Old 03-23-2013, 12:24 PM   #43
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Torque of 245 @ 7500 rpm is kinda weak, can they improve this?
RehabJeff86 is offline   Reply With Quote
Old 03-23-2013, 12:32 PM   #44
wbradley
Sarcastic SOB
wbradley's Avatar
Dont mean to be a parade pisser...
If you have the ability to swap in a completely different motor, with the fabrication that will no doubt be required...why not just pull the FA20 and make it a built engine, then go FI? Probably cost the same or less and you have a lot less fitment issues.
Old 03-23-2013, 12:38 PM   #45
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
sounds like more like $30k all done out the door if that motor alone is $20k.
Huehuecoyotl is offline   Reply With Quote
Old 03-23-2013, 12:40 PM   #46
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
the weight savings would be a plenty good reason for many. a fully dressed 400-500hp engine that weighs all of 200lbs is somewhat astonishing. anybody know what the stock motor weighs? est. 300-340lbs? the weight balance would move closer to the rear.
Also Flat-plane crank engines are not really torque monsters the are designed to rev high, 245lb/ft out of 2.8l is pretty decent really. i mean that is 90lbs more than stock and it still makes 170lb ft at 2500rpm.
FreshFRS is offline   Reply With Quote
Old 03-23-2013, 01:13 PM   #47
wbradley
Sarcastic SOB
wbradley's Avatar
There are a lot easier ways to save weight if that is the goal. And, the balance of the car would be off as well. Not to mention the CoG.
This just sounds like a wildly expensive venture with benefit that could be easily achieved with a built factory motor.
The Following User Says Thank You to wbradley For This Useful Post:
DAEMANO (12-11-2014)
Old 03-25-2013, 10:41 AM   #48
jm1681
Drives: MKVI VW GTI
Originally Posted by FreshFRS View Post
...IMO the V10 will probably weigh about 275lbs or so and be 600hp ~330tq don't quote me on that but it would be bad ass. probably 50+k or so for the engine...
Again with the soiling...
jm1681 is offline   Reply With Quote
Old 03-25-2013, 01:20 PM   #49
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
you improve it with gear ratios and weight reduction
and you can stay in each gear longer which also helps cause you can take advantage of each gear more effectively
lets say you use the same gear ratios and swap the engine
2nd gear 7450 rpms = 59 mph
2nd gear 10,000 rpms = 79 mph
3rd gear 7450 rpms = 86 mph
3rd gear 10,000 rpms = 115 mph
so you would change out for a 4.5-4.9 final drive, get a close ratio gear set to tighten up 1-2-3 and your golden at the track
by changing the final drive you can multiply how much tq is actually going to the ground
with a 4.9 you can put around 20% more power to the ground and you can land in the rev range's "power" zone much easier
EDIT: or you can get a close ratio gear set and hit 60 mph in 1st gear you wouldn't lose .3-.7 seconds a shift and seeing that the twins need to do a 2-3 shift to it 60.... you could lay down a 5 second 0-60 on the stock power... yeah 10,000 REVs help out a lot
with 400hp i could easily see the car screaming to 60 without shifting in a good 4 seconds flat.... but hey what am i to say?!!??!?!? 4 seconds is pretty good, more than i'll ever need + instant response from cable throttle + 10,000 rpms = heaven
supercharger kits also exist for that engine... so a 3 second to 60mph supercharged tiny v8 86 wouldn't be hard to imagine
EDIT EDIT:
also 245 tq is perfect for the application i want, i do have an automatic and that tq shouldn't overwhelm the transmission in any way. Or i could go with the 8 speed from the ISF have some nice shift times and plenty of gears to play with.
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
RehabJeff86 (03-26-2013)
Old 03-25-2013, 04:11 PM   #50
Praetendere
FNG
Praetendere's Avatar
Drives: 19 WRX
Want.
