Old 03-20-2013, 11:19 AM   #2535
greighn
greighn's Avatar
Drives: Scion FR-S
Can the last couple of you who had the problem tell me if you had the Service Campaign ECU update applied already? Its the one that says its emissions/engine heat related for the states that follow CA emmissions.
-Gary.
greighn is offline   Reply With Quote
Old 03-20-2013, 11:56 AM   #2536
rawr
Drives: Red ZN6
My car did not have the Service Campaign ECU update applied. Stock ECU from Aug '12. I believe they updated it as the initial fix but CEL came back up and new ECM should be here today.
-Gary.
rawr is offline   Reply With Quote
The Following User Says Thank You to rawr For This Useful Post:
Marrk (03-20-2013)
Old 03-20-2013, 03:25 PM   #2537
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Originally Posted by lorenander View Post
not gonna lie, seeing all these issues have me reconsidering my deposit i placed for my 2013 due to hit the dealership next week. may end up waiting for a 2014 instead. the vin of my reserved one is 6075XX if that matters.
i hope this, and all the other common bugs get fixed for the next round of cars, or by 2014.
You might be OK. Just go to the first page, hit 'Ctrl + F' (assuming you're using Windows), and see if there are any other 6075. I have 6024XX and so far, I don't see any other VINs in that range. Then again, there have been quite a few reports that don't post their VINs.
Eurasianman is offline   Reply With Quote
Old 03-21-2013, 01:54 AM   #2538
lowellm
Sideways and Smiling
Drives: BRZ Limited/Manual/Galaxy Blue
I don't know if I have the updated ECU or not-- the car's manufacture date says July 2012, and I've just now taken it to the dealer for them to take a look and update the ECU if needed.
Other update: the issue showed up again today after resetting the ECU, so that appears to only be a temporary solution. I'm guessing the dealer will reflash the ECU, or update if I'm not current, and then we'll try it again and see if it comes back.
lowellm is offline   Reply With Quote
The Following User Says Thank You to lowellm For This Useful Post:
eurospeed (03-27-2013)
Old 03-21-2013, 03:21 AM   #2539
foxhu
Is there anyone updating this post or the sales of BRZ/FRS stop at October????
foxhu is offline   Reply With Quote
Old 03-21-2013, 12:33 PM   #2540
jduffy
jduffy's Avatar
This car is not for you. Get a pickup truck you'll be happier.
jduffy is offline   Reply With Quote
Old 03-21-2013, 12:36 PM   #2541
Marrk
Drives: Honda Fit
Now, is that helping?
Marrk is offline   Reply With Quote
Old 03-21-2013, 08:34 PM   #2542
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
Well, after 9 months of owning my wonderful car I have now unfortunately joined this prestigious group. My SL and CEL came on tonight. 13,543 miles and vin 7046##. Orlando, FL I'm taking it into the dealer tomorrow.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
The Following 2 Users Say Thank You to greenguy101 For This Useful Post:
BrokenNocturne (08-25-2013), eurospeed (03-27-2013)
Old 03-22-2013, 01:07 AM   #2543
lowellm
Update: heard back from the dealer this morning. They confirmed I didn't have the latest ECU, and flashed the update. They believe the latest one (I didn't get info on if there is a newer new one they are using) solves this issue. After I pick up the car tomorrow it will likely take a few days to determine if the issue returns... I will post back here if the issue comes back. Otherwise, *crosses fingers* perhaps this will fix things this time!
Old 03-22-2013, 09:46 AM   #2544
greenguy101
Update: so they said that the CEL code had to do with lean fuel attributed to the fuel pump. They have ordered a new fuel pump but they are back ordered. They told me that the car was safe to drive and that they would call me as soon as the part came in. They said it could be 2 days or 2 weeks.
The Following User Says Thank You to greenguy101 For This Useful Post:
Old 03-22-2013, 11:23 AM   #2545
Marrk
Drives: Honda Fit
Fuel pump? Aside from the chirp issues, is this something new? Or have others had their fuel pumps replaced because they were malfunctioning in this way?
Sorry if this is a repeat question. Just reply with "old issue" or "new issue," if you like.
:happy0180:
Old 03-24-2013, 03:29 PM   #2546
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
I'll be interested to see what happens when this CEL pops up after the 3 year/36k warranty. (Unless engine components are covered longer - anyone know if that's the case?) As it stands now, based on some of the higher mileage cars that are just now encountering CEL issues, the chances of me wanting to keep mine beyond the warranty period is very low. It'd be great if Subaru came out and said they would warranty this particular issue out to 10 years/100k, similar to what BMW did with their HPFP issue.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 03-24-2013, 03:38 PM   #2547
Lonewolf
Lonewolf's Avatar
Drives: Moped
Engine is part of the powertrain warranty...5 years/60K miles...plus if you have documented engine issues then most decent manufacturers extend the powertrain warranty for a little bit or give you a bit of grace period even after the powertrain warranty is over to get bugs sorted out...
Old 03-26-2013, 05:39 PM   #2548
jduffy
jduffy's Avatar
If you have to explain, you won't get it.
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
