Old 01-06-2013, 03:59 AM   #43
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Originally Posted by captainzib View Post
I realize this is an old thread, but I just thought I'd point out that while the bit in bold is correct, when modern cars sense lower octane than desired, the computer will adjust the timing to compensate which could result in the power loss OP is feeling.
It says in the manual for this car that 93 is preferred but 91 can be used if that's not available. I know there are cars out there that say 93 preferred but 87 can be used, with the ecu running different timing as mentioned above to compensate.
Our cars will run on 87 if you have to put it in.. I've been out of the mechanic field for a few years.. But when I was doing my ASE classes and schools and stuff.. There wasn't a car that is a USDM vehicle that couldn't run on 87.. They all had to have a map.. Even Ferrari or Lamborghini ... They couldn't be responsible for a engine that blew out of warranty because all that is around is 87 octane and the driver had to use it.. For instance the sandy incident, 87 was all that was available in some places.. If you had to put it in your car and the engine would detonate, even with that sticker, the manufacture is still responsible, it would be a law suit they wouldn't want to handle.. It'll run different.. You especially notice it in the summer months.. But it should still run acceptable.. I thought about running 87 for half a tank to see the differences in this car.. My 93 probe with the Jdm KLZE engine was suppose to run 93+ but ran just fine with no noticeable difference in performance.. Unless i was driving up the only hill in central Texas.. Then I could hear a slight knock.. Other wise fuel mileage and performance stayed the same.. I remember when I used to cry over 1.75$ for premium.. We have a station here in Barstow off the highway to get the suckers that don't turn left and drive a block that pay 4.35 to 4.80 for 91.. It's like 3.75 a block down the road the other way..
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Marrk (01-06-2013)
Old 03-16-2013, 03:26 PM   #44
FRiSson
Drives: FR-S MT
I have had problems after two fillups. The first one lasted for about 1,000 miles. After the second time it happened, I added a half bottle of HEET additive. It went away quickly after that. I believe that the FR-Z is particularly sensitive to gas quality problems due to the dual nature of the fueling system.
FRiSson is offline   Reply With Quote
Old 03-16-2013, 05:26 PM   #45
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
like others said, empty it out by driving then fill it up with new gas again and see.
i had few experience when i drove RSX-S, Miata. aftre filling new gas, it was fine.
still, i couldnt believe you actually visited dealer for this + e-mailed corporate.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
chenshuo (03-17-2013)
Old 03-16-2013, 05:52 PM   #46
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Originally Posted by Ad8707 View Post
Have you guys experienced getting bad batch of gas before..with either your current or previous cars...
Bad gas in my old car messed up the timing in one of the cylinders causing the car to throw a misfire code. had to replace spark plugs and add fresh gas to burn up the crap.
Darryljr11 is offline   Reply With Quote
Old 03-17-2013, 02:02 AM   #47
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Add this to the tank, and fill next time with different station. Done!
http://m.canadiantire.ca/mt/www.cana....jsp?locale=en
Gords_zenith is offline   Reply With Quote
Old 03-17-2013, 02:38 AM   #48
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Lucas oil has a good octane booster and noticed HPFP to stop all cricket noises and a dead silence, actually heard the injectors ! Every full up I just add about 1/4 of it and let her be free
SMOKETREES is offline   Reply With Quote
Old 03-17-2013, 09:14 AM   #49
Skurj
Drives: SOLD...
Just don't fill up at a station which has a tanker sitting there filling the tanks. It stirs up all kindsa crap.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
The Following User Says Thank You to Skurj For This Useful Post:
FRiSson (03-18-2013)
Old 03-17-2013, 11:50 AM   #50
Gords_zenith
Good point! I will now watch out for that.
Old 03-18-2013, 10:42 PM   #51
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I have also had issues with Shell fuel in the past and now refuse to use it unless it's an emergency. I had a moderately modified s/c '98 Grand Prix for 8 years and I gave Shell a try (93 oct) three times it's whole life. Every time I lost a noticeable amount of power and got about 2-3mpg less. Same for current my '07 Silverado and '86 Dodge Daytona cs turbo.
