Old 03-08-2013, 08:05 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
AT owners only, custom CF paddle shifters, pin stripe custom color
So I love using my paddle shifters, but sometimes they are too short and miss them. Not to mention they are kinda puny looking.
I know high end super sports cars have CF paddles shifters from the factory but I am going to custom make the shifters with a Portland CF fabricator company.
My plan is to have custom stripes with our car color around the edge, (also no stripe option) and a glossy or flat looking CF paddle shifter that is much bigger so it is easily reached. And they will look bad ass.
I personally will have my SWP striped color on them for extra cost, and is in the process of making them. This will not be a complete replacement of the shifter, but rather an attachment to make them bigger. They will still rotate with the steering wheel and not stay put like some high end vehicles or a $2000 replacement.
This is an example with the red stripe, CF paddle shifters:
This process is just starting, and was seeing if people will be interested in purchasing them since I will probably make multiple of them, doesn't make sense to make just one after creating a mold. I am planning on making about 4 of them when they make the mold, to sell only for what the materials cost for prototype. Let me know if you are interested!
Update 3/9/13:
The steering wheel needs to come off for the paddle shifters to come out. I'm sure it is possible to screw the paddle shifter bolts from behind blindly, but taking off the steering wheel is pretty easy.
Follow the guide to take off the airbag on this DIY tutorial, very easy: http://www.ft86club.com/forums/showt...airbag+removal
When you take off the airbag mechanism, you will notice some screws that are in facing towards you (backwards), and that means the steering wheel needs to come off to take off those screws. The red arrow indicates the "bottom" of the screws.
Then the next thing you notice are some wires coming out of a box on the top side, with wire clips. There are 3 main wires coming out of them. One is for the horn/cruise control, one is for the airbag (yellow wire) and one is the for the paddle shifters. We are focusing on the paddle shift wires that splits in to "L" and "R" of the paddles. The red arrow indicates the wires for the paddle shifters, going right and left.
There are clips on the wires that you will need to pinch and take off before taking off the steering wheels. These are the various wires that does the controls. The very left wire is the airbag (big yellow cable), next one is the cruise control/horn, and the one farthest to the right is the paddle shift wires (red arrow). The airbag wire will not come off, they are attached to the main column so you can let that be hangin.
The steering wheel is attached by a single 17mm bolt. You will need a 17mm socket wrench to take this bolt off. This is what it should look like when you take off the steering wheel, with the airbag yellow cable still hanging out.
When you take off the steering wheel and flip it around, you can see the individual wires that split in the previous picture going to the paddles. Now that the steering wheel is flipped, you can unscrew the screws that were facing backwards from the front view. Also unclip the wires that are attached to the paddles. The red arrow indicates the wires that were connected to the paddles and the green arrow indicates the screw holes that were keeping the paddles in place. Once the screw comes out, you just take the paddles off, very simple.
The cables that are still attached to the steering wheel is only the cruise control/horn and the paddle shift cables. The green arrow indicates the cruise control cable and the red arrow indicates the paddle shifters. Since the cables on the shifter is unplugged and the connector to the column is unplugged, the cable will come out. However the cruise control cables are still connected to the steering wheel it self since we did not unplug those.
Now the paddles shifters are off, with the cable that attaches to the column and the shifter.
One mistake I made was when you re-plug the big yellow cable to the airbag system on the steering wheel, be sure to clip back those tabs that are on the connectors or else the "check airbag" light will come on. Learned it the hard way!
More info to come once we get the design and mold made.
Update 3/10/13:
It will be an add on piece, and not a brand new mechanism. The video shown here is an aftermarket CF paddle shifter for the R8.
[ame]http://youtu.be/rp_kdgNzQAw[/ame]
Just stick it on with 3M tape and bam. I don't have the resources to make a whole new paddle shift mechanism that replaces the OEM ones.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following 16 Users Say Thank You to BRZPDX For This Useful Post:
bggns (03-10-2013), BugeyedWagon (03-09-2013), calis5nest (03-09-2013), Dadhawk (03-20-2013), ericvanderwoodsen (03-09-2013), feldy (03-09-2013), finch1750 (01-26-2014), FRS_Ken (04-08-2013), kidgogeta (03-09-2013), Minovsky (03-08-2013), russv (03-08-2013), Saika (03-20-2013), supragoods (03-09-2013), SupraRon (03-08-2013), Tylub (04-08-2013), zzabbas (03-08-2013)
Old 03-08-2013, 10:25 PM   #2
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
let me know how the shifter come off please do a right up im looking to change mine as well.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
The Following User Says Thank You to jazztennor For This Useful Post:
BRZPDX (03-09-2013)
Old 03-08-2013, 11:29 PM   #3
SupraRon
SupraRon's Avatar
Drives: Raven 6AT
I'd be interested to see how these look when installed, but I've definitely noticed they're a little too small. Subscribed.
