Old 03-07-2013, 11:49 PM   #15
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Originally Posted by SubaSteve View Post
Sucks because you have to drill out a hole and our dremel is stuck at max speed..... Had to go get a washer to fill the edges.
You tap into the white wire with blue tape on it.
What does tapping into the white wire do?? Which wire do you need to tap into to have the fog light indicator on the dash light up?
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
Old 03-08-2013, 03:16 AM   #16
coachzizi
Drives: 2013 scion FRS
or dont do any tapping, dont do any drilling. split the connection from low beams and attach to fog lights. They pop on when i have my low beams on....less hassle
coachzizi is offline   Reply With Quote
Old 03-08-2013, 09:22 AM   #17
Gost
Drives: 2014 Scion FR-S
Originally Posted by Asphalt View Post
safe to say then that the fog light kit will include a new stock. seems like a little bit of a pain to install. maybe someone with more experience with this could input
Is there a foglight kit that's for sale? Or is it in the works or something?
I've been wanting the foglights on my FR-S. I asked the dealership if it was already had prewiring if I was to install foglights on my own but they said no. It would be nice to see an official kit releaesd that included a new stock to turn them on and off.
Gost is offline   Reply With Quote
Old 03-08-2013, 12:09 PM   #18
KSC
KSC's Avatar
Drives: Ion Redline
I have a Premium that came with fogs. It looks like SubaSteve's pic, but I think it actual says "Fogs" above the switch.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 04-05-2019, 03:47 AM   #19
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
I am not sure whether I will get a response but wanted to ask.
The 2019 BRZ is the same and has a fake headlamp leveling switch beside the trunk release. I have 2 questions:
1) I assume that the wiring (as shown in the picture above the white wire) is still there in 2019 limited. Can I replace this Headlight leveling switch ( https://subaruonlineparts.com/subaru...ch-p-1347.html ) with the fake one and attach the wire to get it active? Are the 2019 headlights adjustable for leveling?
2) I plan to get this DLR lamp http://www.ft86speedfactory.com/suba...l#.XKcFBZj0mUk which includes the original switch. Does anyone know whether the wiring is also ready for the DLR lamp? I want it to look like the Japanese BRZs in this video - go to 3:45 minute - [ame="https://www.youtube.com/watch?v=-o3UsHULaVI&list=LLI7YNymaHfqdt-bOZxfwAMA&index=3&t=0s"]https://www.youtube.com/watch?v=-o3UsHULaVI&list=LLI7YNymaHfqdt-bOZxfwAMA&index=3&t=0s[/ame]
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 04-08-2019, 07:09 PM   #20
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
On my 2016 FRS there's a purple wire on the harness that plugs into the stalk. You'll have to take apart the plastic covers around the steering wheel to get to the harness but it's simple and easy to do.
All you have to do is ground the purple to one of the black wires on the harness. This emulates the fog switch that's on the 86 that's equipped the fog lamps. So every time your low beams turn on, the fogs turn on too and there's an indicator on the dash that illuminates to let you know. Keep in mind that this method requires you to use the factory harnesses to power your fog lamps.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Permanent Traction Override Switch DarrenDriven DIY (Do-It-Yourself) Guides 197 07-14-2020 11:03 AM
GT86 foglights installed but no switch? derka-derka Electronics | Audio | NAV | Infotainment 8 08-16-2013 03:13 PM
Switch to Subaru center caps? SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-26-2012 10:21 PM
LF: rear fog switch picture Silverdub Scion FR-S / Toyota 86 GT86 General Forum 6 06-28-2012 08:34 AM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 02:56 AM
