Old 03-20-2013, 09:40 PM   #15
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by JC86 View Post
I was wondering is there an amp turn on wire in the back of the stock head unit? If not what did you for the amp turn on? Thanks.
yes there is, its brown if I remember correctly. there is a diagram on here you will just have to take a look at it.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
JC86 (03-21-2013)
Old 03-23-2013, 04:26 PM   #16
Aaronimoe
Thinking of getting the same sub/amp as you OP
I've never done audio but I think I can tackle it with this DIY
http://www.ft86club.com/forums/showthread.php?t=23314
Also what do y'all think about the infinity bass link?
http://www.crutchfield.com/p_108BASS...er-reviews-tab
Aaronimoe is offline   Reply With Quote
Old 03-23-2013, 04:45 PM   #17
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Read the reviews. I mean REALLY read the reviews on the Basslink. Check Amazon, Crutchfield, etc. Go ahead, I'll wait.
Done? Notice the overwhelming number of people complaining about the thing failing 12-16 months after installation? It's pretty common. I was considering one for my Jeep JK but had a friend talk me out of it just by showing me the reviews. True, you might get lucky and have a solid unit. But with a nearly consistant issue that's reported on numerous vendors I think I'd pass.
Skippman is offline   Reply With Quote
The Following User Says Thank You to Skippman For This Useful Post:
cruzinbill (03-24-2013)
Old 03-23-2013, 04:57 PM   #18
Aaronimoe
Yea I read some of those reviews. I'm probably gonna just spend the extra flow and get the JL setup. Always wanted something from them..
Old 03-23-2013, 06:22 PM   #19
Skippman
Skippman's Avatar
I think that's your best bet if you're looking for an "all in one" solution honestly.
Old 03-24-2013, 03:34 AM   #20
cruzinbill
I'd wait to see how the Integrity Concept guys do. It looks promising so far.
Old 03-24-2013, 03:49 AM   #21
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I just bought the non-powered version of that JL Audio sub+enclosure, the "JL Audio CS110-WXv2
Sealed BassWedge™", and want to install my Rockford Fosgate 500w amp right on top of it.
Reaffirming news to see JL Audio don't foresee any real problems with an amp tied to the box itself.
mit_peid is offline   Reply With Quote
Old 03-24-2013, 04:28 AM   #22
cruzinbill
You really don't with modern amps, unless you are pushing a ton of SPL.
Old 03-24-2013, 11:11 AM   #23
Aaronimoe
Does anyone know how much the integrity concepts box will be?
*Never mind. Damn that integrity box looks dope. Sounds like it would be just as good as the stealth box but without the JL price tag.
Old 03-24-2013, 01:00 PM   #24
mit_peid
Boosted Noob
mit_peid's Avatar
I think the OEM Audio+ system sounds good but a bit overpriced. The most attractive thing about it is how the sub/amp is located all the way to the side of the trunk. The JL Audio stealth box that is due out for the FRS will likely be even pricier than the offering by OEM Audio+.
I choose to go a similar route as the OP hoping I'd be able to get a little more value, power, SQ, and fun designing and building my own system. So far I've spent close to what the OEM Audio+ retails for $1075 - $600 (parrot smart HU), $200 (RF 4-ch 500w Punch amp), $125 (MB Quart components), $150 (JL Audio 10" enclosed). Hopefully when it all comes together it'd sound good as well.
Old 03-26-2013, 11:09 PM   #25
ysr50guy
ysr50guy's Avatar
Drives: brz
A little update, I had a bunch of junk in my trunk and one of the objects kept on rubbing against my speaker and it almost made a hole
So if anyone plans on purchasing this sub I highly recommend to buy a speaker grill, 20bucks well spent!
ysr50guy is offline   Reply With Quote
Old 03-26-2013, 11:42 PM   #26
mit_peid
Boosted Noob
mit_peid's Avatar
@ysr50guy, looks sweet dude! Hey I was wondering if you ever considered placing the sub facing downward? I asked a Crutchfield advisor about the JL Audio CS110 sub enclosure (similar to yours without the amp) and they said it would be fine because of the grooves on the side. I noticed yours has the grooves as well. Regardless, like you I may just spend the $20 to pick up the JL grill as well to protect my investment (even if I'm planning on having it face down).
Old 03-27-2013, 12:20 AM   #27
ysr50guy
ysr50guy's Avatar
Drives: brz
Will the thing is if its facing downward its going to be a little hard to find a way to strap it down to keep it from rolling around. What I did was I use industrial strenght velcro to keep it in place and it worked really good!
Old 04-01-2013, 02:46 AM   #28
Liquid Thinker
Drives: 2008 Nissan Titan
Besides the horrid reliability that someone else mentioned, it sounds like garbage.
Which is unfortunate because they make some of the better budget-friendly components IMO, the Kappa Perfects.
Liquid Thinker is offline   Reply With Quote
OEM Audio Plus BRZ review MrBodyMassage Electronics | Audio | NAV | Infotainment 235 06-16-2016 07:33 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 05:34 AM
V8 powered BRZ! Hawk77FT AUSTRALIA 4 12-28-2012 04:48 AM
OEM Audio Plus Subwoofer K2 Electronics | Audio | NAV | Infotainment 28 12-21-2012 11:28 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 10:45 PM
