| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I would agree.. I'm sure the difference would be noticeable considering headlights tend to get hazy by then as well.
#16 |
Drives: 2008 Mitsubishi Eclipse GS
Don't physically touch the bulbs. That's about all..
#17 |
Drives: BRZ DGM Limited
If you park in a garage don't keep the lights set to auto since the Hids will go on each time you start the car and then go off as soon as you drive out of the garage during the day. Because, as someone posted above, a quick on and off can shorten the bulbs life.
#18 | ||||
Drives: 2013 Subaru BRZ MT Limited
There is some misinformation in this thread...as somebody who works with HID's nearly every day of different types let me try to clear some of this up as well as expand upon some others posts.
Whoever told you HID bulbs don't "die" was lying. While low wattage/voltage HID's like what you find in a car have a very long life and most likely will last many years, there WILL come a day where the gap between anode and cathode becomes too large for the ballast to strike an arc. Whether that day is after 1 year...or 8 years depends on the lamp and it's usage. That day however is the day the lamp officially dies. In the entertainment industry our HID Lamps range in life on average from 400 to 1500 hours and from 150 to 7,000+ watts or more in some cases. Because output is SO important to us (no one likes a dark stage) we tend to replace out lamps more often than most people at about half their rated life, so between 200 and 750 hours. We also replace them early because the closer they become to their rated life (especially with the higher powered lamps of 500+ watts) the most likely they are to explode due to age. This is less of an issue with low wattage HID's found in the automotive industry as they are usually far more robust since they are meant to cope with the vibrations of a vehicle as well as there is less stress on a lower wattage lamp. On our high powered lamps, if one were to explode, is could cause us a lot of money in costly repairs to our equipment so we tend to be more cautious. Quote:
^^^ bad plan...the lamps you usually find on ebay are cheapo knockoffs and will not have the same quality as an OEM lamp...you may as well be throwing your money away. Some other info that people may be interested in! Always replace your HID headlamps in pairs! If one goes...the other is most likely not far behind. NEVER touch the glass of a lamp with your bare hands, this goes for both HID and Halogen lamps. The oil from your hands will weaken the glass when it is hot and will cause the lamp to shatter and explode, this is more of an issue with HID's which have a higher operating temperature than Halogens but the practice should be used with both types of lamp. In HID"s this could mean you need a new headlight enclosure on top of a new lamp...very expensive. If you do touch the glass of a lamp with your hands, not all is lost! Grab an alcohol wipe or some rubbing alcohol and a paper towel and wipe the outer surface of the lamp down and allow to dry. This should remove any oil from the lamp surface. ALWAYS disconnect your battery when replacing your HID's....the combined voltage and amperage contained in the HID Ballast FAR MORE THAN enough to KILL YOU. God forbid you forget and someone starts your car up or even puts it in ACC/ON mode without starting the car while you're working on it and you have the headlight stick set to auto. You will learn quickly at minimum what it feels like to get Tasered...and at maximum, you'll be on the ground in a seizure suffering from cardiac arrest when the electricity of the lamp strike jumps your heart and stops it. Other than that HID's do not require much maintenance and they do last longer and have higher lumen output over Halogens. Some people call HID's in car's "Xenon's" and while unlike normal HID's, automotive HID's do contain some Xenon gas for faster startup, they are just an HID with some Xenon gas inside. True Xenon's operate at around 300atm (Atmospheres) of pressure when turned on and hot, thats about 4400psi and around 10atm (147psi) when cold. Because of this, special Kevlar body armor, masks and gloves are required when we replace these lamps.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake Last edited by Sony; 03-19-2013 at 10:40 PM. |
| The Following 6 Users Say Thank You to Sony For This Useful Post: | Cjymiller (03-20-2013), Gums (03-19-2013), jonnyozero3 (03-21-2013), M-17 (03-20-2013), michaelahess (03-20-2013), mike18 (03-19-2013) |
#19 |
Drives: 4 wheels
Automatic headlight sensors are also very sensitive to shadows, if you start the car in a shadow with the auto function on they will come on. Imo manual headlight functions trump automatic function.
#20 |
Drives: '12 C63 P31, '23 GRC
I don't use the automatic headlight feature. I'm smart enough to know when I should use the headlights.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#21 |
Drives: soon....
I've heard after a HID bulbs goes out it is best to replace it ASAP because the ballast will be damaged from trying to 'strike an arc' on a shot bulb.
Just like grounding spark plugs when cranking, give the voltage somewhere to go. |
#22 |
Drives: SOLD...
Op is in Canada, I think the hids will be on whenever the car is...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
#23 |
This is true, the ballast will continue to try to strike an arc a prescribed number of times before it gives up and stops trying, but it's best to replace the lamp ASAP to prevent damage or wearing out your igniters (the part of the ballast that created the high voltage needed to strike the arc).
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#24 |
No, the BRZ comes with separate DRL's, they are the LED's just above your fog lamps. They turn on whenever the parking brake is released. DRL's do not have to be the main headlights, and in fact most of the time they aren't to save on headlamp life. On the Canadian version of my Tacoma the turn signals act as DRL's. The FRS runs the low beam halogen's through a large resistor which halves their output and they use that as a DRL. The GT-86 uses the little LED Eyelash next to the HID lamps.
#25 | |
Drives: SOLD...
Doh! Guess I find out tomorrow!
#26 |
Drives: '05 Outback Wgn, '05 Lotus Elise
I'm doing nothing to mine. Same here, first time owning a car with HID.
If it breaks then I'll just get rid of the car and buy the newer model, hopefully the BRZ STI
#27 | |
Drives: 4 wheels
They look pretty cool. |
#28 |
Tips for extending the life of HID lights? Don't use the auto feature. Every time you pull into a garage, etc., the lights turn on for a brief period of time and are pretty much on for no reason at all.
| [GTA] Elevated Car Care - anyone used them? | chenshuo | CANADA | 14 | 11-24-2013 03:15 PM |
| FRS Carpet care | encity5 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 01-30-2013 11:04 PM |
| Best Car Care Supplies or Kit? | Dang Lad | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 18 | 07-03-2012 12:01 AM |
| Best Care Care Supplies? | Dang Lad | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 05-28-2012 02:51 PM |
