Old 10-15-2012, 09:40 PM   #29
so26
Drives: Raven FR-S 6MT
Originally Posted by Ad8707 View Post
Filled 91 v power (no ethanol), hour later noticed significant power loss..it's taking awhile for the rpms to climb...car has 4000km no oil change..did I get bad gas...or is something more serious ie maf sensor fuel pump/fuel filter..it takes awhile for those things to go bad right...
Soooo how does this story end?
so26 is offline   Reply With Quote
Old 10-15-2012, 11:57 PM   #30
Rob_g
Drives: 2010 4Runner Trail
Originally Posted by TemeCal View Post
Sorry to resurrect this thread. However, I just had the exact same thing happen to my car. My car had Mobil 91 in it, and it was very quick and responsive. Just fueled up with 91 Shell V-Power, and it is SLOW now. It honestly feels like a completely different car, like I'm back in the Corolla rental Toyota put me in.
Anyway, I was curious to see if you resolved your issue. If so, what'd you do? Switch brands? Octane booster?
Before anyone says I should be using 93, I'm in CA and only have access to 91. I do have some Torco fuel additive I use in my desert toys, so I may mix some into this tank.
Thoughts??
I have tried v-power 91 octane and it seems to consistently lower the mileage I get by about five to ten percent. We don't have 93 anywhere locally here in SK.
Rob
Rob_g is offline   Reply With Quote
The Following User Says Thank You to Rob_g For This Useful Post:
TemeCal (10-16-2012)
Old 10-16-2012, 12:14 AM   #31
TemeCal
Drives: 86
Rob
Thanks Rob. Did you notice any loss in power also? This is my 1st tank on Shell, and happens to coincide with my power drop.
TemeCal is offline   Reply With Quote
Old 10-16-2012, 12:56 AM   #32
gmookher
shell sucks?
Old 10-16-2012, 12:58 AM   #33
Razz
Razz's Avatar
Drives: Fast
Gas Stations vary in the amount of ethanol from day to day.
This effects power output.
Razz is offline   Reply With Quote
Old 10-16-2012, 01:28 AM   #34
gmookher
Originally Posted by gmookher View Post
shell sucks?
No , not to be g=funny, i live by techron/chevron, but have been using shell in the BRZ for a quieter fuel pump, but I too feel there is less power in Shells 91 vs the other guys 91
Old 10-16-2012, 01:38 AM   #35
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
I use shell at least once a month just to clean up things inside but i do see a difference using shell compared to QuikTrip gas..... Use that all the time and it seems to have more go compared to Shell
SMOKETREES is offline   Reply With Quote
Old 10-16-2012, 01:55 AM   #36
AVOturboworld
The problem with gas stations, especially ones that you have never been to before, is that while you paid for, and thought you pumped, 91+ octane gas into your car, you are unfortunately at the mercy of the gas station owner, who may not actually be using 91+ octane at those pumps. In Japan there was a big scandal over that, actually.
It's something we noticed on our big cross-country road tune trips. Most gas stations were "honest", but occasionally we'd hit that bad one and the car would would start pinging.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
makesdrivingfunagain (08-22-2014), sierra (10-16-2012)
Old 10-16-2012, 05:28 PM   #37
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I'm pretty sure I got some bad V-Power my last fill in the Eclipse. I'm still trying to work it out of the system. There's been rumors of bad gas going around (no, not that kind of gas) also with BP. But I've been using V-Power for years and this is the first time I may have had an issue (but I'm still not 100% certain it is the fuel).
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 10-16-2012, 10:51 PM   #38
Rob_g
I couldn't say, but it sure as heck didn't run any better with it.
Rob
Old 10-16-2012, 11:10 PM   #39
FRiSson
Drives: FR-S MT
Got something like this a while back. I thought my calipers were dragging - but that wasn't it. The engine would lose power, particularly at neutral throttle, and I had to goose the accelerator to compensate. It continued to act up periodically through about 4 fillups. Finally, it has disappeared after 1,000 miles. I took it to two dealers, but the problem is kind of subtle and they just couldn't feel it. Gas mileage suffered by about 10% as well.
FRiSson is offline   Reply With Quote
Old 10-16-2012, 11:21 PM   #40
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I drove my car a lot before getting the crickets fixed I had this issue my dealership said it was because the fuel pump was bad which caused the crickets once I got them fixed that all went away. Not sure how true all that is but it seemed to work.
Old 10-17-2012, 11:18 PM   #41
TemeCal
Drives: 86
So, I happen to have 5gal of Torco Accelerator in my garage. I added 8oz of it to my ~10gal of fuel. My car woke up BIG time.
I'm not sure what the issue was, but it was either bad gas or lower than the advertised 91 octane. My car is running great again! No more Shell for me (may try it again later).
Old 01-06-2013, 02:05 AM   #42
captainzib
Oompa Loompa of Science
Drives: Scion FR-S
Originally Posted by RandomHero View Post
Not to be a stick in the mud but doesnt each bottle raise the octane by like 0.3? so to go from 87-90 thats 30 bottles? Octane doesnt make power it just prevents knock. Look elsewhere before wasting money on octane booster. Take it to dealer if it gets real bad. But unless its knocking (banging) the octane is fine.
I realize this is an old thread, but I just thought I'd point out that while the bit in bold is correct, when modern cars sense lower octane than desired, the computer will adjust the timing to compensate which could result in the power loss OP is feeling.
It says in the manual for this car that 93 is preferred but 91 can be used if that's not available. I know there are cars out there that say 93 preferred but 87 can be used, with the ecu running different timing as mentioned above to compensate.
captainzib is offline   Reply With Quote
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 54 12-09-2016 01:14 AM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 06:24 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 05:49 PM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 64 04-13-2011 01:36 AM
