Old 03-22-2013, 09:35 PM   #15
turbo_jimbo
Drives: 01 MR-s, 78 280z, 13 FR-s
What price range are you targeting?
turbo_jimbo is offline   Reply With Quote
Old 03-23-2013, 12:01 AM   #16
jamal
jamal's Avatar
Drives: Legacy GT
Originally Posted by Hancha Group View Post
Correct. However, 4G is a very extreme load. I don't expect most to do be doing that at a regular basis. I did do a fatigue analysis of the control arm under more realistic loading conditions (1.5G cornering, 1.5G braking, 2G bump) and here is the result:
Do you have an estimate of what a small pothole impact works out to? Or maybe just a big expansion joint at freeway speed?
jamal is offline   Reply With Quote
Old 03-23-2013, 02:41 AM   #17
u/Josh
Drives: GBS Limited 6MT
Adding to this, how did you calculate the forces encountered in 4G bump? The damper force will be proportional to velocity not acceleration, so did you make some assumption about the wheels upward velocity in this bump?
u/Josh is offline   Reply With Quote
Old 03-23-2013, 03:02 AM   #18
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
I only pay attention to Grades 2, 5 and 9 and their 'E' is ~ half of steel give or take.
As for the design, with the FEA that you're doing, the colours represent stress? So the more to red the more stressed? Could you basically just subtract material where it's blue and add it where it starts to become yellow? Same for fatigue? Get it do it stays a universal colour at whatever loading you decide for your safety factor?
The colored bar on the side will tell you how much stress is in the part. For the Fatigue study, it's the number of cycles until failure.
I want to make this at the most cost efficient way possible so there may be simple design revisions. It also depends on how many we order at a time due to the scheduling for the machines. I should have pricing early next week.
Typically around .3 G's. .5 G's if it's particularly severe.
Based on corner weights, known spring rates, and basic vehicle dynamics. It's not exact, but they're reasonable estimates. I did not reduce force from the damper working on the system, so the loading conditions for the FEA were even more extreme than what they would actually experience in real life. This is just an added factor of safety. If I could model and analyze the part more accurately, I'm sure I could take even more weight out of the part.
Hancha Group is offline   Reply With Quote
Old 03-29-2013, 04:23 PM   #19
Hancha Group
Drives: Subarus
I was able to test fit our simplified prototype (this does not reflect the final design) yesterday and spot check everything. While I wasn't able to translate it to degrees (which depends on ride height anyways), you can shorten or elongate the arm about 20mm from stock.
Since we opted to use a linkage adjuster, adjustment was a breeze. With other thin adjustment bolts, you're going to have to get creative to turn it when it's in the subframe.
We are working on final pricing and will put it up shortly.
The Following User Says Thank You to Hancha Group For This Useful Post:
NorCalRider (03-30-2013)
Old 03-30-2013, 10:24 AM   #20
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Nice piece.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-30-2013, 11:12 AM   #21
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
Looks really nice!!
johnb831 is offline   Reply With Quote
Old 03-30-2013, 08:34 PM   #22
Hancha Group
Drives: Subarus
Thank you very much. We are so confident with our product, we are offering a three year warranty for our products to be free from manufacturer's defects. This INCLUDES some forms of motorsport.
There are companies out there that say their product is intended for motorsport use, but will void your warranty if you participate in motorsports. That doesn't sound like much of a warranty to us.
Warranty is also transferable. So, if you buy it second or third-handed, we can still cover you!
For more details, please read our terms of sale on our blog here
Old 03-30-2013, 10:19 PM   #23
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Will you cover people that are from Australia too?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-30-2013, 10:37 PM   #24
Hancha Group
Drives: Subarus
We will cover warranty globally, but please remember shipping is the buyer's responsibility. If you have any specific questions, please PM or email us.
DriftEightSix (03-31-2013)
Old 05-14-2013, 04:47 PM   #25
Hancha Group
Drives: Subarus
Stopped by the manufacturer's shop. The LCAs are almost complete and they look terrific. Quick video of them milling the pockets.
[ame="http://youtu.be/-D3TWK7I43c"]http://youtu.be/-D3TWK7I43c[/ame]
A few pictures during the build steps. The sides were milled and our logo etched
Then the radii were added
Then the pocket milled
And the hub fork milled
They should be finished tomorrow, then it will be sent off for anodizing.
Our arm does NOT change the damper height. It retains the OEM damper position and adjusts the camber arm length only.
The Following 3 Users Say Thank You to Hancha Group For This Useful Post:
bestwheelbase (05-16-2013), kanundrum (05-14-2013), Overland'n'5thGEN (06-03-2013)
Old 05-14-2013, 10:39 PM   #26
Dezoris
Dezoris's Avatar
Finally a designer/vendor close by. Where are you guys at in Chicagoland? Going to likely need some of your stuff for projects.
Old 05-14-2013, 11:35 PM   #27
kanundrum
Drives: 2013 Whiteout FR-S
hmmm delicious
Old 05-15-2013, 01:23 AM   #28
Hancha Group
Drives: Subarus
Most of the time I work from Glenview, but I'm mobile so I can always meet you at a convenient time and place. Paul and Zach are based out of Indianapolis and Lawrence is based out of San Francisco. We operate like a 21st century tech company :]
hancha, rear lower control arm
Rear lower control arm part # BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-15-2013 12:33 AM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 08:18 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
