Old 03-12-2013, 11:50 AM   #1
Subabie
Drives: BRZ LTD
Suggestions for my new Rims?!?!
I am a noob .. totally clueless what I am gona do with my BRZ
I dont like the "lifted" look it has.
SO i am thinking of getting new rims/tires for it
So far I am thinking of getting a set of Enkei Kojin Mat but clueless about sizes and all the specs .. will someone give thoughts and advices??
and what is all of this mean??
KOJIN,17x8,35,5x120,72.6,BK
Subabie is offline   Reply With Quote
Old 03-12-2013, 11:52 AM   #2
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Have you looked above? Any rim that you put on a stock ride height car will look more lifted. If the lifted look is what you wanna lose, maybe think about springs/coils?
Beyer Subaru is offline   Reply With Quote
Old 03-12-2013, 01:28 PM   #3
Subabie
Drives: BRZ LTD
lower it an inch and get an 18 inc rim!! Hows that sound?
Old 03-12-2013, 06:54 PM   #4
Beyer Subaru
You could just lower it and you won't have to deal with the monster truck look.
Lowered and 18" rims = lookin great.
I'm more fond of 16-17" rims on these cars but I've got 18's on right now due to availability. I'm waiting to see if some 17's become available that I really want.
Old 03-12-2013, 07:01 PM   #5
leon78
leon78's Avatar
Drives: 13 Whiteout
Noob will noob.....wheels not "rims".....im out.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 03-12-2013, 07:02 PM   #6
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Wheels! They're called wheels not rims they're wheels!
tuckdaddy is offline   Reply With Quote
The Following User Says Thank You to tuckdaddy For This Useful Post:
leon78 (03-12-2013)
Old 03-12-2013, 08:45 PM   #7
Beyer Subaru
Ummmm ok. Sorry rim, I mean wheel police.
Y'all can call em wheels I'll call em rims, shoes, cycles, disks, rollers or what ever I want.
Thanks for contributing to the OP's thread with this new and insightful revelation.
Old 03-12-2013, 09:16 PM   #8
leon78
leon78's Avatar
Drives: 13 Whiteout
http://en.wikipedia.org/wiki/Rim_(wheel)
The rim is the "outer edge of a wheel, holding the tire."[1] It makes up the outer circular design of the [ame="http://en.wikipedia.org/wiki/Wheel"]Wheel - Wikipedia, the free encyclopedia[/ame] on which the inside edge of the [ame="http://en.wikipedia.org/wiki/Tire"]Tire - Wikipedia, the free encyclopedia[/ame] is mounted on vehicles such as [ame="http://en.wikipedia.org/wiki/Automobile"]Automobile - Wikipedia, the free encyclopedia[/ame].
That is all.... .... teachable moment.
The Following User Says Thank You to leon78 For This Useful Post:
tuckdaddy (03-12-2013)
Old 03-12-2013, 09:22 PM   #9
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Just thought i would help clear up the confusion between RIMS and WHEELS so he doesn't buy rims but buys wheels for the car!
Thanks for the irrelevant post though i'm sure it was educational and just as beneficial to the clearing up of the confusion of the revelation i revealed.
The wheel police...
leon78 (03-12-2013)
Old 03-12-2013, 09:31 PM   #10
Xdragonxb0i
Drives: ex500r
You want to lower your car to get rid of the tire gap.
You probably wanna get no more then 8'' wide since i assume your on stock HP numbers
Xdragonxb0i is offline   Reply With Quote
The Following User Says Thank You to Xdragonxb0i For This Useful Post:
Beyer Subaru (03-13-2013)
Old 03-12-2013, 10:01 PM   #11
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
KOJIN - I assume to just be a brand so disregard that.
17x8 - 17" wheel diameter, 8" wheel width
5x120 - That is the lug/bolt pattern. The 5 represents the lug/bolt count while the 100 represents the bolt circle diameter. In this case, the 100 is metric and means 100mm. The twins use a 5x100 bolt pattern.
72.6 - That is the wheel hub inner diameter. It is better if the wheel rest on the hub and not the bolts. When a wheel has a greater hub diameter than the car's wheel hub, hub-centric discs are used.
BK -
Then there are tire specs. 115/45R17 87W
Someone please correct me if I'm wrong.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Old 03-12-2013, 10:36 PM   #12
schtebie
Drives: CBS BRZ Limited
BK -
BK probably means black.
schtebie is offline   Reply With Quote
The Following User Says Thank You to schtebie For This Useful Post:
Old 03-12-2013, 11:59 PM   #13
boredom.is.me
Custom User Title
That's actually what I was thinking.
Old 03-13-2013, 04:53 AM   #14
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
your selection by wheel is limited by the car's bolt pattern (5x100)...
for the Kojin
17x8 +40
17x8 +45 (closest to stock)
17x9 +45
18x8 +40
18x8 +45
18x8.5 +45
18x9.5 +45
(so for 17x8 +40 17 is the wheel height (inches), 8 is the wheel width(inches), and +40 is the offset. offset just describes how far the mounting surface of the wheel is from the center of the wheel's width, so this wheel's mounting surface is 40mm out from the center)
are your options. then you decide what sizes you need depending on if you want a square setup (all wheels/tires same size) or staggered (rear wider than front).
square lets you rotate tires easily and would probably maintain the character of the stock car (since it is square setup from the factory).
staggered gives you that agressive sports car look and could increase understeer/decrease oversteer at the limit of grip depending on tire selection
so you tell us what you want to do and your goals are, and we make a suggestion
btw, 'rims' is just slang for wheel, no need to ride his ass about it.
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
NAV Radio suggestions Dadhawk Electronics | Audio | NAV | Infotainment 20 07-31-2013 02:25 PM
Suggestions? Cameronghanson Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-18-2013 10:19 PM
HELP! Need Suggestions Please!!! Bfly BRZ First-Gen (2012+) — General Topics 30 09-05-2012 03:46 PM
Wheel suggestions... wootwoot Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-05-2012 01:00 PM
MT shift suggestions DIE1000DEATHS Engine, Exhaust, Transmission 6 07-21-2012 10:39 PM
