Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 08-16-2012, 07:41 AM   #29
coyote
coyote's Avatar
Drives: Slowly
Having just done a bit of googling about car engine oils I have come to the following conclusions:
Finding objective information is nigh on impossible. It is either forum threads ("yeah, i use extra virgin olive oil and it rulz") or it is an infomercial by an oil manufacturer ("tests have shown that using our oil will get you laid").
It has been suggest that it is more important is to change the oil regularly than the brand of oil.
Google BITOG
coyote is offline   Reply With Quote
Old 08-16-2012, 07:44 AM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by 000 Racing View Post
I guess I don't care if you don't use it.. just my opinion. We just pulled it down for a rebuild and just needed to do the heads.. bores are fine along with bearings.. Once it was back together we went from 351rwhp to 394.. just my opinion but I am staying with the Royal purple.. there are comparitive dyno tests between different oils and it comes out very well on HP. Wear is something you would have to judge, personally I change oil regularly.. it's cheap insurance as I say.
Sure sure sure. I am not saying RP is not a good oil. As for it increasing power that is not unreasonable either. I was just questioning your statement that RP saved your engine.
Sorry,I am pedantic and my friends get amused and annoyed with me in equal measure.
Old 08-16-2012, 08:01 AM   #31
Loki556
Drives: RA23
Real questions seems to be - whats the best fuel for the 86?
Loki556 is offline   Reply With Quote
Old 08-16-2012, 08:02 AM   #32
Captain Snooze
Drives: Red Herring
Fuel? I thought we discussing engine oil.
Old 08-16-2012, 09:35 PM   #33
Loki556
Drives: RA23
Yep, but apparently using wrong kind of fuel on this car causes pinging.
Old 08-20-2012, 06:04 PM   #34
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Use 98 & you shouldn't have a problem. (although after reading this post maybe not http://www.ft86club.com/forums/showthread.php?t=13827 )
Back on topic, I'd stick with 0w-20 or 5w-30 to avoid any warranty issues. If you want extra protection use Amsoil, Redline or Motul. http://www.ft86club.com/forums/showt...213#post392213
SXE10 is offline   Reply With Quote
Old 11-06-2012, 12:37 AM   #35
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Ive used the HKS 0-25w oil and my car likes it, I have seen very little in the way of Oil usage and im upto 8000km already 2nd oil change just finished and used about 0.25 litre in that time
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 11-06-2012, 01:09 AM   #36
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
warmed to 90C , OW20 shows only 0,9-1,0 bar pressure idling
kinda scares me, I 've never used such waterish oils
but still, if it's prescribed in the service manual, should be fine
MSTiFK8R is offline   Reply With Quote
Old 03-15-2013, 06:10 PM   #37
rx3
Oil with a low viscosity reduces frictional losses. However, oil is also responsible to seal the combustion chamber properly:
The oil film between the piston ring and the cylinder wall can tear off if the oil film has a low viscosity. This reduces the combustion pressure and with it power.
Racing engines usually run thus on an oil with a high viscosity. http://pitstopusa.com/i-8583247-motu...ase-of-12.html
In short: Using an engine oil with a low viscosity may actually result in less power despite the fact that the frictional losses are reduced.
rx3 is offline   Reply With Quote
Old 03-16-2013, 01:06 AM   #38
Captain Snooze
Drives: Red Herring
Hawk77FT (03-21-2013)
Old 03-17-2013, 05:11 AM   #39
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
We are going to run the Royal Purple XPR 5w 30 at Bathurst (Easter). We have the HKS oil cooler... Once we are done we will have the oil tested..
Practice, Qualifying, 2 x 30 minute sprints and a 1 hour enduro... it will be interesting to see the change in pressures and temps from the genuine oil it has at present.. still only have 530k's on the clock.
We will take some heavier weight in case the conditions get very warm.. I suspect not though given the weather in NSW lately.
000 Racing is offline   Reply With Quote
Old 03-17-2013, 05:13 PM   #40
SXE10
SXE10's Avatar
Have you thought about using Motul 300V 5w30? It doesn't get much better than that off the self. Be worth while getting a UOA done on the RP to see how its holding up
rx3 put some 20w60 in your BRZ & let us know how you get on
Your whole statement is incorrect. Most race engines will run a thinner oil in qualifying to gain more HP. Do some reading on HT/HS. BITOG is a great place to learn from http://www.bobistheoilguy.com/motor-oil-101/
Old 03-18-2013, 12:49 AM   #41
Captain Snooze
Drives: Red Herring
You forgot to mention the proviso: 300v is a race oil and is not designed for extended use. It is great if you plan on changing your oil every 2000 kms or so.
Old 03-18-2013, 04:22 AM   #42
SXE10
SXE10's Avatar
If you'd read 000 Racing post you'd see he is using is car for racing...
The JZ engine? speedy07 Engine, Exhaust, Transmission 35 04-12-2012 01:18 PM
What will the engine need to go FI? suprachica79 Engine, Exhaust, Transmission 90 11-29-2011 11:46 PM
STI engine Aldo the Apache Engine, Exhaust, Transmission 49 11-03-2011 09:36 PM
FT 86 Engine jayjayjayjay Engine, Exhaust, Transmission 15 01-18-2011 02:22 PM
