Old 03-20-2013, 11:31 AM   #1
5bolt
5bolt's Avatar
Any mags from other Scions or Subarus fit a FR-S
Are there any mags from older model Scions or Subarus that would fit a new Scion Fr-S? I wanted to pick up some used mags to put winter tires on. Not sure what would fit. Anybody have any suggestions?
5bolt is offline   Reply With Quote
Old 03-20-2013, 11:36 AM   #2
EarlQHan
Drives: Subarus
like magazines...? is mag slang for wheel in quebec? the car is 5x100. the 1st gen tc and all subarus except 05+ sti share the same bolt pattern.
EarlQHan is offline   Reply With Quote
Old 03-20-2013, 11:39 AM   #3
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
As mentioned, tC1 wheels will fit or can be made to fit fairly easily. There's a thread here of a member that put them on his car. They are the correct bolt pattern (5x100) and are very close to the stock wheels in size (17x7) and offset (+45).
MVJ1975 is offline   Reply With Quote
Old 03-20-2013, 11:43 AM   #4
turbo_jimbo
Drives: 01 MR-s, 78 280z, 13 FR-s
They're only mags if they're made from magnesium. Not a very common wheel material.
turbo_jimbo is offline   Reply With Quote
Old 03-20-2013, 11:45 AM   #5
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
http://www.ft86club.com/forums/showthread.php?t=7535
Scroll down to the OEM section to answer your question
Old 03-20-2013, 12:22 PM   #6
DarkSunrise
DarkSunrise's Avatar
One thing to keep in mind is hub bore. HB size on the twins is 56.1mm.
Subaru standard hub bore is 56.1 mm, so OEM Subaru should be fine (if bolt pattern matches and offset fits).
Scion standard hub bore is 54.1, so you'll need to machine out the center by 2mm to get these to work.
2022 BRZ Build
2013 FR-S Build
Old 03-21-2013, 11:43 AM   #7
5bolt
5bolt's Avatar
Thanks for the input guys. I will make sure to use the term wheels instead of mags.
Old 03-21-2013, 11:53 AM   #8
5bolt
5bolt's Avatar
Smile
This thread is awesome. Thanks!
Old 03-21-2013, 11:55 AM   #9
5bolt
5bolt's Avatar
Smile
I meant the above thread is awesome.
fr-s, mags, wheels
First Coast Scions Dam262a Southeast 38 04-04-2014 05:18 AM
Changing mags? Kev01 AFRICA 10 11-30-2012 10:54 AM
about scions.. pr086 Scion FR-S / Toyota 86 GT86 General Forum 31 07-28-2012 09:42 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Scions FR-S page hartnsol Scion FR-S / Toyota 86 GT86 General Forum 1 12-05-2011 03:05 PM
