Old 03-22-2013, 02:36 PM   #15
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Huehuecoyotl View Post
Agree 100%
I'm not in a hurry to replace mine, and it drives fine 90% but when I am pushing it past 9/10, you do smell a lil clutch if I am not gentle on the shifts, but I'm modded. Burn a clutch in a month? really?
Just a lil smell. No, not the end of the day, but I dont know that its a pre-requisite, nor is an oil cooler, but nice to have if you plan to run it hard and want to enjoy lower oil temps. I will keep you all posted on my clutch.
I have no need to replace my radiator, you can bolt the SC on stock and go, no ill happens.
Originally Posted by PERRIN_Mladen View Post
Yes, with the S/C a lot more stress is put on the engine with a lot more load. The kit also uses a thin oil which is another contributing factor that brings up oil temperatures.
thanks for the awesome input guys. nice dyno graph btw. i like those numbers. i usually don't push hard and go easy on shifting but i will admit that i will like to pull from third and take some turns .that's about it.
ah yes the oil issue. hmm something to think about ,i appreciate the heads up.
vortech is saying it's meant to be run on a stock motor. bolt up and go. they have their frs they have been smashing on a dyno and is driven and has put on about 2k on it and no issues at all on stock everything.
all this info is fantastic guys. i really appreciate it.
ft86me is offline   Reply With Quote
Old 03-22-2013, 02:42 PM   #16
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
1st, I dont know what the official word is, but as someone who doesnt sell these but owns one...
Well ok so let me clarify, as much as I am a fan of the oil cooler Perrin sells and as much as I agree with their posts you should buy it/benefit cooler oil, look, I drove my stg2 Vortech kit back from CA to AZ no oil cooler no problems, and drove it around that way a bunch and beat on it too... can you run it like that for a 'minute', sure.
If youre short the $$$ for the oil cooler its not cause to not get the kit. I wouldnt suggest tracking it like that, but for the daily non beat drive, its not like its gonna overheat without it and blow your stuff up.
can the oil cooler be added later? sure
is it easier to do all at once? yup
Ideally, yes, you want the oil cooler as part of your FI kit. But I dont think it should be said you NEED it to even get started with this FI kit.
Vortech returned my stg2 car to me without the oil cooler installed, fwiw
I'm rocking away with my OE fuel, clutch, radiator, etc.
Stuff I am modding at this point is so I can track the car, not for DD
Huehuecoyotl is offline   Reply With Quote
The Following 3 Users Say Thank You to Huehuecoyotl For This Useful Post:
ft86me (03-22-2013), Sportsguy83 (03-22-2013), staycrushing (03-22-2013)
Old 03-22-2013, 02:43 PM   #17
ft86me
ft86me's Avatar
Drives: 2013 FRS
perfect!
Old 03-22-2013, 02:47 PM   #18
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
Originally Posted by ft86me View Post
robert coaches or however you spell his last name. the dude with the orange rocket bunny at sema from cali . apparently he says he needs a 6 puck clutch because it burnt through oe in a month and he needed to upgrade water cooling and needed an oil cooler annnnnd even said its not good for daily driving.
lol i never said its not good for daily driving... i stated that i recommend the 6 puck clutch if you plan on driving aggressively and if you drive in a lot of traffic i do not recommend that clutch for daily driving...
but yes the stock clutch is garbage and you should at least upgrade to an act street puck.
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
The Following User Says Thank You to staycrushing For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 02:47 PM   #19
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Originally Posted by 2forme View Post
What does the oil of the kit have to do with the oil in the motor?
I apologize for that. Had a miscommunication with Jeff!
PERRIN_Mladen is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Mladen For This Useful Post:
2forme (03-22-2013)
Old 03-22-2013, 02:48 PM   #20
ft86me
ft86me's Avatar
Drives: 2013 FRS
thank you for the clarification. i was told by SOMEONE here at my shop that its NEEDED and even for daily its NEEDS it. so definitely was the person conveying the message to me that did not mention the little details such as driving aggressively.
Old 03-22-2013, 02:51 PM   #21
Huehuecoyotl
Again, I've got a few thousand miles now on the OE clutch at the 240whp power level. Is the stock clutch absolute crap. Yes. Can you get by with it till you have loot? I hope so!
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
ft86me (03-22-2013)
Old 03-22-2013, 02:53 PM   #22
staycrushing
Drives: A Hot Mess
Originally Posted by dabocx View Post
This is going to depend alot on how you drive the car, there a quite a few people on here with the vortech kit some with higher psi versions without any of these problems.
If your going to do heavy/hard track work you might need a oil cooler or at least get one to be safe.
Clutch is going to depend on how you drive it, the vortech kits dont have alot of torque so you should not have any problems for a long time. You could get one at the same time as a lightweight flywheel to be safe, though there are alot of diff types and some might be more friendly for DD
i like to actually slide my car from time to time and i prefer clutch kit initiations.. stock clutch HATES the supercharger with clutch kicking so i e brake initiate now.
Old 03-22-2013, 02:54 PM   #23
staycrushing
Drives: A Hot Mess
i drive my cars extremely aggressively. i NEED it, the stock clutch is garbage however you look at it. i am going to be going to a sprung 6 puck in the next couple months and a 2 way diff to really make car aggressive.
The Following 2 Users Say Thank You to staycrushing For This Useful Post:
ft86me (03-22-2013), Huehuecoyotl (03-25-2013)
Old 03-22-2013, 03:05 PM   #24
ft86me
ft86me's Avatar
Drives: 2013 FRS
dang that's awesome!! thanks for the input man and clarification. btw your car is sick as fuck
Old 03-22-2013, 03:06 PM   #25
ft86me
ft86me's Avatar
Drives: 2013 FRS
thanks again man! when it craps i'll go with a stage 1 or 2
Old 03-25-2013, 04:31 PM   #26
Huehuecoyotl
... and a 2 way diff to really make car aggressive.
what 2 way diff? can you elaborate please? thanks!
Old 03-25-2013, 05:49 PM   #27
staycrushing
Drives: A Hot Mess
i am going to run the kaaz 2 way!!!!
http://www.kaazusa.com/contact2.html
i am going to be marketing the unit for ray (the owner), drop my name there... i think he got a new shipment in from japan...
they also rebuild diffs and he rebuilt the cusco diff on my 240 (the previous owner had it done) and its a BEAST!!!!
their fluid is also top notch. he is an enthusiast at heart and happy to answer any questions about his product.
Old 03-25-2013, 07:14 PM   #28
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Ray still in country? I thought he went off to Japan earlier this year. Send him my best, he knows us very well.
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Vortech Supercharger or AVO Turbo HillCountryGuru Forced Induction 48 04-11-2014 09:19 PM
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
Vortech supercharger skatery1989 Forced Induction 293 04-19-2013 04:58 PM
Vortech supercharger. skatery1989 Engine, Exhaust, Bolt-Ons 2 02-23-2013 07:19 AM
Vortech Supercharger FRS/BRZ vividracing Forced Induction 5 01-29-2013 07:03 PM
