Old 01-06-2013, 03:16 PM   #71
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Working around the CEL issue via tinkering with the ECU or by drilling hoses and relocating O2 sensors sounds like a bit of a PITA.
Wonder if they're doing a catted version or, if not, why?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-06-2013, 07:04 PM   #72
FR-S Matt
Some companies are planning on a catted version. Only problem with catted is it restricts airflow in the most important part of the exhaust. In some places, it will get you past the sniffer test having both cats.
I've seen people daisy chain with male/female connectors for an extension or just have a 4 foot extended cable ziptied up that extends back to the secondary cat making it their primary and bypassing the first cat. I'm almost positive that requires a tune to remove the first cat sensor.
Old 01-06-2013, 07:08 PM   #73
FR-S Matt
Originally Posted by stockysnail View Post
I'm guessing a sensor bung is a hole in the exhaust tube that the plug goes into to monitor the o2? That would mean that I'd need an exhaust shop to drill a hole in the exhaust past the 2nd cat for the plug? or cut the wire and wire it into the 2nd bung. I wonder if that would be as easy as cutting the wire and daisy chaining the wires together...
Sensor bung is that little hole the size of a nickel that the O2 sensor screws into.
Yes, that is one way of doing it, or you could have them put a bung on the header if it doesn't have one far enough back so it doesn't pick up a huge amount of flow from the collector to avoid a CEL for running rich. I've seen others reprogram the main sensor post cat as well. There's several ways to do it. Exhaust shops are able to fabricate a bung anywhere on the pipe you want I'd assume. Some vendors have been posting about the Borla header not throwing a CEL and same with the JDL one so far.
I'd find a header solution that has a built in bung and not mess with the far extension of the sensor to the front pipe or post second cat. Depending on how good our stock O2 sensors are, they may burn out after 30k miles and need better aftermarket ones. Time will tell.
I plan on going with a catless header but keeping a catted front pipe so I don't pollute the hell out of everything. The flow from the header to the downpipe/overpipe is where the biggest gains occur and that's the spot you don't want to restrict as much.
Just my 2 cents. Someone correct me if I'm wrong. The back half of the exhaust isn't too important especially if you're NA. FI is another story.
The Following User Says Thank You to FR-S Matt For This Useful Post:
ultra (01-07-2013)
Old 01-06-2013, 07:44 PM   #74
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Borla should have done an O2 bung like my old PDE down pipe.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 01-07-2013, 02:59 AM   #75
ultra
Curious cat.
ultra's Avatar
If somebody finds a way to add a bung to the Borla header which fits and avoids the CEL issue that'd be sweet.
Bit curious why Borla wouldn't do that themselves though. I'd hate to have a mechanic hack into my new header only to encounter clearance issues or worse, quality issues with the bung cracking at the weld or not fitting / not working.
Suppose we'll have to wait on some guinea pig types to show how it's done.
Old 01-07-2013, 01:02 PM   #76
gmookher
Planned.
Old 01-07-2013, 03:19 PM   #77
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Easiest way is...
Install it yourself and not where the stock O2 is
Mark it off in a close location (where it will fit on the car) on the test pipe
Buy O2 bung
Take off test pipe and have a shop weld in the bung
Not super easy but not rocket science either. Did this with my STI and my Corvette.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-07-2013, 04:33 PM   #78
BeltedBiscuit
I thought I'd chime in here since I have a UEL header from Borla. All I did to ensure I didn't though a CEL from the cat delete is to move the O2 sensor about in inch away from the exhaust flow. I placed the O2 sensor into a Spark Plug Non-Fouler that I bought at AutoZone for 4bucks. (http://www.autozone.com/autozone/par...er=720805_0_0_)
I found this video on youtube that pretty much explains the process. This is not an FRZ/BRZ in the video but it's the same thing I did to move the 02 sensor: [ame="http://www.youtube.com/watch?v=GqDmmLQ4pGk"]Clear check engine light for less than 5 dollars - YouTube[/ame]
I've had the headers on my car for about a month now, no CEL.
BeltedBiscuit is offline   Reply With Quote
The Following 6 Users Say Thank You to BeltedBiscuit For This Useful Post:
AlvinT@Borla (01-08-2013), ATL BRZ (03-21-2013), cobrabyte (01-07-2013), HRTROB (01-23-2013), industrial (01-07-2013), sinigang_guy (03-21-2013)
Old 01-07-2013, 05:34 PM   #79
seven
Tells it like it is
seven's Avatar
Very common fix also.
Old 01-07-2013, 06:11 PM   #80
FR-S Matt
Sounds pretty smart, whatever keeps that sensor from reading a flow increase.
Old 03-17-2013, 09:54 PM   #81
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
[ame]http://youtu.be/YHP6SiiToOY[/ame]
01s0uljah is offline   Reply With Quote
Old 03-18-2013, 12:19 PM   #82
Eyesacky
Eyesacky's Avatar
Drives: DGM BRZ Limited "Freyja" +2 Miatas
I installed my Borla UEL headers from JSCSpeed this past weekend. Mine has two bungs and was able to mount both O2 sensors without throwing any CELs. The sound is amazing and I'll have a video up by next weekend
http://instagram.com/p/W8UhLQjdiA/
follow me on instagram @Eyesacky
Eyesacky is offline   Reply With Quote
The Following User Says Thank You to Eyesacky For This Useful Post:
Pete (03-18-2013)
Old 03-18-2013, 12:20 PM   #83
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
how many miles have you driven it? The CEL will come on its only a matter of time.
Old 03-18-2013, 01:18 PM   #84
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I want a working CEL solution without a tune and then I'd consider buying.
Dynos.. Mustang, DynoJet and Dynapack phenom86 Engine, Exhaust, Transmission 44 01-19-2018 06:32 PM
Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ RiskyTrousers Engine, Exhaust, Transmission 155 08-16-2013 10:05 PM
New! Borla cat-back for FR-S/BRZ Mach V Dan Engine, Exhaust, Bolt-Ons 9 02-06-2013 09:57 AM
Berk mid pipe and track exhaust installs, dynos, and video Matt Andrews Engine, Exhaust, Transmission 15 12-11-2012 09:15 PM
Borla Exhaust in the works DAZE752 Engine, Exhaust, Transmission 14 06-13-2012 03:27 AM
