Old 03-10-2013, 11:12 AM   #15
Turbowned
Turbowned's Avatar
Originally Posted by Spaceboy View Post
i thought you should never go into first
On older cars without synchros in first gear, this is valid. Otherwise you're fine.
Old 03-10-2013, 11:33 AM   #16
a2cpc
Drives: WRX
I have been driving since(god, I sound like my dad) 1968. We have always had at least 1 vehicle in the family with a stick. The only clutch problem I ever had was a cable on a Datsun 2nd Gen 510. When approaching a stop sign I have always fully depressed the clutch, applied the brakes and when close to fully stopped shifted into 1st. It is not that hard.
a2cpc is offline   Reply With Quote
Old 03-11-2013, 02:40 AM   #17
Morg
Drives: 2014 Ford Fiesta ST Green Envy
Coasting in neutral is easier, and might make you feel less guilty about clutch wear but is kind of an amateur and/or lazy habit.
"Best" depends on who you ask I suppose...
Out here, you would likely fail your drivers license exam if you pulled that. And any instructor at any of the schools for both manual cars and motorcycles... will give you hell for it. Generally, "safety" is higher on the priority list than clutch wear, and if you are downshifting and braking properly it really isn't going to hurt your clutch significantly.
Perhaps these standards are different elsewhere? But out here you're basically told that the reason NOT to coast in neutral is because if there is any last second emergency or whatever and you need to react IMMEDIATELY you will already be in gear and that power is then accessible to you right away. That 1-3 seconds it takes you to get into gear when you realize you are about to get hit by someone (assuming you are paying attention) and are in a state of panic... can make the difference between getting hit or getting out of the way.
Anyone who's been rear ended or experienced permanent neck/back damage can probably vouch for how unpleasant those kinds of injuries are.
Granted there is the argument, that "well I'm thuper awethum at shifting pro because race car!" but when the shit hits the fan, do you want to gamble on your nerves being what they need to be? Most people who panic in a moment like that, didn't expect to react that way. And if you're watchin a car come barrelling towards you while you're sipping a latte in neutral and texting.... you'll wish you had an automatic.
FWIW, the day I was in an accident as a rear seat passenger in a manual at a stop light. I wish my buddy had it in gear. Could have been avoided if he had any power to the wheels to gtfo.
Life changing and not in a good way. Barely survived. And life's not the same due to the aftermath.
Anyway, not to be "that guy" and pitch the safety first rant... To be honest, I find that I habitually tend to neutral coast.... so I have to really consciously decide to not do that.
Green Envy 2014 Ford Fiesta ST
Red 1984 Harley Davidson Ironhead XLH 1000
Blue Flame 2010.5 SVT Raptor 6.2L SCab (Sold)
Black 2010 Camaro 2SS~RS m6 (Sold)
Black 2009 Honda Ruckus (Sold)
Morg is offline   Reply With Quote
Old 03-11-2013, 05:30 AM   #18
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Downshifting: it could save your neck and it sounds cooler too!
Ganthrithor is offline   Reply With Quote
Old 03-11-2013, 08:07 AM   #19
a2cpc
Drives: WRX
If you were talking to me, I never said I was in neutral, just had the clutch in as I came to a stop. True, I might be technically "coasting", I maintain the proper gear and can remove my foot from the clutch as fast as I can move my other foot from the brake. I also haven't had an accident in over 20 years.
Old 03-11-2013, 12:21 PM   #20
Mollusk
Drives: Honda Civic
Bury your foot in the throttle until it redlines in whatever gear you happen to be using. Then shift from that gear directly into first without using the clutch pedal. Then do a couple of donuts around the stop sign. That is how the pros do it.
Mollusk is offline   Reply With Quote
Old 03-11-2013, 03:26 PM   #21
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Pros or Honda drivers?
speedracer38 is offline   Reply With Quote
The Following User Says Thank You to speedracer38 For This Useful Post:
sklimo (03-11-2013)
Old 03-11-2013, 04:01 PM   #22
brz7400
brz7400's Avatar
Drives: Subaru BRZ
too many approach & go situations to say...
- i may coast to stop sign in neutral if i am the only one coming up to it & no one behind me and feeling leisurely.
- i may stay in gear if cars in front of me, but they are moving along quickly after stop. or if there is someone behind me while things are moving along quickly at the intersection.
- if i know i will just stop and go without waiting, i stay in gear.
- if there are other cars waiting at the intersection, i put in neutral since it will take some time for your turn.
brz7400 is offline   Reply With Quote
Old 03-11-2013, 07:27 PM   #23
GNS
Drives: .
Originally Posted by kchkwan View Post
Hey guys
General question on manuals and stoping for a stop sign then lift off again.
Whats the best procedure?
Usually this is what I do, clutch, shift to neutral, brake till full stop, clutch, shift to 1st gear and go
Or on the other hand does anyone do this?
Break to nearly full stop, clutch for full stop, leave in 1st gear, and depress the clutch to lift off.
I know it adds wear and the if the clutch is pressed for too long, but if for method 2, which only lasts 3secs. Is that a big deal?
However, the main idea is, which method is better or is there another?
Just be careful if there are people behind you. I have avoided at least one accident by judging how fast someone is coming up behind me and moving my car out of the way before said retard could ram into me. This split second decision was helped by the car already being in gear as I was slowing to a stop.
Don't take it as a hard and fast rule to always slow to a stop in gear, sometimes its just not needed (nobody behind you, clear roads, slow speeds, etc).
GNS is offline   Reply With Quote
Old 03-11-2013, 09:25 PM   #24
Mollusk
Drives: Honda Civic
Oh snap! lol I guess I deserved that.
(Disclaimer: my advice is for entertainment purposes only. I have only driven a manual car once.)
Old 03-11-2013, 09:48 PM   #25
speedracer38
All in good spirit just giving you a nice welcome for your first post :happy0180:
Old 03-11-2013, 10:21 PM   #26
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I usually downshift to second by rev matching, engine brake, slowly press brake pedal if needed, push clutch and brake, put in first (I am stopped at this point), look all around including rear view mirror, let off brake, depress clutch and give gas, continue driving. I always do this as I have no need for a SUDDEN stop at a stop sign. If for some reason I almost miss the sign, its foot push clutch and full braking, put car in first, repeat previous steps when stopped.
The Following User Says Thank You to Khazzy For This Useful Post:
speedracer38 (03-12-2013)
Old 03-12-2013, 09:10 AM   #27
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
I just stop or do the rolling stop, look both ways to see if any cops (as was mentioned earlier), and really don't count the friggin steps. I've got things to do, places to go, people to see.
BRZfan is offline   Reply With Quote
Old 03-12-2013, 09:59 AM   #28
Khazzy
Khazzy's Avatar
I do not go through any steps either, this is all second nature to me and just happens to be the way it takes place. I actually had to think about how I stopped for a min to type it out.
sklimo (03-13-2013)
Road to SEMA Tour stopping at King's in Cincinnati Brett Great Lakes 0 10-17-2012 04:08 PM
Vinyl Stickers and Signs Corked Designs Exterior Parts - The Rest 4 06-25-2012 12:27 AM
Please... Stop... Me.. moda3 Great Lakes 4 12-09-2011 11:51 AM
signs of scion dealer getting ready for FR-S 4agze Scion FR-S / Toyota 86 GT86 General Forum 32 05-15-2011 05:05 PM
