Old 03-11-2013, 03:36 PM   #15
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Originally Posted by dun3 View Post
Makes me want to just throw in a bazooka and say screw custom boxes and shit..
You can do that if you like... but I still prefer my setup and it was worth every penny!
Scott
naikaidriver is offline   Reply With Quote
Old 03-11-2013, 04:29 PM   #16
Liquidsnake
Drives: "I drives like a Porsche"
Originally Posted by mbh1101 View Post
What is the bazooka base mount, mounted to?
I have since changed the position of the tube, I got rid of the straps. The tube moved around to much.
Its such an awesome set up. I have it pressed up against the back seat parallel to the back seat. It is held in place by a single 6 inch bracket bent at a 90 degree angle screwed into the top of the tube, and the back seat. Has not budged in 6 months.
Liquidsnake is offline   Reply With Quote
Old 03-11-2013, 05:00 PM   #17
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Originally Posted by Liquidsnake View Post
It's been a long day. I will post pics in 10 min. Got my bazooka installed. 8 inches was perfect. I still have 3/4 of the trunk available. The guys who installed this had no clue what they were doing. It was sadly amateur hour. I've got to hide some wires myself. End result is fine.
I'll post my tips. I bit off of another forum member.
10 min.
For future reference, install the bazooka yourself.
Eric G
mkiisupra is offline   Reply With Quote
Old 03-11-2013, 05:07 PM   #18
Liquidsnake
Eric G
Dude I stood in amazement when I was able to change shower heads, and use water sealing tape correctly. Like I built a castle.
I would not be able to install the tube myself.
You should have seen me Saturday for two hours trying to figure out if I put a drop in filter correctly. Its some sad shit man.
My girl tells me oh my car is making funny noises, so I pop the hood and say oh timing belt looks good, carburetor's ok, lets take it in to get looked at. Like I know what I am talking about. So I don't look impotent.
The Following 3 Users Say Thank You to Liquidsnake For This Useful Post:
chenshuo (03-13-2013), mkiisupra (03-11-2013), tripjammer (03-11-2013)
Old 03-13-2013, 11:37 AM   #19
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
10 min.
Did You get The 50 or 100 watt Bazooka 8"?
Old 03-13-2013, 01:46 PM   #20
Liquidsnake
100 Watt. [ame="http://www.amazon.com/gp/product/B0002QYS8W/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1"]Amazon.com: Bazooka BTA8100 BT Series 8-Inch 100-Watt Amplified Tube Subwoofer: Car Electronics[/ame]
The Following User Says Thank You to Liquidsnake For This Useful Post:
finch1750 (03-13-2013)
Old 03-13-2013, 04:50 PM   #21
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Having been through the HS years with the crazy system I was very skeptical of going with an inexpensive choice like the Bazooka. In the end I picked the BTA10250D on sale for $125 and gave it a shot, it was too cheap to pass up.
It's light, easy to remove quickly, and sounds surprisingly good. It adds more than enough bass. Best bang for the buck I have seen yet for this car. Highly recommended.
OjiGeorge is offline   Reply With Quote
Old 03-14-2013, 02:54 PM   #22
Thorpedo
The SquadWhisperer
First post!
The bazooka tubes do put out a surprising amount of bass for their size and wattage. I was about to buy one for mine as they are really easily removed for track days when I found this guy.
A little pricey but it is tiny and has the amp built in and is easily removable (1 molex connector and 2 straps)
http://www.futureshop.ca/en-CA/produ...2db494a764en02
Thorpedo is offline   Reply With Quote
Old 03-14-2013, 03:09 PM   #23
mkiisupra
mkiisupra's Avatar
'Zookas weren't cheap when I was in high school, but then again, that was when you could build most of the amps available from parts at Radio Shack. Ask me how I know... Only up until about early/mid-2000's, they were twice the price.
If'n you aren't going to audio competitions, this will work in most hatches for less money and with 80-95% effectiveness.
Eric G
Old 03-14-2013, 10:24 PM   #24
Timmy_Jones
Spun
Drives: 23' Supra
I was so scared a bazooka tube was some sort of ridiculous exhaust.
Timmy_Jones is offline   Reply With Quote
Quad exhaust tips? migle Engine, Exhaust, Transmission 86 09-23-2020 11:45 PM
JDM BRZ/GT-86 Exhaust Tips Sportsguy83 Engine, Exhaust, Transmission 166 09-16-2020 03:44 PM
Exhaust Tips *UPDATED* with pics Ericfrs Cosmetic Modification (Interior/Exterior/Lighting) 35 01-13-2017 02:58 PM
Exhaust tips rawbz Cosmetic Modification (Interior/Exterior/Lighting) 37 01-19-2013 08:12 PM
Let's keep it simple, I want to change out my exhaust tips. Liquidsnake Engine, Exhaust, Transmission 11 06-30-2012 03:08 AM
