Old 03-09-2013, 04:16 PM   #1
SloS13
Drives: 2013 FR-S whiteout
FYI - it's possible to add a reverse camera for $20.
Using a mismash of various and sundry posts on this board I was able to add a backup camera to my FR-S with Bespoke head unit.
Camera: http://www.ebay.com/itm/Promotion-Ca...154300&vxp=mtr
(I will be replacing this with a wedge-type soon. The one in the link blows ass to align)
You don't really *need* any special harness or pins. I basically wedged a wire in the connector for the reverse sensor thingamabob in the back of the head unit, then used the pointy end of a zip-tie to make sure it didn't go anywhere.
I used computer floppy disk connector pins and heatshrink for the camera + and - connectors. Sounds kind of ghetto but it works great and I don't see it going disconnected under any reasonable scenario. I used the amp for 12v.
SloS13 is offline   Reply With Quote
The Following 3 Users Say Thank You to SloS13 For This Useful Post:
Rayme (03-09-2013), SupraRon (03-09-2013), Wolfking (03-10-2013)
Old 03-09-2013, 07:03 PM   #2
SupraRon
SupraRon's Avatar
Drives: Raven 6AT
I've been wondering about this. Do you have any pics?
The fun has returned!!
Morimoto Mini H1 HID conversion
SupraRon is offline   Reply With Quote
Old 03-09-2013, 07:05 PM   #3
SloS13
Unfortunately...no. I wish I would have If I ever have to open it up, I'll take some.
The Following User Says Thank You to SloS13 For This Useful Post:
Old 03-09-2013, 11:29 PM   #4
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
It's a piece of trim and 4 screws. Please do us all a huge favor and take some photos. You'll being doing us all a huge favor!
post_break is offline   Reply With Quote
Old 03-10-2013, 01:22 PM   #5
SloS13
Well crap, something isn't quite right. The wire I tapped for reverse puts out 12v whether I'm in reverse or not so the HU is always showing the camera.
I quadruple checked and I've tapped the correct wire (orange/white on back transitions to pink). Reverse lights work as expected but this wire is always 12v.
Old 03-10-2013, 02:29 PM   #6
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
http://www.ft86club.com/forums/showp...&postcount=157
Assuming of course the same harness exists on the FRS as the BRZ, which I would assume it does.
michaelahess is offline   Reply With Quote
Old 03-10-2013, 02:31 PM   #7
michaelahess
There are a bunch of posts on how this comes off. The right most trim panel is very easy, just put your fingers under the edge closest to the stereo trim piece and pull away from dash, work way around to the right, top, then back left.
Second piece around stereo, do same thing starting from the right, don't pull it out too far, just enough to get traction with your fingers to pull straight out.
4 10mm (IIRC) bolts and the stereo is out.
Old 03-10-2013, 03:37 PM   #8
post_break
post_break's Avatar
I know how it comes off, that's why I said how it comes off. I'm asking for pictures of this guys wiring job.
Old 03-10-2013, 03:48 PM   #9
SloS13
I would assume the same. I don't know if it's something different about the FRS or something weird about my car in particular. When I say I quadruple checked, I mean more like octo-checked. Very odd.
That's a little forward. We hardly know eachother. As much as I hate to, I think I'm going to run a wire from the reverse light harness to the HU. I'll take pictures at that point but I expect some in return. I'm not a whore.
Laika (09-10-2013)
Old 03-10-2013, 04:28 PM   #10
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Mhh reverse camera. I'd love to put a switch with multiple camera select...like one under the mirror to curb park
Rayme is offline   Reply With Quote
Old 03-10-2013, 04:58 PM   #11
michaelahess
Sorry, your post sounded like photos were needed of the take apart, not the connectors. I too would like to see the connectors.
Old 03-10-2013, 07:33 PM   #12
SloS13
Here is where I tapped in to reverse. I went ahead and ran 2 wires so I can later use the HU's 6v output to trigger a relay. This is near the trunk latch thing area.
Here is the connections for RCA input. Notice the beautiful heatshrink. Top is signal, bottom is ground.
I used the pins from a connector like this: (from floppy drive power)
Yes, it's ghetto, I soldered directly to a male RCA. Don't judge me.
stripped some wire for reverse wire.
shove wire into hole like you are making love to beautiful woman.
Now the wire is in there pretty tight but used the end of a zip-tie to really wedge it in there
Enjoy - trunk is open, you're looking at my garage door
the angle of the camera (not pictured) totally sucks donkey balls. Replacing camera soon - should only take a few minutes
post_break (03-10-2013)
Old 03-10-2013, 07:41 PM   #13
post_break
post_break's Avatar
Awesome! This is fantastic for bespoke owners.
Old 03-10-2013, 07:55 PM   #14
michaelahess
If you have any old video card dongles laying around, cut off one of the rca connectors and push those wires directly into the connector, that's what I did. Gives a nice quick disconnect for free!
"Genuine" reverse camera manboobs AUSTRALIA 35 09-13-2013 08:35 AM
anyone interested in a bespoke unit w reverse camera? xpicer NY / NJ / CT / PA 3 11-03-2012 06:57 AM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
