Old 03-18-2013, 11:31 AM   #15
nonicname
Drives: it has 4 wheels and a motor
I would love to see torque curves, I don't care about HP on this car.
nonicname is offline   Reply With Quote
The Following 4 Users Say Thank You to nonicname For This Useful Post:
2forme (03-18-2013), cmss2000 (03-18-2013), Huehuecoyotl (03-18-2013), Pete (03-18-2013)
Old 03-18-2013, 12:11 PM   #16
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
what I want is a flat to better than than flat TQ tho rare to find them jewels, flat is hard enough to find
as for hp I want a constant rise rate so I stay pushed back in your seat thru each gear
here is my Vortech SC dyno plot for 240whp BRZ
24.5 mpg driving like a fool, far better, like 26.5 when she drives it
Huehuecoyotl is offline   Reply With Quote
Old 03-18-2013, 12:15 PM   #17
ft_sjo
Drives: GT86
Huehuecoyotl- Thanks for the graph, however if it's not an off-the-shelf offering then it doesn't belong in my chart.
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
2forme (03-18-2013), Sonolin (03-18-2013)
Old 03-18-2013, 12:40 PM   #18
djdnz
1337
Drives: 2013 BRZ WRB S/C
Hey ft_sjo can you add the stock curve as well? I am aware it varies from dyno to dyno, but this chart is pretty fun to at least compare the different curves themselves.
djdnz is offline   Reply With Quote
Old 03-18-2013, 12:43 PM   #19
2forme
@ft_sjo, did you want to add my best NA (203whp) run as a base for people to compare? I know this is an FI chart, but I think it would help people who are researching kits and their capabilities.
Old 03-18-2013, 12:46 PM   #20
ft_sjo
Drives: GT86
I'm trying to figure out the google chart api and how to use a google spreadsheet as the source data at the moment... once I do, you can add any data you want and select which you'd like to view/compare against. Might be a while before I get it sorted though, but I won't make any changes to the above chart in the meantime.
Old 03-18-2013, 02:18 PM   #21
AVOturboworld
Originally Posted by Shankenstein View Post
A "small turbo" kit is the same... but you add on less cylinders at lower engine speed (exhaust flow rate). If you're cruising down the highway, it's pretty likely that you're atleast at half of your max boost pressure. This means you've got more available torque and the potential for worse fuel economy.
A small turbo kit isn't any different than a large turbo kit when it comes to cruising - the car doesn't need to boost to cruise at any speed below, say, 110mph. Just because the turbo will spin up sooner and quicker doesn't mean it is going to automatically. 33~36mpg cruising at freeway speeds is very easy to do (get to speed, turn on cruise control).
The Following User Says Thank You to AVOturboworld For This Useful Post:
sw20kosh (03-18-2013)
Old 03-18-2013, 02:33 PM   #22
Sonolin
I'd like to know what mods you have to get 203 whp NA?
Or, is that e85?
Sonolin is offline   Reply With Quote
Old 03-18-2013, 02:38 PM   #23
2forme
Or, is that e85?
Yes. I/E/E85/Tune. It was 186 with the same setup on 93.
The Following User Says Thank You to 2forme For This Useful Post:
Old 03-18-2013, 04:21 PM   #24
djdnz
1337
I think we should make an E85 forum so we can filter out that noise :P
The Following 2 Users Say Thank You to djdnz For This Useful Post:
Floggin Tires (03-18-2013), sw20kosh (03-18-2013)
Old 03-18-2013, 04:55 PM   #25
sw20kosh
Drives: 2013 Black FR-S
I would suggest keeping this pump gas as not every state has access to E85. The typical buyer of these kits will be running on pump.
Old 03-18-2013, 05:19 PM   #26
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
It's funny, a local guy thought the same... until i showed him an E85 map. It had 5 stations within 5 miles of his house.
Most of your fuel is in oakland, and berkley unfortunately. Lots in sacremento.
85 map
Thank god i'm in IL. Looking at that map it's the E85 capitol of the world.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 03-18-2013, 05:19 PM   #27
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Agreed. When Corn juice is at 75% of all pumps nationwide, then I'm down.
Until then I'll rock 93.
I Want to drive anywhere in the states, and not plan fuel routes.
Street car is on street fuel.
Different strokes for different folks.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 03-18-2013, 09:09 PM   #28
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
just want to point out that our numbers shouldn't be considered finalized. We were having issues with the intake cam timing and weren't able to tune it. Once we have it sorted i would expect a 8-10% gain and earlier spool.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
cmss2000 (03-18-2013), Immortality (03-18-2013)
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 10:14 PM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 09:27 AM
Turbo Kits: Rational boost threshold yet? Ryephile Forced Induction 88 01-22-2013 01:05 AM
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! Lisa@TrueStreetIndustries Exterior Parts - Lighting 129 01-18-2013 09:57 PM
