Old 03-09-2013, 11:11 AM   #1
kchkwan
Drives: Subaru BRZ
Stopping for stop signs
Hey guys
General question on manuals and stoping for a stop sign then lift off again.
Whats the best procedure?
Usually this is what I do, clutch, shift to neutral, brake till full stop, clutch, shift to 1st gear and go
Or on the other hand does anyone do this?
Break to nearly full stop, clutch for full stop, leave in 1st gear, and depress the clutch to lift off.
I know it adds wear and the if the clutch is pressed for too long, but if for method 2, which only lasts 3secs. Is that a big deal?
However, the main idea is, which method is better or is there another?
kchkwan is offline   Reply With Quote
Old 03-09-2013, 02:01 PM   #2
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
1st method is better, forces u to do a proper stop, and if ur pretty good at driving stick u can just take off immediately anyway, plus no wear and tear from the clutch imo
brzadrian is offline   Reply With Quote
Old 03-09-2013, 02:55 PM   #3
fatoni
i prefer the second method for stop signs simply because youre only stopped for a second. the time it takes to press the clutch pedal twice is probably longer than how long you would press it once. at lights it just depends on the strength of the clutch pedal regarding what i do. either way is not going to make a significant impact on the life of your clutch. i doubt either one is more damaging than when you engage the clutch to start the car every day.
Old 03-09-2013, 03:27 PM   #4
shawnperolis
shawnperolis's Avatar
Drives: 2013 Scion FR-S MT "Panda"
The first method you described is best.
shawnperolis is offline   Reply With Quote
Old 03-09-2013, 03:34 PM   #5
whtchocla7e
Drives: 2013 FR-S Hot Lava
I hate to admit it but I no longer fully stop at stop signs if there's no one else at the intersection. I do a rolling stop and take off in second.
If I have to stop then I follow the same procedure as you guys.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 03-09-2013, 03:47 PM   #6
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
I usually downshift until I hit second gear, clutch in when engine drops to ~idle RPMs (I don't like to coast), shift to 1st as I come to a stop (I usually don't like trying to rev match into first), and then accelerate away from the stop in 1st.
Sometimes if it's downhill-ish or a place where I don't want to accelerate quickly anyway I'll start in second. I probably won't do much starting in second in the BRZ though since it doesn't have much torque and would probably involve a lot of clutch slipping.
Ganthrithor is offline   Reply With Quote
Old 03-09-2013, 05:12 PM   #7
andrew20195
The additional wear from holding in the clutch pedal is on the clutch release bearing, not the clutch disc itself. Generally, as long as you aren't riding the clutch pedal, your clutch disc will wear out before the bearing (although I'd recommend replacing it along with the clutch.
Personally, it depends on how long I have to wait. If it's a 4 way stop, I generally use method 2. If I'm stopped at a cross street with traffic, I'll use method 1, more for not having to hold the clutch pedal than out of mechanical empathy.
andrew20195 is offline   Reply With Quote
Old 03-09-2013, 06:38 PM   #8
Soslow
Drives: 2010 Suzuki SX4 SportBack
Gear down down to first, observe for police/traffic, accelerate.
Seriously I probably do the California roll thru 75% of the stop signs I encounter.
Soslow is offline   Reply With Quote
Old 03-09-2013, 10:49 PM   #9
kchkwan
Drives: Subaru BRZ
lol... ever since i started driving manual (2nd day of this yr) i've began to stop at every single one, it seems like it took soo much more focus to pay attention to low speed stalls on first than to completely stop :/
Old 03-09-2013, 11:07 PM   #10
whaap
whaap's Avatar
I do both ways. There is no particular formula I follow. I guess it just depends on the day and time and what driving mode I'm in at the time.
whaap is offline   Reply With Quote
Old 03-09-2013, 11:15 PM   #11
samfrs
Custom User Title
Drives: FRS
First method but take off in 2nd gear, it's a habit.
samfrs is offline   Reply With Quote
Old 03-10-2013, 04:16 AM   #12
dammitcubs
Drives: 2008 EVO X
What I usually do is that the first method. It also the way I learned to downshift. (by not doing it) lol. It's much harder to downshift smoothly than upshift so if I was worried, i used to put it in Neutral.
You should learn both, because they are both valuable. but my recommendation is that if you know for sure that you are going to stop, just put it in neutral. But it's also good to learn N to a specific gear at a specific speed. I usually use this technique if there was a improper shift and I had to put it in Neutral but I'm coasting and want it back in gear, you have to know how much to blip the throttle.
dammitcubs is offline   Reply With Quote
Old 03-10-2013, 05:30 AM   #13
cgrey
Drives: 2013 Argento Silver FR-S
Everyone in my area runs stop signs at 25mph+. I seriously count more people running stop signs than stopping. I vote for that.
Dear cgrey,
You have received an infraction at Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB.
Reason: Quit the trolling.
cgrey is offline   Reply With Quote
Old 03-10-2013, 11:03 AM   #14
Spaceboy
NG- Think better
Spaceboy's Avatar
Drives: White FR-s
i thought you should never go into first
Spaceboy is offline   Reply With Quote
Road to SEMA Tour stopping at King's in Cincinnati Brett Great Lakes 0 10-17-2012 04:08 PM
Vinyl Stickers and Signs Corked Designs Exterior Parts - The Rest 4 06-25-2012 12:27 AM
Please... Stop... Me.. moda3 Great Lakes 4 12-09-2011 11:51 AM
signs of scion dealer getting ready for FR-S 4agze Scion FR-S / Toyota 86 GT86 General Forum 32 05-15-2011 05:05 PM