The fun has returned!!
Morimoto Mini H1 HID conversion
SupraRon is offline   Reply With Quote
The Following User Says Thank You to SupraRon For This Useful Post:
BRZPDX (03-09-2013)
Old 03-08-2013, 11:37 PM   #4
ScionFrsFan
Good idea! I like!
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
The Following User Says Thank You to ScionFrsFan For This Useful Post:
BRZPDX (03-09-2013)
Old 03-08-2013, 11:56 PM   #5
ThugNasty
Drives: Asphalt FR-S
ThugNasty is offline   Reply With Quote
The Following User Says Thank You to ThugNasty For This Useful Post:
BRZPDX (03-09-2013)
Old 03-08-2013, 11:59 PM   #6
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
I dont care how much just put me for the first person on your list to purchase these thanks! I actually dont mind red because they go well with the red stitching better than white imo~
Minovsky is offline   Reply With Quote
The Following User Says Thank You to Minovsky For This Useful Post:
BRZPDX (03-09-2013)
Old 03-09-2013, 12:16 AM   #7
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
Yes please!
The Following User Says Thank You to BugeyedWagon For This Useful Post:
BRZPDX (03-09-2013)
Old 03-09-2013, 12:19 AM   #8
DR 86
DR 86's Avatar
Definitely interested
DR 86 is offline   Reply With Quote
The Following User Says Thank You to DR 86 For This Useful Post:
BRZPDX (03-09-2013)
Old 03-09-2013, 12:38 AM   #9
BRZranger
Yes please
BRZranger is offline   Reply With Quote
The Following User Says Thank You to BRZranger For This Useful Post:
BRZPDX (03-09-2013)
Old 03-09-2013, 12:39 AM   #10
ScionFrsFan
I'm actually surprised nobody has made this already.
ScionFrsFan
Old 03-09-2013, 02:13 AM   #11
BRZPDX
Boosted Member
BRZPDX's Avatar
It may take a while, or some vendor might start making them before me but I will keep you guys posted. Going in for the first design meeting tomorrow
The Following User Says Thank You to BRZPDX For This Useful Post:
Minovsky (03-09-2013)
Old 03-09-2013, 03:06 AM   #12
Minovsky
Minovsky's Avatar
Great! no worries man! haha i just got new front lip, and getting side fenders soon cause i got hit and run sighh.. that aside tho im thinking of the seibon side venders cant wait haha!! Updates when possible!!!
BRZPDX (03-09-2013)
Old 03-09-2013, 03:16 AM   #13
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
Im soo in for these!!!
ericvanderwoodsen is offline   Reply With Quote
The Following User Says Thank You to ericvanderwoodsen For This Useful Post:
BRZPDX (03-09-2013)
Old 03-09-2013, 04:00 AM   #14
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Wouldn't it make more sense to have them replace the existing paddles? A replacement needs primarily to cover a larger angle of the wheel circumference so you can still catch the correct paddle with the correct hand even on sharper turns without having them so big that you over stress the pivots and activation switches.
Good idea
smbrm is offline   Reply With Quote
The Following User Says Thank You to smbrm For This Useful Post:
BRZPDX (03-09-2013)
for the AT owners, custom CF paddle shifters BRZPDX Northwest 17 11-24-2013 11:45 PM
How do I use my paddle shifters? nerb Other Vehicles & General Automotive Discussions 13 02-17-2013 08:10 PM
Paddle Shifters Atticus808 Scion FR-S / Toyota 86 GT86 General Forum 8 10-01-2012 09:34 PM
paddle shifters Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 11 08-28-2012 11:15 PM
Paddle-Shifters Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 45 09-14-2011 01:20 AM
