Old 03-20-2013, 09:15 PM   #43
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Originally Posted by panoy86 View Post
Very useful thread, thanks all. I met 1 fellow FR-S owner, sw20kosh (i think???) at Thunderhill, and from what I recall he posted a 2:12 on RCE Yellows with 245 or 255 width tires, very impressed.
Anyone knows if any vendor sells the RCE Yellows as a "kit", i.e., springs, camber correction bolts/perches, etc, etc?
Other than RCE? I don't think so.
enjoyminutemaid is offline   Reply With Quote
Old 03-21-2013, 10:49 PM   #44
Racecomp Engineering
The best handling I have felt with regards to rear alignment settings for N/A cars is -2.0 ish to -2.2. This makes for a very planted rear. If you can get it for the FRONT, then -2.0 o -2.5 works well also.
Just my .02 cents worth.
Myles
Old 03-22-2013, 01:40 AM   #45
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
Myles
Myles, do you think the alignment should be different for FI cars? Just trying to nail the adjustment window we must have for our control arms, in case we have to skew one way or the other.
Hancha Group is offline   Reply With Quote
Old 03-22-2013, 02:57 PM   #46
my personal experience relates to 944 turbos with 300+ whp and almost the same corner weights as the BRZ.
The theory is to get as much CONTACT patch for forward acceleration to get power down, rather than lower HP cars that rely more on overall cornering speeds and require more rear camber to "carry speed" through.
I ran 305's on my 944 Turbo and only........-.5 rear camber.
So for my BRZ when I supercharge it, I will probably start with -1.0 rear. Difference is Turbo charge cars will have a HUGE power spike mid corner and the SC cars will be super linear. Either way at some power level I think, you will need to cross over into more contact patch rather than extra camber to achieve cornering grip with FI power.
Again thats my opinion based on my past experience. I will see if this works with the BRZ chassis soon.
Myles
xxBrun0xx (08-14-2014)
Old 03-22-2013, 02:59 PM   #47
Perhaps with say 255's in the rear a compromise setting for the rear might be the ticket !
Myles
Old 03-22-2013, 05:07 PM   #48
jeebus
I've been planning on doing RCE springs as well. Can any of you chime in on what I might be able to get alignment wise, if I don't do the rear camber adjustment?
Below is my current alignment with OEM camber bolts and stock everything else. I DEFINITELY need more front camber as I am destroying the outside of the tire at each autoX, and honestly I need more rear camber too...
Front camber: -1 left, -1 right
Caster: 5.5 left, 5.5 right
Toe: 1/32" out left, 1/32" out right
Rear camber: -1.4 left, -1.6 right
Rear toe: 1/16" in left, 1/16" in right
jeebus is offline   Reply With Quote
Old 03-24-2013, 05:01 PM   #49
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Anyone got pics with the RCE drop to get an idea how much wheel gap is covered?
efactor84 is offline   Reply With Quote
Old 03-24-2013, 05:04 PM   #50
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
husker741 is offline   Reply With Quote
Old 03-24-2013, 05:08 PM   #51
efactor84
efactor84's Avatar
Originally Posted by husker741 View Post
love the decent drop. is camber kit and mounts necessary to get a full benefit out of lowering springs?
Old 03-24-2013, 05:16 PM   #52
husker741
If you go to this thread, http://www.ft86club.com/forums/showthread.php?t=29453, it'll answer a lot of questions you have, because I asked the same thing. They are super helpful. I went with the starter kit lite.
Old 03-24-2013, 05:23 PM   #53
efactor84
efactor84's Avatar
Thanks, that answered my question. I'm considering the camber kits and whiteline mounts to make camber adjustments.
Old 03-24-2013, 05:26 PM   #54
husker741
I think that the starter kit lite is probably the best all around spring kit for this car. I got it for like $400, while keeping the stock struts nice with replacement bump stops, then being able to adjust everything. I haven't heard one bad review about the springs or the kit yet. Although its not the lowest drop, it makes the car look much better, while keeping the stock struts.
Old 03-24-2013, 05:31 PM   #55
efactor84
efactor84's Avatar
can you mess the camber adjustments without needing another wheel alignment?
Old 03-24-2013, 08:45 PM   #56
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
You'd want an alignment so you can set the camber to a specific number. So you'd want an alignment if you going to change alignment settings.
Grimlock is offline   Reply With Quote
Insight on winter wheel/tires? BRZranger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 61 09-20-2013 11:06 PM
Cricket TSB - Local insight needed NickFRS Northwest 12 11-27-2012 05:32 PM
I Spent the Weekend Driving my FR-S in Snow - Insight SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 49 11-16-2012 04:56 PM
Insight on my first M/T Car. Veloist Other Vehicles & General Automotive Discussions 24 08-31-2012 11:58 AM
Would love some insight on these rims... Exhaust Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-26-2012 08:02 PM
