#29 |
Drives: Toyota 86 GTS
Pm'd
#30 |
Drives: Subaru BRZ, Toyota MR2 Turbo
#32 |
Front control arms
Well we finished the front adjustable control arms this weekend. We made a few finally changes for the front arms which are:
-offset bushings for the primary arm -bend to provide more steering angle clearance -spacer set for up to 2" of RCA movement We are sending the arms out for powder coating now, they are full 4130 chromoly, and the tapered rods are getting zinc plated. The full arm with hardware weighs about 5 ounces more than the OEM arm. We are currently working on the rear upper arms and I am pretty excited about them. ![]() ![]() ![]() ![]() ![]()
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | colHolm (03-21-2013) |
#33 |
Drives: 13 BRZ
Those look really nice. Good work guys.
Interested in adjustable rear UCA's as well. |
#34 |
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Awesome work!!! I've seen your handy work on the mr2 forums can't wait to see what else you have on the way
Living life one HPDE at a time
#35 |
Site Moderator
Drives: Stuff
Control arms look great! Can't wait to see the UCAs! Pre-order special or group buy?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#36 |
#37 |
An important question to ask is, the way you've designed the offset bushing on the front arm to line it up with the outer ball joint, will this increase or decrease caster? Just looking at the pics alone, it looks like it decreases caster because the ball joint will move the knuckle further toward the rear of the car. Of course I could just be dyslexic.
#38 | |
#39 |
Adjustable toe links, part installation and weights
We finished the toe links a couple weeks ago with the adjustable rear control arms, adjustable trailing arms, and rear end links. We made a small change to the tapered rod, and did not want to post them up till we had the updated design completed.
12L14 cold rolled steel hex stock with 5/8 LH/RH rod ends, tapered studs provide a perfect fit to the hub and we use hex stock again to eliminate extra fastners. We will ship out the tapered studs to be zinc plated. These Will provide strength and durability for all customers looking to have great handling from racing to street. We will provide custom tapered rods for those guys that want the capability of bump steer adjustment. Be aware that it will impinge on the e-brake cable. Currently there is roughly a 1/2" of height adjustment this would not be enough to properly provide the range required. We should have the rear upper arms completed this weekend and will update again then. If you have any questions feel free to PM or email: info@racerxfabrication.com ![]() ![]() ![]() ![]()
#40 |
Pics with trailing arm installed, weight of trailing arm.
#41 |
FT86Club Official Vendor
Drives: Subarus
If all our competitors had this kind of quality, I'd be more than happy to compete. Keeps everyone on their toes and prevents us from getting complacent. Great to see another solid option for customers.
#42 |
Are the toe-links adjustable on the car without removing an end? It looks like it might be based on the link itself being a hex, but without seeing a left and right thread I can't see for sure.
| Tags |
| lower control arms, racer x fabrication, rear toe links, trailing arms, upper control arms |
| Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
| Intakes, Exhausts, Service, Fabrication! All go fast parts! We ship international! | No Limit Motorsport | Engine, Exhaust, Bolt-Ons | 3 | 10-02-2012 04:21 PM |
| Gauging interest: No Name Garage NEW86 Parts & Fabrication | DookDookDGM | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 08-07-2012 10:09 AM |
| Freed Engineering custom metal fabrication and parts development | bFreed | Announcements, Contests, Giveaways | 23 | 03-24-2012 03:35 AM |
