck tracking it down?
suaveflooder is offline   Reply With Quote
Old 03-22-2013, 12:04 PM   #18
eundaddy
eundaddy's Avatar
check to see if the sway bar end links are tight
eundaddy is offline   Reply With Quote
Old 03-22-2013, 01:16 PM   #19
suaveflooder
I'll see what i can do about getting down there today, but the car is 100% stock. I did a search, not find any information on end links being loose, but plenty on a drivers side suspension clunk. Weird.
Old 03-22-2013, 03:19 PM   #20
suaveflooder
Checked the links. All is well. Just going to ignore it. For all i know its doing the same on the passenger side and is just not right behind my ear
Old 03-22-2013, 03:29 PM   #21
automatic
Drives: WRB BRZ
I got the same clunk on the left rear when going over bumps. I mostly hear it when going over bumps at speed...thought of emptying out the trunk to see if it was anything in my trunk. Or just waiting for my next service appointment to bring it up.
automatic is offline   Reply With Quote
Old 03-22-2013, 03:33 PM   #22
suaveflooder
Yeah, oddly, i don't think anything is wrong. I hit a bump evenly, i don't hear it. I hit just on the drivers side, i do. I am wondering if we are just hearing regular suspension noise and more so because it is so close to the driver. Gonna ask the dealer next time I take it in. I need to start making a list of things to have looked at.
Old 03-23-2013, 03:40 PM   #23
suaveflooder
Update.
For me at least, it was my freakin' jack! lol. When I first got the car, I had to add those rear grommets that go over the strut to keep water out. Well, I never pulled anything apart, just shoved my head down there and took care of it. The carpet/panel on the drivers side never fully laid back down.
After hearing a couple people mention the jack, I checked it out last night. Messed with the jack a little and sure enough, it made the same noise. It's not a tight fit so it bounces around pretty easily back there. I looked everything over and got everything to lay down like it should. The clunk is gone.
Crazy part is, when I went over some speed bumps today it made the noise! Go figure, it could be something so simple! All that to say, it's a bit annoying, but now that I know what it is, WHO CARES!? It's like the chirp. Not hurting anything, so all is well.
Old 03-25-2013, 11:17 AM   #24
automatic
Drives: WRB BRZ
Originally Posted by suaveflooder View Post
Update.
I'll check that out too.
I keep a cloth in my car so I suppose I'll shove the cloth where the jack is to prevent it from moving. Hopefully that resolves the noise issue.
Old 03-28-2013, 03:46 AM   #25
vault
86TUP
Drives: 86 GT
any solutions for the clunk if its not the jack?
I get it going over bumps at slow speeds and even when slowing down on a smooth surface
vault is offline   Reply With Quote
Old 03-28-2013, 03:52 AM   #26
suaveflooder
You actually pull the jack? Mine still does it, but if you play with the jack a little and look that one end of it is in the rear quarter panel, it'll echo.
Slow speeds are kind of odd. Mine is over a quick drop whether it be a speed bump or uneven road.
If it's a low thud, my vote would be the rear end. They seem to be noisy in this car.
Old 03-28-2013, 08:51 AM   #27
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
Is it just me or does the clunk seem to be worse when it's cold? I live in Florida and on cold mornings I hear it at low speeds over bumps. Once the temp warms up in the afternoon I don't hear it at all. I have to say that I adore this car but it does have some strange quirks!!
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Old 03-28-2013, 10:37 AM   #28
vault
86TUP
Drives: 86 GT
yea took it out for a few days to see if it still clunks... and it does =S
Rear end clunk when shifting? HuntingtonFRS Issues | Warranty | Recalls / TSB 26 09-30-2024 11:10 PM
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
Potential design flaw with factory rear suspension? (WATER in boot area) WTF Suspension | Chassis | Brakes -- Sponsored by 949 Racing 243 07-26-2018 03:06 PM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 05:49 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 12:10 AM
