Old 03-18-2013, 06:25 PM   #43
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Black Tire View Post
Personally, on a flat surface, I put my car up on jack stands so it doesn't roll away. I also remove the wheels and tires and put them in the car so they won't get stolen. On a hill, I take out my 3-foot steel stake, pound it through the asphalt with my sledge hammer, and attach it with a chain to a tow hook so the car does't roll downhill just in case everything else breaks.
That's the real reason they designed the twins to take 4 wheels/tires in the trunk and back seat.
I go a step further in that I remove the ECU (behind the glove box) every time I leave the car unattended for a while to counter any attempted theft. Pulling the engine just got way too bulky and time consuming with having to haul a winch setup behind the car everywhere I go. Plus all the questions I used to get while riding up the elevator with the engine on a dolly...
Old 03-18-2013, 07:43 PM   #44
roddy
roddy's Avatar
Drives: '13 Ultramarine
Another thing to note... The recommendation of 1st or reverse is because they are the lowest gears. If you are on an incline, the car will roll easier in the higher gears than in the lower ones. I don't trust parking brakes alone...I've seen them fail. I use the brake and 1st gear.
Old 03-18-2013, 10:14 PM   #45
Imrac
Drives: 13 SWP BRZ Prem
17 comments in and nobody mentions that the manual says not to leave the car in gear unless parked on an incline, interesting...
But I agree with everyone here, it doesn't hurt and can only help so I do it all the time out of habit.
Good call sir! Although it doesn't really say not to park in gear, but states if on a hill, park in gear.
Oh and.. "Block the wheels as needed"
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 03-19-2013, 12:34 AM   #46
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I live mine in reverse. I don't know about the FR-S manual gear box but many have a stright cut reverse gear which is much more robust that your forward drive gears. Plus I figure if your going to let your car rest on a gear might as well be the one you use the lest.
At any rate there's absolutely no reason not to leave your car in some gear.
Old 03-19-2013, 11:32 AM   #47
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I go even a step further. If I know I have to park on the street....I take the wife's car.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 03-19-2013, 11:38 AM   #48
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
If a thief tries to steal your car, leaving it in 1st gear will make a very loud squeaky sound that will wake the neighbors up. If you leave it in neutral, then well...your tires will just keep rolling freely.
LeeMaster is offline   Reply With Quote
Old 03-19-2013, 12:57 PM   #49
bdub85
bdub85's Avatar
Drives: 2013 Raven FR-S
In every manual car I've owned (which have been a lot), I leave it in gear when I park. I thought that was standard practice? It's never broke anything in any of my cars.
bdub85 is offline   Reply With Quote
Old 03-19-2013, 01:58 PM   #50
Kunzite
Drives: Toyota Auris
It is standard practice (at least around here, where most cars by far are manual); and, as we can see, there's nothing in the manuals that says not to do it.
People not used with it must be extra careful (when releasing the clutch), but it won't break anything; it just adds safety.
Kunzite is offline   Reply With Quote
Old 03-19-2013, 02:06 PM   #51
TKinWhiteOut
TKinWhiteOut's Avatar
Drives: 2013 White Out Scion FR-S Manual
I checked the manual too. I wonder if the booklet doesn't tell you because they think you should know? I have no idea.
I was always taught to put the car in 1st gear when parking and to think of it like 1st gear is Park.
Automatics have Park and an emergency brake. You wouldn't drive your automatic and park without setting the gear into to Park and just using the emergency break.
My motto, 1st gear is park for manual drive.
What I was surprised about in the booklet is it teaches you how to start off from a steep hill when driving manual. That was something I learned and never knew they would put it in the booklet.
TKinWhiteOut is offline   Reply With Quote
The Following User Says Thank You to TKinWhiteOut For This Useful Post:
Bonburner (03-21-2013)
Old 03-19-2013, 03:52 PM   #52
jdmasfcuk
jdmasfcuk's Avatar
Drives: Toyota 86 ZN6
Originally Posted by Imrac View Post
Leaving the car in first and with the handbrake is way too much stress on the vehicle. I make sure I have 4 sets of chocks with me at all times. I pull the handbrake, get out, place all 8 chocks around the car (Because I don't want to stress just one or two wheels with chocks). Then I release the handbrake so the cable doesn't stretch.
jdmasfcuk is offline   Reply With Quote
Old 03-19-2013, 05:00 PM   #53
Endless Mike
Drives: 2013 Ultramarine FR-S
It is standard practice, or should be, at any rate. Saabs won't even let you remove the key without being in R (which is kind of dumb, since the gear you want to be in kind of depends on the direction the car is facing on a hill).
Incidentally, automatics should always use the parking brake, as well, since a brake is far better at keeping a car from moving than the parking pawl in the transmission, not mention easier to repair.
Endless Mike is offline   Reply With Quote
Old 03-20-2013, 11:55 PM   #54
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Where does it say that?
Evil Jesus is offline   Reply With Quote
Old 03-21-2013, 12:34 AM   #55
airjonny
airjonny's Avatar
Drives: Nissan Murano
I'm learning to drive stick this summer. So should I always leave it in gear last on hills? Or is there no particular order?
airjonny is offline   Reply With Quote
Old 03-21-2013, 01:12 AM   #56
Imrac
Leave it in gear (1st or reverse) when ever you want, but the manual recommends at least on hills. Just be sure to get into a habit of making sure the car is in neutral before releasing the clutch after starting the vehicle.
Best Parking Job Ever Mr.Bobbino Off-Topic Lounge [WARNING: NO POLITICS] 15 01-17-2013 08:30 PM
FR-S backed into in parking lot tvpr Scion FR-S / Toyota 86 GT86 General Forum 29 01-06-2013 02:20 PM
parking in gear jarviz Scion FR-S / Toyota 86 GT86 General Forum 47 11-10-2012 12:22 PM
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 12:42 AM
Hit and Run in parking lot PoRco Scion FR-S / Toyota 86 GT86 General Forum 39 08-17-2012 01:44 AM
