Old 03-17-2013, 12:16 PM   #29
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by WingsofWar View Post
Discussed, and acoustics have been noted to be the greatest effect of this phenomenon.
Also please shift your paradigm, as its not a dip but more of a switch, its the end of extreme scavenging during low RPM.
So true, This thread was solved after only 2 pages!
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
CircuitJerk (03-17-2013)
Old 03-17-2013, 01:27 PM   #30
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Originally Posted by Gords_zenith View Post
Well if that is true, than my apologies. I was only trying to show that maybe timing is the key culprit, but like everyone has pointed out, it's clearly the intake runner length combined with avcs that plays a bigger role.
no need to apologize dude, if you felt you needed to share something that was different to bring more information to the table theres no reason to be sorry for those actions. We ask, we research, we learn, then we ask some more. Wrong or right, that's of no consequence to the quest for knowledge.
WingsofWar is offline   Reply With Quote
The Following 5 Users Say Thank You to WingsofWar For This Useful Post:
Calum (03-18-2013), CircuitJerk (03-17-2013), mad_sb (03-17-2013), NickFRS (03-18-2013), Sportsguy83 (03-17-2013)
Old 03-17-2013, 02:05 PM   #31
mad_sb
Drives: 2013 Asphalt FR-S
Yup, hence why i like to post proof when i can. Before I started tuning my FR-S I was sure it was all tuning too. After a couple trips to the dyno and plenty of log data latter i changed my mind.... especially after seeing Nameless and P&L's results from equal length long tube headers...
There are still more NA gains to be had without cracking the seals on the motor with the intake manifold, though how much remains to be seen... At least for now we have lots of options for headers, both long and short tube, tuned and un tuned
Old 03-17-2013, 07:35 PM   #32
itwillboost
35r + 35r = 70rr ?
itwillboost's Avatar
Drives: Subaru BRZ Time Attack S13
It's pipe acoustics, intake and exhaust.
TMC/FHI used acoustic tuning to create massive low end torque (for a 2.0L NA motor) which creates the 'dip' out of the super low-end and normal mid range.
These 'dips' have existed in bikes as 'flat spots' for ages. They are pipe related there, pipe related here. Evidence comes from the only exhaust company doing real header R&D, Nameless. Major changes in pipe design led to major changes in the power curve.
This has been discussed a lot, for a long time, but people refuse to make any attempt to understand the 'why' part because the science is hard.
Bam, that's well put and it's rare to hear some one talk about the acoustics. I remember when I was learning about tuning n/a cars and people started talking about this how confused I was. For people who don't understand it's all about getting the intake and exhaust gases in and out at the right time for optimal intake and combustion.
I don't get why people are complaining so much though most older cars 200hp was plenty to have fun in.
itwillboost is offline   Reply With Quote
Old 03-17-2013, 07:47 PM   #33
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
So acoustics, it's kinda like a 2 stroke tuned pipe but reversed pretty much eh?
I love 200 HP, not too slow and you can let the engine sing for a longer time before hitting overly stupid speed...kinda like a Ninja 250R
Rayme is offline   Reply With Quote
Old 03-17-2013, 07:57 PM   #34
Dimman
Kuruma Otaku
Dimman's Avatar
Same principal of sound energy used for scavenging from the exhaust stroke. There is also wave transfer from exhaust to intake during overlap, plus the intake can generate an independent wave when the intake valve shuts on high velocity air flow.
Because titanium.
BRZ Back-up Camera and NAV Bypass SOLVED Flat Black VW Electronics | Audio | NAV | Infotainment 167 02-13-2018 12:45 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
Backseat buzzing solved (Seat belt retractor?) enivid Issues | Warranty | Recalls / TSB 1 10-05-2012 11:51 AM
BRZ won't start (Problem solved) Dusky BRZ First-Gen (2012+) — General Topics 6 09-01-2012 09:51 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
