#15 |
Drives: Some rust bucket
Note that warming up the engine doesn't mean the transmission is warmed up. When you idle your car until your engine is "warm", the transmission isn't at operating temp yet. You still need to take it easy until the transmission is warmed up.
The same thing for the differential. You need to drive it to warm it up. This is what I do. Start the car. Wait about 10 seconds. Drive slowly (stay below 2.5k RPM) for a few miles. It make take a longer distance/time if you're in a colder area. Once the car is at the proper operating temp, then you can start beating on it. |
#16 |
Drives: Scion FR-S
This is just a lot of various opinions. I like to warm up, but I have no idea if it's right. Is there any actual data or definitively expert opinion/explanation?
#17 |
Drives: 2013 Asphalt FR-S
consensus: It will be fine if you pull off right after you started up, just don't go flogging it until temps are up to normal operating range.
#18 |
Drives: Scion FR-S
#19 | |
However, there are some things we do know for sure. Engines need oil to lubricate parts. Cold oil is thick, and when oil is too thick, engine components aren't fully lubricated. When components aren't fully lubricated, you have metal on metal contact. This is BAD. |
#20 |
#21 | |
Drives: Ion Redline
Most of us who do it, even if it's placebo, have gotten the desired results from doing it, so we'll most likely continue to do so. Those that don't, don't, and probably won't start now.
"Bullshit, asshole! No one likes the tuna here!"
#22 |
Drives: 2013 Ultramarine FR-S
Volvo manuals have, for years, said that no warm-up period is necessary, just to take it easy until the engine reaches operating temperature. How this applies to other makes is probably arguable, but I would tend to believe that the Swedes know a thing or two about driving in cold weather.
#23 |
Drives: WRB BRZ
i wait for the temp gauge to change just a little bit, usually that's about a minute or so.
#24 |
Drives: 2013 Firestorm FR-S
I don't wait for the car to warm up to drive but I would never push the car over 4,000rpm until my water temps are ~180f.
2013 Firestorm FR-S, MTX, build date 1/13.
#25 |
Drives: dirty er'ryday
#26 | |
Drives: Scion FR-S
I don't think there are too many variables. It's pretty simple, there is temperature range for starter car, there is time to warm up, and there is a way to measure wear. Surely engine makers do this kind of thing all the time, so there must be some concrete data. |
#27 | |
Drives: Scion FR-S
#28 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
| Warm air from vents | blunova | Issues | Warranty | Recalls / TSB | 131 | 10-06-2020 01:27 PM |
| Warm Up? | gt865 | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 09-17-2014 11:28 AM |
| good warm-white LEDs? | Elfreda Blau | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-13-2012 10:06 PM |
| a thought about the warm air coming from the vents... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 08-02-2012 10:06 AM |
| Warm vs cool Weather performance | EsoBOFH | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-10-2012 11:45 AM |
