Old 03-11-2013, 11:12 AM   #365
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by JDLAutoDesign View Post
Yes we have it scheduled just really busy with getting the car ready
yeah understandable. Your twinscroll kit looks insane. I might have to sell a kidney
Thanks for responding! (and sorry for being a PITA )
xxscaxx is offline
Old 03-20-2013, 07:02 PM   #366
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Got lots of stainless in today. EL & a few UEL headers
JDLAutoDesign is offline
Old 03-20-2013, 07:05 PM   #367
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Any fueling or AFR issues with the secondary O2 sensor spacer on the catless headers running on a STOCK ecu tune? I noticed in the pics of the EL header that there's a spacer/spark plug anti fouler on the second O2 sensor, presumably to avoid getting a CEL.
Check this out: http://forums.nasioc.com/forums/show....php?t=2234058
OK, this one is coming back again because a couple of vendors offer what they call "O2 Sensor Spacers" that they incorrectly list as compatible with 2005+ Subarus. I'm getting PMs about these on a pretty regular basis.
They're also available as spark plug anti-foulers or as little extension tubes welded on to the pipe.
Regardless of what they're called, what they do is to move the O2 sensor physically farther away from the main exhaust flow in hopes of tricking the ECU into not throwing the P0420 DTC when you run headers, a HFC, or a trackpipe. While on some cars they do actually prevent the P0420 DTC from being thrown, they cause fueling problems on all cars 2005 and newer. In 2005, Subaru switched to an ECU that uses the input from the rear O2 sensor to affect fueling in addition to simply monitoring the cat (as in 2004 and older cars). If you remove the rear O2 sensor entirely, mount it somewhere that isn't in the exhaust at all (don't laugh, I've seen it done), or even just move it out of the main exhaust flow, you'll develop strange fueling errors as the ECU tries to make the rear O2 see what it's programmed to achieve. The result of this is slightly worse fuel economy, a worse idle, and generally increased difficulty in getting the car tuned to a good state.
Summary: DO NOT USE O2 SENSOR SPACERS OR SPARK PLUG ANTI-FOULERS ON 2005 OR NEWER SUBARUS.
Also, it's worth noting that you can't use electronic "MIL Eliminators" like the ones from Pony Express on 2005 and newer Subarus either. Your only solution to getting a P0420 DTC on the newer cars is to disable it in the tune.
Makes me nervous about using one with the stock tune.
ATL BRZ is offline
Old 03-20-2013, 07:11 PM   #368
JDLAutoDesign
Drives: 13 FRS
We ran ours on the stock ECU no tune whatsoever with no fueling issues at all. We have air fuel graphs to show as well as graphs of our AF to show it with the sensor completely unplugged.
We also stated that if this is an issue we would move the secondary bung behind the catted front pipe. Whatever is most comfortable for the customer is what we wil do
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
ATL BRZ (03-20-2013)
Old 03-20-2013, 07:17 PM   #369
ATL BRZ
ATL BRZ's Avatar
Good info, thanks! This needs to be in the OP of all the catless header threads!
ATL BRZ is offline
The Following User Says Thank You to ATL BRZ For This Useful Post:
JDLAutoDesign (03-20-2013)
Old 03-20-2013, 07:38 PM   #370
JDLAutoDesign
Drives: 13 FRS
Im going to take a few pics to show the procedure and leave the option up to the customer. Since we are EMS we arent running it at all any more
Old 03-22-2013, 08:01 AM   #371
xxscaxx
Friday bump
xxscaxx is offline
Old 03-22-2013, 10:23 AM   #372
HRTROB
HRTROB's Avatar
Drives: Toyota 86
So you're saying the secondary o2 sensor does nothing more than check for the quality of air after the cat, correct? AFR stayed the same with the secondary o2 sensor unplugged?
HRTROB is offline
Old 03-22-2013, 05:24 PM   #373
JDLAutoDesign
Drives: 13 FRS
The wideband O2 sensor for the Dyno was in the spot where the secondary normally goes.
HRTROB (03-24-2013)
Old 03-25-2013, 10:42 AM   #374
xxscaxx
xxscaxx is offline
Old 03-25-2013, 09:07 PM   #375
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
When does the catback get released? Excited to see what the single looks like the from the back.
Tansey86 is offline
Old 03-26-2013, 07:04 PM   #376
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
And what it weighs.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline
Old 03-26-2013, 07:06 PM   #377
Tansey86
Tansey86's Avatar
Originally Posted by Simmons View Post
And what it weighs.
Simmons
I heard the entire system netted them over 40 lbs in weight loss. Pretty impressive.
Tansey86 is offline
Old 04-11-2013, 10:52 PM   #378
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
UEL ETA? Bump
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline
The Following User Says Thank You to ngabdala For This Useful Post:
FreshFRS (04-11-2013)
UEL Header Development 86drift Engine, Exhaust, Transmission 77 07-07-2016 01:45 AM
SRT Header Back Exhaust System Intro Piricing Swift Racing Technologies Engine, Exhaust, Bolt-Ons 51 09-25-2012 10:00 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