Praetendere is offline   Reply With Quote
The Following User Says Thank You to Praetendere For This Useful Post:
sato (12-10-2014)
Old 03-25-2013, 04:25 PM   #51
Tainen
Drives: First SWP BRZ-L
That engine is used in very, very specific racing groups around the country- mostly spec classes that all run specific versions of the H1. You can usually find used ones after someone trying to run in that class goes bankrupt- happens quite often. I researched the H1 a few years ago out of sheer interest, and man... the experiences the racers have with these motors are really cool.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 03-25-2013, 04:43 PM   #52
carbonBLUE
Reverse Burnouts
thats exactly what i want, i want something thats w technological feat that will take me a couple years to master plus itll be a hoot!
(wont forget you)
2011 Infiniti G37x
Old 03-26-2013, 02:17 AM   #53
RehabJeff86
EDIT EDIT:
Wow! U just enlightened me!! :happy0180:
That totally make sense now!! So how much is this engine again?
Old 03-26-2013, 04:52 AM   #54
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Will it sound like an LFA?
Ganthrithor is offline   Reply With Quote
Old 03-26-2013, 04:58 PM   #55
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
This motor was designed to be used in sub-1000kg cars such as Caterham clones, Ariel Atoms and Radicals, where it'd mate to a bike transmission or a sequential box.
Sticking an H1V8 in a ZN6 sounds nice in theory (when you fap over the numbers) but realistically speaking it makes no sense at all for this car.
First of all, as already mentioned, we're talking about putting a 30k+ engine into a 25k car all for the sake of 400hp.
Let's assume that passes though.
The next big problem is that you'll need a completely new transmission as well. You see, the H1V8 is designed for sub 1000kg cars with bike trannies or sequential boxes.
The ZN6 at 1400+kgs is far too heavy for a bike transmission to handle which leaves you with two choices:
A: A Hollinger style sequential box. Big $$$ there.
B: Fab up a custom bellhousing to mate the H1V8 to the stockZN6 Aisin tranny. Better have some mad CAD skills and be prepared to completely change/build up the tranny internals and possibly swap put most of the remaining drivetrain gearing as well too. Don;t take my word for it - have a read through the Miatabusa build on MotoIQ for some good info on the joys of putting a bike-derived motor into a conventional road car.
Then of course there's engine management. No problem though - Motec M800 or better and a custom wiring harness. Just write another $$$ check.
Point is that you'd easily end up far north of $80k (and probably $100k) for a build like this, at which point you'd still be getting smoked by stuff like C5 and C6 Z06 Vettes (sub 1400kgs and/or 400+hp after all).
Don;t get me wrong here. Insanity isn't necessarily a bad thing. I'd *love* to see somebody try stuffing a Busa V8 in a ZN6 as much as I'd love to see this motor in an NA series Miata/Roadster/MX5. I'll even comment first on your Speedhunters story. You'd have to be extremely rich and batshit crazy to attempt an H1V8/ZN6 is all, given the cheaper and more practical alternatives of built FA20 motors, F/I and/or swapping in a mildly built EJ/JZ/LSx/other V8 etc.
Moar power to yall.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following 2 Users Say Thank You to ultra For This Useful Post:
DAEMANO (12-11-2014), jimbobrand (03-26-2013)
Old 03-26-2013, 05:08 PM   #56
Chad_W
Drives: 2013 BRZ DGM
As someone mentioned before, you may be better off pulling the stock motor and working it. We already know that e85 will add power, so how much would it cost to add 10% displacement, another 1.5K rpms and make it work? Could get you in the 300-350hp area without having to spend all the other money on ancillaries...
Chad_W is offline   Reply With Quote
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
What do you think about this idea... FRSowner Scion FR-S / Toyota 86 GT86 General Forum 10 07-20-2012 03:26 PM
Dealership playing games w/ price? Chewie4299 BRZ First-Gen (2012+) — General Topics 14 07-02-2012 06:11 PM
Playing music off of USB question Hanzo Electronics | Audio | NAV | Infotainment 22 06-26-2012 10:44 AM
My first time playing... ruskymx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 06-25-2012 02:19 AM
