Old 03-19-2013, 09:14 AM   #43
swift996
swift996's Avatar
I like the design of the intercooler and it having the inlet/outlet up top. It gives more room for an oil cooler and better airflow to the radiator.
Does anyone know the spec on the turbo?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-19-2013, 09:54 AM   #44
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Greddy 11500314 Turbocharger T518Z
GReddy exclusively uses GReddy Spec. Mitsubishi Heavy Industries, Japan Turbochargers, many of which are unique to us, including the popular 18G’s, compact TZ line and large hybrid T-power Turbos. It is well known, Mitsubishi turbochargers are among the highest quality turbos in the industry today. They utilize a durable center cartage, an extra large free-floating bushing with a large diameter center shaft. We believe this design to be superior to all other standard bushing turbos as well as many ball bearing types.
T518Z = TD05H-18G
CWL = inducer 50.5mm, exducer 68mm.
TWL = exducer 49.1mm, inducer 56mm.
COMP HSG =
EXH HSG = 8cm2 or 10cm2
Looking for map
Edit :found best available
Read First This is the most accurate map I'm aware of
Originally Posted by Danny50 on Aug/07/09 on Garret
Description: This flow map is my speculation based on horizontally squeezing and vertically stretching a MHI 20G map.
The 16G-large, 18G, and 20G compressor wheels all share the same 2.680" exducer diameter and differ in trim (and perhaps blade design): 50 trim for the 16G-large, 55 trim for the 18G and 60 trim for the 20G. In wheel "families" like this (same exducer size) higher trim usually means more flow and often lower maximum pressure ratio. Sometimes the higher trim wheel may have a bit less maximum efficiency than the lower trim wheel, such as seen in the Garrett T3 series (compare 50-trim and 60-trim wheels). So to make this map I reduced the 20G flow some and increased the maximum PR some. All "G" maps are somewhat similar in appearance so I think this speculative map may be a reasonable guess as to the MHI 18G performance. Coverage of demand lines is not as good as the 14B and 16G-large, but better than with the 20G. However, efficiency is probably better than either of the other 3 wheels. Note: This is the stock turbo for the GReddy turbo kit.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following 2 Users Say Thank You to Floggin Tires For This Useful Post:
Shankenstein (03-19-2013), swift996 (03-19-2013)
Old 03-19-2013, 11:04 AM   #45
SnapOv3st3r
Drives: 400whp Scion tC
Thought this was interesting:
Originally Posted by SpeedHunters
At the $25,255 sticker price that Scion offers the FR-S it is actually cheaper to buy one of these outright and ship it back to Japan than it is to go down to a local Toyota dealer and order an 86, if they even have one in stock.
SnapOv3st3r is offline   Reply With Quote
Old 03-19-2013, 11:16 AM   #46
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Originally Posted by diss7 View Post
Hey, maybe you are a guru, maybe you aren't. But implying that you know more than a massive well respected tuner like greddy/trust is a hell of a call to backup.
I'm implying that i have seen plenty of those type of flex bellows fail. I've been doing this over 10 years and personally built over a thousand manifolds. Not saying i know more than whoever, but i am confident in my work and thats all that matters to me.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 5 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
akuhei (03-19-2013), Floggin Tires (03-19-2013), Huehuecoyotl (04-04-2013), No Limit Motorsport (03-19-2013), SkullWorks (05-22-2013)
Old 03-19-2013, 04:56 PM   #47
diss7
Drives: AE86, 2x GT86, TE27
All good man. I'm not blinded by the brand either, you might be right about this.
I'll retract my indirect comment about your kit being a copy of this kit as well; based on your word that it's not. Just because two kits look similar doesn't mean one is a copy of another - althougth usually it does. Sometimes two different sets of experienced eyes come up with the same solution to the same problem.
diss7 is offline   Reply With Quote
Old 03-19-2013, 05:00 PM   #48
Noob4Life
86 Noob
Drives: Firestorm FR-S
If this kit ends up being carb exempt I may have to pick it up. I know greddy has released carb exempt kits in the past so itd be nice to see another one.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline   Reply With Quote
Old 03-19-2013, 05:14 PM   #49
diss7
You guys in the states are lucky in this respect. Because you're such a massive market, car manufacturers put MUCH less margin on your cars sold there. I lived in Australia up until a few months ago, and there dollar is the same value as yours. Yet a car that was made in Australia, (HSV, Pontaic GTO in US) was $10k MORE to buy in Australia, than it was to buy it from the US, and ship it back.
Another example is new luxury cars. Again in Australia, a new Lexus ISF was $135k, a new E92 M3 is $190k.
But, that said; our wages / living conditions / economy I believe are better in Australia/New Zealand.
Originally Posted by TylerLieberman View Post
I'm not saying it's not worth it. I would definitely buy GReddy products over most others. I was just stating that I'll bet it will be $5,000+ because there are various people saying it should only be $3,000-$4,000 for the full kit.
Its 514,000 yen, which according to google is $ 5404 USD.
Old 03-19-2013, 05:21 PM   #50
swift996
swift996's Avatar
Weather, beaches, people, all better lol.
Old 03-19-2013, 05:30 PM   #51
Jesse@JDLAutodesign
We sell quite a few turbo kits for other makes/models to Australia...would love to move there!
Old 04-02-2013, 07:17 PM   #52
diss7
I wonder why they went with the t518z 10cm instead of the t518z 8cm. All the SR20 guys who have tried both believe the 8cm is the better street setup for their motors. And considering that many will run this kit at low boost levels, I wonder if Greddy would offer it as an option if you asked for an 8cm instead.
A t517z might be a great option for a more responsive 200rwkw setup as well.
Old 04-02-2013, 11:06 PM   #53
diss7
After spending the afternoon comparing turbos around the 200kw range, I'm convinced the t517z 8cm is an excellent choice for a "Stage 1" (stock fuel system) setup. The t518z 10cm included in this kit, has been chosen so that there is much more headroom in the setup for when the purchaser decides to upgrade fueling.
I've asked Greddy/Trust Japan direct if they have tested a t518z 8cm or t517z 8cm on this setup already, and whether they would consider supplying the kit with one of these turbos as an alternative for those seeking realibility and response more than top end.
Old 04-04-2013, 06:29 AM   #54
brocktwalker
Drives: Scion FR-S Black
Has anyone heard a recent update on the expected availability date ? And 280hp is nice. I really want to be around 300 tho. I personally am looking for a fast daily with the style of this car. Whatever numbers Greddy ends up with will be good for me but with TSM (top speed motorsports) tuning, I wonder what kinda numbers we could see?
brocktwalker is offline   Reply With Quote
Old 04-04-2013, 08:35 PM   #55
JerryMichaels7
Drives: Whiteout FRS
From past experience with there kits, does anyone know if it was possible to just upgrade to a bigger greddy turbo
JerryMichaels7 is offline   Reply With Quote
Old 04-09-2013, 06:28 PM   #56
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
You know you can call Greddy and ask about their kit. I called them the other day. The said they're still testing the kit on Ken Gushi' scion frs. They're hoping to release the between June and August, so that means they don't have a set date yet.
Cessblood is offline   Reply With Quote
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Greddy turbo clayrush Forced Induction 12 12-18-2012 12:19 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