6speed_Sam is offline   Reply With Quote
Old 03-18-2013, 10:55 PM   #52
FRiSson
Drives: FR-S MT
Mobil 93 is just as good as Shell 93, and the quality control is probably better. Shell cuts corners.
Old 03-19-2013, 07:47 AM   #53
KSC
KSC's Avatar
Drives: Ion Redline
Shell doesn't "cut corners". All top tier gas is the same shit. It comes from the same pipeline, same refinery. It's the additives, added to the actual tanker making the delivery, that make the difference. The issue can be that each brands additive package can do different things to different cars in different environments, climates, ect. One Brands additives may dilute the fuel, another's may provide better gas mileage, and another's may focus on "less engine deposits". Also, what's great for one engine, may not run so great on the next.
"Bad gas" can be attributed to numerous factors. For one, you can never know if the truck bringing the fuel to a particular station is putting what they're advertising in the tanks. There's regulations to make sure the octane is correct, but no one is monitoring the additives package. Shady stations have been known to do this.
My advice is to pick a station you trust and stick with them whenever possible. Use a place that maintains their tanks and gets plenty of traffic, so the gas never sits around too long.
I for one swear by Shell V Power and my cars run great, so sometimes it's just a personal thing and a perception that makes one prefer a particular station over the others.
Here's a list of Top Tier stations. Do some research so you can see what I'm saying isn't bs, then pick one and stick with them. Whatever you do, don't go to anyone not on that list. Valero, Hess, Eagle, or whatever else all use a standard additive package. Yet, even with that being said, there are some that would claim ALL brands, regardless of being Top Tier are no different from the rest. Go ahead and Google, "who makes the best gas". After hours of reading, you'll never get an definitive answer...
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
The Following User Says Thank You to KSC For This Useful Post:
Anthonytpt (04-05-2013)
Old 03-19-2013, 08:53 AM   #54
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
we had a local place put diesel in the 83 pump a few weeks ago.... people complained ... after their engine died....
microbionic is offline   Reply With Quote
Old 03-19-2013, 09:30 AM   #55
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
Originally Posted by RandomHero View Post
Is someone hiding in the trunk? Seriously though i noticed power loss (lack of) when carrying 3 cases of beer in this thing. I always use Shell VPower. no issues yet.
He opens the truck to see a team of midget pit stop crew workers climb out
Obja is offline   Reply With Quote
Old 03-20-2013, 08:43 AM   #56
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
I've used Shell V-Power 93 in my Mustang Bullitt for 3 years and it loves it. For some crazy reason my MX-5 doesn't run as well on the Shell but it loves the local grocery store's 'unbranded' 93 instead. I have used it exclusively for the MX-5 for over 20K miles.
Began the break-in of the FR-S with the Shell, knowing how well it works in the Bullitt. It ran OK, acted a little better with each fill-up and more miles. Plus I got used to how the car behaved with more driving.
So the last time I pulled into the Shell station near me the tanker was there filling the underground tanks. Because I NEVER fill my car while they are filling the tanks, I ran up the street to the grocery store gas station. Figured "what the hell" and I did have a ton of discount points I could use. Filled the tank with 93 and left. After a few minutes I realized the car was running much better, more seat-of-the-pants power and better throttle response too. Now after driving it more I realize that like the MX-5, the FR-S loves the grocery store gas - it's like racing fuel there is such a noticeable difference in how it runs as well as the power.
Guess that makes me a believer that every car has a favorite fuel, it's just a matter of finding the right one. And using the unbranded grocery store gas doesn't bother me at all. It comes from the same local (and reputable) distributor each time and I've used it in all my cars (except the Bullitt) for years with no issues. It's available all over my area and it's a lot cheaper as well.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 54 12-09-2016 02:14 AM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-27-2013 12:49 AM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 07:24 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 06:49 PM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 64 04-13-2011 02:36 AM
