Old 03-14-2013, 08:19 AM   #183
skatery1989
Drives: BRZ Limited
Originally Posted by 2forme View Post
Gem, I'll start by saying congrats on making the most power with this kit out of the half dozen or so people who already have it. Can you please supply us with a complete list of your mods at the time of testing?
He still has a little bit to go to be making the most I know Perrin has more and so do I. I do wish I could get the supercharger he has looking forward to see what comes now. I pick up about 15hp and 10tq from adding bigger fuel injectors and fuel pump.
skatery1989 is offline   Reply With Quote
Old 03-14-2013, 08:22 AM   #184
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What were your max numbers in 93 and E85?
Old 03-14-2013, 08:23 AM   #185
2forme
He stated that he was having issues with the 9psi pulley. Most people get 275 ish out of the stock fuel system on a TC, so 30 whp of parasitic drag isn't out of the realm of possibility.
Old 03-14-2013, 09:09 AM   #186
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
spot on...
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Sportsguy83 (03-14-2013)
Old 03-14-2013, 09:13 AM   #187
2forme
Originally Posted by Huehuecoyotl View Post
spot on...
See that everyone? Gem and I agree!
The Following 4 Users Say Thank You to 2forme For This Useful Post:
akuhei (03-14-2013), Calum (03-14-2013), Freeman (03-14-2013), skatery1989 (03-14-2013)
Old 03-14-2013, 09:32 AM   #188
Huehuecoyotl
See post #5 for my complete mod list
Secondly, this kit is technically sold with a 6psi pulley, unless you raise the rev limit. So people shouldn't expect 239/200 from a stg1 kit. Just wanted to clarify. You have made this clear as have I! Thanks!
Third, Scottsdale is 1250 ft above sea level.
Really? Please tell me the next time youre here I will calibrate my alitimeter in front of you, promise. See picture attached to verify my location, and the airports altitude. I was a few hundred feet from scottsdale airport, which both according to my personal altimeter(will snap a pic next time I am in scottsdale) and the airports posted sign read 1500feet. when ya coming to az? Beer is on me! heck, 2forU
If I were you, I'd slap the 10psi pulley, pull back the higher RPM timing and enjoy a really nice, flat torque curve.
NAh, thats too simple, not that me or anyone would be anything less than ecstatic to have the easy of install, simplicity of systems, and heat immunity I am seeing(PHX was 93F according to my dash so heattesting is under way) not as much fun as testing the wastegated options, and higher boost, like 12 and 14psi that tapers off before redline, that may be a neat curve to play with!
Responses in red
Man, you crack me up, starting to like your tendency to verify, youre ALOT like me! I test alot for my own benefit, not the manufacturers, but yeah we all benefit in the end
I will keep you posted of my dyno @ 12 psi and above! I plan to see what else there is on the table to play with, not done yet.
I woke up early today and wanted to address the problems I am seeing with heat off the oil cooler affecting IAT and ultimately power output. I dyno'd less after I took car off dyno, drove it hard, got it hot, and retested.
tests were done both with the oil cooler shrouded in two layers of cardboard as well as with full flow, no cardboard and IAT suffered considerably.
This dyno time and testing is out of my own pocket, so some of it is just because I'm a stickler for getting it right, and if its not right I am not done.
Wil post a picture of my new, albeit temporary oil cooler relocation. Another test item on my list, to see if oil flow and pressure work out ok with it being where it is, after a few test drives I will posta picture of that too, incase you want to copy it, makes for a cooler FMIC= more power, dyno proven, run for run, hot I couldnt exceed 237HP after several attempts.
Old 03-14-2013, 09:42 AM   #189
2forme
Why would IAT be affected by the oil cooler? The sensor sits in the front bumper below the passenger side headlight. Unless your oil cooler sits in front of the IC, then yes, blocking that off will cause a rise in IATs
And I wasn't sure of the exact location of the shop. It is indeed 1464 ft above sea level, however most of Scottsdale is 1200-1300.
Old 03-14-2013, 09:48 AM   #190
ft_sjo
Drives: GT86
I'll be extremely surprised if that's the IAT sensor and not ambient air sensor.
Old 03-14-2013, 09:51 AM   #191
2forme
The IAT is in the Mass Air Flow sensor which is relocated to the front bumper below the passenger side head light on this kit.
The Following User Says Thank You to 2forme For This Useful Post:
ft_sjo (03-14-2013)
Old 03-14-2013, 09:57 AM   #192
Huehuecoyotl
Having the oil cooler infront of the FMIC --->makes the FMIC hot which---> makes IAT hot, simple!
here is the new location: there will be some strap steel welded or clamped to the OE support bars to support the front end of oil cooler and bear most of the load
also I bent the hood support a hair an now clears the camber plate fantastically
ok folks, off to Tucson, ttys!
Pete (03-14-2013)
Old 03-14-2013, 09:57 AM   #193
TemeCal
Drives: 86
Originally Posted by s2d4 View Post
Sorry noob here, what is pd?
PD = positive displacement superchargers
TemeCal is offline   Reply With Quote
Old 03-14-2013, 10:00 AM   #194
ft_sjo
Drives: GT86
Thanks for clarifying, some people may have gotten confused with the other sensor down there!
The Following User Says Thank You to ft_sjo For This Useful Post:
2forme (03-14-2013)
Old 03-14-2013, 10:01 AM   #195
2forme
LOL that's what I said at the end of my quote. That being said, I'll take cool oil over 5 degrees of IAT anyday. Your setup wouldn't work for me as I have the AOS.
Old 03-14-2013, 10:02 AM   #196
ft_sjo
Drives: GT86
Have you cut a hole in the hood for air to actually pass through that oil cooler, or do you have the rear of the hood raised to allow air to escape? Otherwise it's just a heatsink..
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 12:19 PM
Pete's Perrin Vortech build thread Pete Member's Car Journals 91 06-04-2013 01:38 AM
*PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) PhastekSport Forced Induction 425 04-26-2013 10:06 AM
