Old 01-22-2013, 03:56 PM   #267
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Originally Posted by -max- View Post
WTB: Anbody offloading RTR tires for the new stuff?
Wow, it's good to discover the Hotchkis front is too stiff. After all, I only ran it in RTR for half the last season in the AZSolo and the AZBR regions and was doing really well. Plus, I have been letting some of our top locals run it, and none of them said it was too much bar.
But, it's good to know.
Evil86 is offline   Reply With Quote
Old 03-08-2013, 10:18 AM   #268
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
So i'm reading the coil-cooler thread, and now i'm reading the stock class/ rtr rules and oil-coolers are not permited
sad fucking panda
what's up with that?
Old 03-08-2013, 10:29 AM   #269
xwd
Yeah there has been some talk in the past about allowing those. They aren't even allowed in the ST classes where people would be even more likely to have them. I could see them being allowed in ST if someone just wrote a letter to propose the addition.
I don't see an oil cooler as a performance benefit, it wouldn't really even come into play on an autocross course. They allow catch cans in stock class so there is some precedent.
Old 03-08-2013, 11:22 AM   #270
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
The goal in SCCA is to keep stock as reasonably stock as possible plus the old rules inherited that made cars in past eras handle reasonably well (shocks, sway bar). There have been small concessions over the years (shift knob, catch can), but it just makes it hard in most cars to have a stock class car that you take to the track at times.
TomR
ABQautoxer is offline   Reply With Quote
Old 03-08-2013, 09:23 PM   #271
race2win
Drives: 2012 Miata
Well put Tom, if anything the stock class ruleset should be taken back some rather than allowing more. However, I can see oil coolers being allowed in ST* classes, since most casual track-day cars would fall into them mod-wise. There is debate going on right now regarding allowing them in Street Touring, but don't expect to see them legal in Stock anytime soon.
Mark Scroggs
Edge Motorworks 2013 Subaru BRZ STX #30/130
Special thanks to Edge & Perrin Performance
https://www.facebook.com/EdgeMotorworks
race2win is offline   Reply With Quote
Old 03-13-2013, 10:46 PM   #272
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Originally Posted by jdrxb9 View Post
As mentioned elsewhere, I had the car on the rack today and it just so happens my alignment guy is also an exhaust guy. We came up with a plan for a 2.5", single central muffler, single exit system that I figure will save almost as much weight as a muffler delete, will be PA legal, and I won't have to mess with! It'll be on by the car by spring.
Just to 'close the loop' on this:
I'm not really into exhausts so to speak, but I did want to drop some weight with minimal hassle. So, with the Borla cat-back system for 'inspiration', I had a local shop fab up a system.
First, they removed everything starting just forward of the small box resonator. Total weight removed according to my scale was 42.7 lb (3.8 box res + 12.5 mid/resonator assy + 26.4 axle back assy). They replaced that with 16 ga 2.5" OD SS tubing, a centrally-located Borla 40942 muffler, and more 16 ga 2.5" OD SS tubing. That's it - single exit, no tip, just functional. Total weight added back was ~20.6 lb (8.0 muffler, 11.6 pipe, ~1 for unmeasured hangers and welding), so the total savings is approximately the same as a muffler delete.
I don't put a lot of stock in exhaust videos, but I put this together just to see how it would turn out and compare to other videos:
I tried some inside shots with the gopro mounted to the side window, but at moderate revs you can't really hear the exhaust at all over the wind, road, and mounting/housing noises. In person, there are a couple interesting resonances in the 2k-3k range, but nothing bothersome and overall I'm satisfied with it.
As far as any power increase, I have no idea. I have no plans to dyno it and the axle-back part is 'crush bent', which probably compromised the benefit of the 2.5" a bit.
cheers!
jdrxb9 is offline   Reply With Quote
Old 03-14-2013, 08:00 PM   #273
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
sad fucking panda
There is no reason a stock class car should require an oil cooler at autocross speeds and autocross lap times unless you are hot-lapping the bejesus out of the car. ...and it that case, you should probably let your tires cool down before they start chunking.
