Old 03-11-2013, 09:27 PM   #225
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by ATL BRZ View Post
I should also mention that I'm in an emissions state (no visual inspection) and I'm not sure the car would pass a smog test via obd2 even if there was no CEL with an EcuTek tune, and the secondary cat were present. To make obd2 emissions testing work I'd have to move the o2 sensors fore and aft of the secondary cat, right? That would probably be a pain in the ass.
That would be a huge pain especially since there are no bungs after the secondary cat.
How many years is your car exempt?
FT-86 SpeedFactory is offline
Old 03-11-2013, 09:27 PM   #226
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Three years I believe in Georgia.
I think my best option at staying as quiet as possible with as little rasp and cabin drone would be a catted EL header and then maybe a (Invidia) catless resonated front pipe. I haven't seen any catted UEL headers yet. A catted UEL design would be difficult to make work, and that's why I don't think we'll see one. I'd love to be wrong.
ATL BRZ is offline
Old 03-11-2013, 10:31 PM   #227
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I'm in for an answer on that. Will the OBD2 say "ready" with this header?
Coheed is offline
Old 03-11-2013, 10:45 PM   #228
jwjknorr
Drives: FRS 2013
Look up defoulers, there simple to install and cheap they will take care of any cell issue from no cat, and wont be detected by the ecu.
jwjknorr is offline
Old 03-11-2013, 10:49 PM   #229
ATL BRZ
ATL BRZ's Avatar
Thanks but a defouler would only fix the cel and I'd still be unable to register my car in GA or any clear air state without a passing a legit obd2 test. I don't think the tail pipe sniffer test is an option for a car this new.
ATL BRZ is offline
Old 03-11-2013, 11:38 PM   #230
NickFRS
Drives: 2013 Asphalt FRS
Keep your stock header. When you need to go in simply swap them out.....
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline
The Following 2 Users Say Thank You to NickFRS For This Useful Post:
Hawaiian (03-12-2013), NoFear99 (03-12-2013)
Old 03-12-2013, 01:46 AM   #231
baxter7893
Drives: 2013 SWP Subaru BRZ
was this ever tested with the Q300, and catless front-pipe? Video's?
baxter7893 is offline
Old 03-12-2013, 01:55 AM   #232
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by NickFRS View Post
Is there anyway you guys throw the header on a stock car to get a dyno graph? I'm really curious on what the header does on it's own w.o a full exhaust. Or even just a car with a full exhaust + the header would be awesome. Would give us as a community a better understanding on how this header stacks up to the Nameless Header that isn't released yet. Also if it's not asking to much even a un-flashed pull then a pull with the tune would be dope. Thanks guys!!! Look forwards to my order sometime at the end of next month!
If someone pays my fuel, i'll drive out with the P&L and do a shootout.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 03-12-2013, 06:33 AM   #233
FT-86 SpeedFactory
We're looking into doing this, but can't guarantee anything. Unless I missed it Nameless has not tested theirs on a stock car, all their tests have been with tunes and full exhaust systems from what I have seen just like ours with the Borla unit was.
The very first dyno plot we posted was without a tune optimized for the header. It was a base stage 2 tune. The final number/dyno was after a couple minor tune tweaks.
Old 03-12-2013, 07:59 AM   #234
mad_sb
Drives: 2013 Asphalt FR-S
No, to pass OBDII in out state you just have to have completed the readiness tests. If ecutek turns off the cell but does not allow the readiness checks to complete you will not pass. I would imagine they have considered that in coding the patch.
mad_sb is offline
Old 03-12-2013, 08:02 AM   #235
mad_sb
Yes you would pass with an anti-fouler so long at it prevents the cel. There is NO visual inspection in GA. OBDII test are the easiest ones to cheat. No check engine light and non continuous monitors complete = pass.
Feel free to PM me if you need details. I have a copy of tech-stream as well so it's very easy to monitor the OBDII stuff to see when the drive cycle is complete. We could install and test the anti fouler in about an hour one after noon (once the header or manifold cools enough to remove the sensor), including completing the drive cycles to get it ready for emmisions test.
FWIW i plan on doing catless EL header along with my nameless catted front / over combo and nameless axle back. Keeping the stock midpipe and a highflow cat in the system keeps the volume down. If the axle back is too loud i will go with a quiet catback.
mad_sb is offline
The Following User Says Thank You to mad_sb For This Useful Post:
ATL BRZ (03-12-2013)
Old 03-12-2013, 10:02 PM   #236
FT-86 SpeedFactory
We have yet to get a CEL on the silver car and it has probably 100 miles on the header. Not sure how long it would take if it is going to throw one. I can only assume it will.
Old 03-13-2013, 12:23 AM   #237
NickFRS
Below are the details in which we did the dyno, the parts on the car, and other information.
Mods on the car that affect the results:
Current Upgrades:
Engine & Exhaust
FT-86 SpeedFactory V1 Exhaust
Borla UEL header
Perrin Overpipe
Invidia catted frontpipe
aFe Takeda Intake
Didn't you mention the intake was modded?
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline
Old 03-13-2013, 07:14 AM   #238
FT-86 SpeedFactory
Correct, exactly as we listed.
Borla UEL Header, any dynos yet? FR-S Matt Engine, Exhaust, Transmission 111 05-16-2016 09:31 PM
AEM Tuned Intake - Pics / Videos / Dynos - FT-86 SpeedFactory Review FT-86 SpeedFactory Engine, Exhaust, Transmission 136 11-05-2015 07:48 AM
Fortune Auto - SpeedFactory Review - Video / Pics - Tracked / Autoxed / Drifted FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 01-29-2015 09:15 PM
Buddy Club Spec II - FT-86 SpeedFactory Review - Photos and Videos FT-86 SpeedFactory Engine, Exhaust, Transmission 35 03-17-2013 10:46 PM
