Old 03-19-2013, 09:53 AM   #141
2forme
Greatly appreciate your guys hard work on this. Just a few more questions for you.
Is this scenario possible or is there a conflict?
Listening to Pandora, call comes in, take that call while pandora mutes itself all while torque has been running and reading the car?
I believe this is what happens. Torque however, stops recording when it doesn't have focus. It "freezes" itself when it loses focus. Your Max and Min readings will be cleared. That's a design of Torque, not the head unit.
Can a satellite receiver be used with the head unit? Don't want to stream xm but actually have an app that controls the stations with station names.
As far as I know, there isn't a way to hook up an XM antenna to this head unit.
Will an audio setup like the oem car audio 400 get better sound from this head unit as it has a seperate dsp and amp?
The one review I've seen here says the head units built in internal amplifier sucks. If the OEM audio plus solution allows you to use RCA's instead of speaker outs from the head unit, it will sound much better.
Hope this helps!
The Following 2 Users Say Thank You to 2forme For This Useful Post:
kharn83 (03-19-2013), Yruyur (03-19-2013)
Old 03-19-2013, 10:00 AM   #142
Yruyur
Yruyur's Avatar
Great, thanks!!
Old 03-19-2013, 10:27 AM   #143
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Is this an exact copy of the actual ca-fi unit, or is it not quite as good? Thanks
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-19-2013, 10:34 AM   #144
2forme
It has the same insides, different apps, and resistive instead of capacitive screen. The Ca-Fi might have a different internal amplifier, although I have never tested it.
Old 03-19-2013, 10:51 AM   #145
Yruyur
Yruyur's Avatar
Wonder if there is a way to keep the deck powered to allow for instant boot ups like a tablet. Unfortunately you probably have to power its amp and not just the brain.
Old 03-19-2013, 10:56 AM   #146
2forme
Considering how weak our stock batteries are (mine won't hold a charge past 3 days), I think it's a good thing it shuts the entire unit off lol.
Old 03-19-2013, 11:35 AM   #147
Brody602
Drift King
Brody602's Avatar
Would youvonsider the apps not as nice/good as the actual unit or of equal value? And can you explain to me the difference between resistive and capacitive. How well does it work, sound wise, good quality? Conparable to a brand name deck? Also being routed, is it glitchy?
Old 03-19-2013, 11:56 AM   #148
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
They both run android so all the apps are the same.
The difference in the screens is capacitive can do multi touch and is just a better screen to use. Resistive is less sensitive I guess you could say. It still works perfectly fine, but don't expect to playing a bunch of games on it necessarily.
Can't comment on the rest as I don't have one.
pheoxs is offline   Reply With Quote
Old 03-19-2013, 12:09 PM   #149
2forme
Sound is great, but again, I'm not using the internal amplifier. I haven't had anything break on it. The root hasn't affected anything.
I'd say the ca-fi apps are prettier, but perform the same. Definitely not worth the 500$ premium.
The Following User Says Thank You to 2forme For This Useful Post:
Brody602 (03-19-2013)
Old 03-19-2013, 12:17 PM   #150
Brody602
Drift King
Brody602's Avatar
By internal amplifier, are you refering to the one in the HU? And how are you by passing it if so?
Old 03-19-2013, 12:26 PM   #151
pheoxs
RCA to an external amp?
The Following User Says Thank You to pheoxs For This Useful Post:
2forme (03-19-2013)
Old 03-19-2013, 12:28 PM   #152
Brody602
Drift King
Brody602's Avatar
Wouldn't that still use the internal amp aswell as external? Or would it actually bypass it?
Old 03-19-2013, 12:45 PM   #153
Brody602
Drift King
Brody602's Avatar
So what are the benefits of the unit being rooted, was there previous limitations? Such as what? Can you connect multiple bluetooth devices? I.e obd bt reader and my phone? Or would I need a wifi obd reader? Is there a diy guide on swapping out the blue led's on the unit? Which dash kit are you using for the unit?
Thanks a bunch, sorry for the noob questions lol
Old 03-19-2013, 12:46 PM   #154
pheoxs
RCAs are before the internal amplifier, if you were to take the speaker outputs and tie them into your amp on the high level inputs, then that would be after the HU's internal amp.
Rooted allows us to run torque on the older version of Android as well as other things that are beyond my knowledge. In theory its one step closer to being able to flash to the newer 4.X versions of Android which would be huge (lots more app support and options)
2forme (03-19-2013)
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