But to Tom's point above, yea the stock class rules for autocross don't really consider a "stock" autocross/track day car where some of those more preventative reliability modifications are important. There has always been a rule disconnect there.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-14-2013, 09:45 PM   #274
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
thing is that while i intend to compete in autocross there are a number tracak days that i might hit up as well at some fast tracks (for instance Mosport International Raceway) that i have traditionally been out for 12-15 laps on at a time. I just don't want to put the car through something that will potentially damage it in the long run.
Old 03-17-2013, 01:56 PM   #275
xwd
I think at some point the rules will be rewritten to cover what modern enthusiasts do to their cars and what makes the most sense. HPDE didn't really exist back when those rules were written but is extremely popular now. I'd like to see them allow upgraded radiators and oil coolers in stock.
There has been a lot of talk on other forums about stock class recently, like the current shock rules. I'd love to see them downgrade the current shock rule and add the ST allowance for front camber adjustment to stock class. It would help out all the camber limited cars and potentially save people a lot of money on race tires.
Old 03-18-2013, 02:50 PM   #276
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I know rules need to stay current and relative. But I have a problem with constant revisions. To me stock is stock. If you want to add a radiator or an oil cooler you can go to a prepared or mod category, that is what their title says- prepared or modfied. With stock, everything should be stock. I still don't believe stock should have Dot-R tires, they should have street tires like ST class or RT class. How many cars can you buy off of a car lot with DOT-R's? (0?) If you change parts for an edge then eventually everyone else will change, then you are back to square one. In the case of stock I have the most problem because new, potential club members come in and see stock class thinking they might fit there with somewhat equal car prep, only to later learn, if this thread is followed, that the next guy has Hoosiers, a larger radiator and an oil cooler. They feel at a much greater disadvantage.The shock rule is a huge change from stock settings, and alignment should stay within stock ranges, otherwise you are drifting towards Prepared again. Too much messing with class changes, especially at the stock end, is changing the spirit of the class. With the classes the way they are now you can make mods and fit in somewhere. Too much complaining about unfair advantages already, so making changes to stock would make the differences in competitors that much worse. If you want to PREPARE your car for track days, etc. then you need to move to that class. But it is a slippery slope, start mods and continue to mod looking for that advantage that is mostly in driver ability anyway, not car prep necessarily.
MTCRX is offline   Reply With Quote
Old 03-18-2013, 02:57 PM   #277
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you're taking this too literal
and it's not a slippery slope because i don't see how you're going to constitute a larger turbo as a safety feature
Old 03-18-2013, 03:33 PM   #278
mla163
Overthinking it
Drives: BRZ in CS
It is
These are the rules. Pick a car.
It is NOT
Pick a car. Adjust rules your benefit.
mla163 is offline   Reply With Quote
Old 03-18-2013, 03:55 PM   #279
SVThis
SVThis's Avatar
Drives: Scion FRS
I agree. By the time you have changed to lighter wheels, replaced your swaybar, ehaust, shocks, bought Hoosiers ect, your costs begin to soar. Either the car is stock or it isn't.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 03-18-2013, 04:29 PM   #280
xwd
The stock class rules are ancient compared to the other classes, they haven't really seen many revisions at all. The shock rules are from a time when shocks on most cars were terrible, and the tire rules are from a time when none of the classes ran on "street" tires.
Oil coolers and radiators aren't exactly performance items, they are for reliability and generally just add weight. There is an allowance for using catch cans in stock, that arguably has more of a performance benefit than either of those items. Unless you have a really crappy car, neither of those items will ever come into play on an autocross course.
Stock is at a point now where people are starting to question the rules. I'm fine with limiting the real performance enhancing items in stock like shocks, race tires, etc. I have Hoosiers but I don't see a point to them anymore, street tires are really really good at this point.
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 04:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
